Results 1,561 to 1,570 of 2348
- Sep 2006
- 1,335
January 18th, 2012 02:58 PM #1561*Boss Dieseldude
Need your expert advice po. I recently bought a Foton Blizzard pick-up with 2.8L NA 4JB1 engine.
My experience as of the moment is steering wheel, pedals & shift knob vibrations during idle. My first diagnosis is cheap engine mounts and transmission mounts. Worry ko lang po kung masosolve nito ung vibrations na na-e-experience ko ngaun kung papalitan ko ung mga mounts. I don't know if vibration will be corrected by replacing engine mounts. I've never worked on a Foton. Btw, check the exhaust pipe if it has rubber isolator hangers.
My next concern is the loud engine noise na pasok sa loob ng cabin and parang nagp-produce pa siya ng low frequency noise na in long drives eh irritating na masyado. Any advice po to reduce the engine noise? Was planning to install sound deadeners sa hood and sa loob ng cabin to reduce noises. Install padding on the engine firewall if none. Retard engine timing by 1 or 2 degrees. It might reduce combustion noise.
Any advice po regarding my concerns will be greatly appreciated po.
thanks in advance
- Nov 2011
- 25
January 18th, 2012 05:30 PM #1562
- Sep 2008
- 35
January 19th, 2012 05:54 PM #1563Sir Dieseldude,
I came across a thread about adding 2t oil on diesel fuel and an amazing positive outcome from users particularly old model diesel vehicles. Even CRDI owners uses this motorcycle oil on their fuel system.
Being a diesel expert, can we have your thoughts on this matter? Will there be long term negative effect on the engine or injectors?
TIA
- Sep 2006
- 1,335
January 20th, 2012 11:36 PM #1564
January 24th, 2012 08:19 AM #1565
sir dieseldude, question lang...
my ride is 3.5-mo, 3500kms-old kia carens 2.0 crdi vgt.
pagi1st start sa morning, typical diesel engine ang tunong--dinig mo rattling.. pero as it goes to its operating temp., about almost 1/2- of the guage.. unti unti din tumatahimik.
gusto ko lang i-clarify ung sabi ng casa sa akin: gun daw talaga diesel engine, kasi daw nagsisimula palang magcirculagte ang oil. tama po ba un?
or antay ko ang magiging resulta ng 1st pms nito next month (4 mo or 5000kms)
January 24th, 2012 11:05 AM #1566
sir dieseldude,
what's the function of this plug located at the rear of the injection pump? this is where the fuel leaks. mechanic installed another used one (with copper gasket & teflon). still leaks but to a lesser extent.
plug location at the rear
here's the injection pump by the way.
TIA
- Sep 2006
- 1,335
January 24th, 2012 12:44 PM #1568
- Sep 2006
- 1,335
January 24th, 2012 02:28 PM #1569
January 24th, 2012 09:06 PM #1570
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
