Page 41 of 118 FirstFirst ... 313738394041424344455191 ... LastLast
Results 801 to 820 of 2351
    Sep 2006
    #801
    Sir I got an Innova J D4D
    is that a water cooled or oil cooled?
    D4D engine is both water cooled and oil lubricated.
    what is the difference between the performance?
    I don't understand your question.
    as Page 1 of his thread shows oil is to lubricate, water is for cooling... so can the vehicle have both for it to function at its topmost....
    A car needs both these systems to function properly (cooling and lube system).
    Sep 2006
    #802
    Sir, as to when is the vehicle needs to be put unto calibration center? Diesel car owners normally have their engnes or diesel injection system checked when they notice irregular engine performance like: low power, black smoke, rough running, etc.
    what does a Calibration Center usually check and what do they really do to your engine - The calibration center works only on the engine's diesel fuel injection system..... not the engine.
    yes, to calibrate your engine thats why they are called calibration center - can you kindly, put it into laymans term/easy to understand why an engine needs to be calibrated... the engine is not calibrated.
    is it only diesel engine(s) that needs to be calibrated? Yes, only the fuel system of a diesel engine is calibrated. Gasoline engines don't normally require this service.
    * am just curious coz there are numerous calibration center am seeing here in my place - but most of them are fixin jeepneys not private cars, as to what I noticed... Where are you located?
    thank you... You're welcome. Feel free to ask if you have any more questions.
    #803
    oh i see... great to know...
    sir, what I meant in here is that... ex. the Innova is only water cooled; what is the difference between a 2.diesel water cooled and a 2.5 oil cooled
    great to know...
    tnx a lot...
    youre makin us very knowledgeable about Diesel engines on your thread...
    #804
    isnt there a necessary kilometer(s) run by the vehicle that requires the vehicle to be calibrated (ex. Change oil-mineral - every 5k kms); coz my Innova is already 70k kms. in Odo, yet performing at its topmost condition; I just dont want to lose its performance...
    honestly I am somewhat ashame to ask this, but what the heck, id rather ask this than remain innocent... isn't that diesel fuel injection system part of the engine?
    is it only diesel engine(s) that needs to be calibrated? Yes, only the fuel system of a diesel engine is calibrated. Gasoline engines don't normally require this service. but can a gasoline engined vehicle be calibrated?
    * am just curious coz there are numerous calibration center am seeing here in my place - but most of them are fixin jeepneys not private cars, as to what I noticed... Where are you located? Sir I am located in the first district of Laguna - Pacita Complex, San Pedro, Laguna...
    thank you... You're welcome. Feel free to ask if you have any more questions. thanks again... youre such a great help....
    Happy Holidays...
    Sep 2006
    #805
    Just like most engines, the Innova is oil lubricated. Oil lubricates the engine, and assists in cooling the engine. The engine needs both systems.
    great to know...
    tnx a lot...
    Sep 2006
    #806
    Change oil and other engine-related service intervals are stated in the owners manual. Diesel calibration service is not included on the service interval.
    honestly I am somewhat ashame to ask this, but what the heck, id rather ask this than remain innocent... isn't that diesel fuel injection system part of the engine? Yes it is. But it doesn't need to be serviced regularly as it is built to last. Diesel fuel injection systems often fail due to dirty and/or use of water contaminated fuel, or use of poor quality fuel filters.
    Yes, the gasoline fuel injectors can be calibrated as the need arises.
    Ooookay....
    Happy Holidays... You are welcome.
    #807
    tnx for clarifying...
    why do you happen to know this stuff, I believe youre a Mech. Engineer or something? or probably, do you own a calibration center?
    do you happen to know how much, would it cost for an Innova to be calibrated?
    can I just go to a calibration center, just to have my tsikot checked by them if it needs to be calibrated?
    tnx again...
    Sep 2006
    #808
    why do you happen to know this stuff? Because I have been in the field of diesel fuel injection for more than 30 years.
    I believe youre a Mech. Engineer or something? or probably, do you own a calibration center? View my occupation under Dieseldude's public profile.
    do you happen to know how much it would cost for an Innova to be calibrated? Cost depends on what's wrong with your Innova. Is there anything wrong with your car? You don't need calibration service if your car performs well.
    can I just go to a calibration center, just to have my tsikot checked by them if it needs to be calibrated? No. Not all calibration centers can service the Innova or any common rail diesel system. Only workshops which have fault scanning capability and common rail test equipment can do this service.
    tnx again... You're welcome.
    #809
    wow you got a long great work experience...
    do you happen to know how much it would cost for an Innova to be calibrated? Cost depends on what's wrong with your Innova. Is there anything wrong with your car? none, as of the moment.. hoping nothing would happen in the near future... You don't need calibration service if your car performs well. alright!
    #810
    Sir help po! kanina before ako umalis ini-start ko na yung sasakyan para uminit na yung makina, normal running for more or less mga 10mins bago ako umalis then mga about a kilometer pa lang yung natatakbo ko, biglang nanginig yung makina, naging palyado then pagnagre-rev ako, ang lakas ng usok (bluish gray) tapos humina ang hatak, bumaba ang rpm pero di naman namamatay ang makina, wala din problema sa starting. Bumalik na lang ako sa bahay at di na ako umalis baka kasi itirik ako. Ano po kaya ang problema? rotor head po kaya? (sana hindi naman). Possible kaya na injection pump? How about yung nozzle tip? Nagreplace kasi ako ng nozzle tip almost a month ago na, mausok at malakas sa diesel kasi before but after mapalitan yung nozzle tip, nawala yung usok, tumipid din sa diesel pero hindi nagbago ang batak. By the way, nakita ko naman po kung paano ni-replace yung nozzle tip, maayos at same code din yung pinalit, zexel po yung brand.
    Ride ko po, 97 Isuzu TFR 4JA1
    Thanks
    Sep 2006
    #811
    Quote Originally Posted by DieselDI View Post
    Thanks
    Try checking everything external like valve clearances, blocked air intake system. etc. But from experience, this seems to be an injection pump problem.... more specifically... the rotor head.
    Good luck.
    #812
    Dieseldude,
    Salamat po sa reply sir, pa-check ko na lang po yung injection pump ko next week. Sana di naman gaano kalaki ang damage.
    Dec 2009
    #813
    sir, may question lang po ako ulit..... R2 engine sa mazda e2000 body ano po kaya size ng piping ang kailangan? 1 3/4, 2inch or 2 1/4? saka pareho lang po ba ang muffler ng gasoline engine sa diesel? maraming salamat po...
    Apr 2005
    #814
    need help tech gurus,
    had experienced with my mazda friendee during cold start pumapalya ang makina parang kinakapos.fuel filter was replaced but still experiencing the same thing na pag malamig pa engine ay napalya.kapag mainit naman ang engine ay nawawala ang ang palya.kindly help.thanks
    Sep 2006
    #815
    Quote Originally Posted by msvan View Post
    Sorry, this is not my line.
    Sep 2006
    #816
    Quote Originally Posted by nitram View Post
    Gasoline engine I suppose?
    Dec 2009
    #817
    Quote Originally Posted by Dieseldude View Post
    ooops!!!! sorry po sir.... na excite lang ako kaya natanong ko sa inyo.
    sir, how about yung magnetic sensor na kinakabit sa injection pump for RPM? nakita ko po kasi 2wires siya.... isang black and isang red w/ black. alin po kaya yung sa positive and papuntang gauge? and yung papunta sa positive kailangan po ba sa ignition ang tap or direct sa battery mismo? maraming salamat po ulit....
    Jul 2006
    #818
    sir pwede mo ba ako ma bigyan ng estimate sa nozzle clean/replace at pump calibration para sa 1996 toyota townace(subic) 2C-Turbo ang makina. TIA
    Apr 2009
    #819
    sir dieseldude question uli.. (stupid question)
    nag stock ako ng petron diesel last month (early december).. then nung isinalin ko kahapon sa clear container napansin ko iba na color nya.. from greenish naging yellowish...
    pwede ko pa ba gamitin? sayang kasi kung itatapon 40liters din yun.. sa L300fb ko na lang ikakarga kung pwede pa...
    maraming salamat!
    Jun 2009
    #820
    sir, tanong ko lang kung ano ang part number ng injection nozzle ng hilander?
    thanks in advance
Diesel Fuel Injection System Help Desk
