Results 141 to 150 of 939
May 18th, 2006 10:15 AM #141
Shell's E10 is P39.20 when i tried it yesterday. Shell's super unleaded is P39.7+. Both are octane 93.
Engine runs a bit better, but consumes more fuel.
I hope I was of help.
May 18th, 2006 10:17 AM #142
That's it.
I'm not going to buy e10 anymore. It is totally impractical. I used 1/4 of my tank and I only got 100kms wherein usually I would get to 160kms with unleaded.
May 19th, 2006 02:28 AM #143
medyo OT: basta ako. . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . TECHRON!!. . . .hehehe!!..bias ba?!? hahaha!!
- Nov 2003
- 71
May 19th, 2006 09:49 AM #144Originally Posted by Mguy
May 19th, 2006 10:36 AM #145
Originally Posted by Jayo
when I was using SeaOil's E10 before, halos pareho lang ang fuel consumption ko.
- Feb 2006
- 20
May 19th, 2006 02:12 PM #146I think ethanol mix fuel is quite expensive since we are still importing it to other countries. Since they are still introducing in this country and maybe Shell still experementing if there really a market for this kind fuel in our country.
Our government should act to pass some laws and encourage local industries to built ethanol plant here, we have all the raw material ( sugar cane, cassava, corn and etc)
In Brazil and Australia they are already using 20% mixture in there gasoline.
- Nov 2003
- 71
May 19th, 2006 03:50 PM #147Originally Posted by mazdamazda
- Nov 2003
- 71
May 19th, 2006 04:28 PM #148Alcohol will raise the octane rating of gasoline, but at the expense of fuel economy. I've seen both ethanol and methanol used to dilute gasoline. Ethanol used to be employed in concentrations as high as 10 percent to formulate oxygenated fuel. ......as high as 0.3 percent are acceptable, and specifically permitted by most of the car manufacturers. Higher concentrations in vehicles not designed for alcohol can cause corrosion of metal parts wetted by fuel--things like the inside of the tank and the lines, and the pintle valve in the injectors. High concentrations of alcohol also can make non-alcohol-rated plastic parts turn to Jell-O in a few months.
Taken from this site. http://www.popularmechanics.com/auto...c/2240212.html
SiRaNeko
- Jan 2003
- 973
May 19th, 2006 08:59 PM #149Originally Posted by mazdamazda
di kya may effect yng octane rating? ang alam ko ang seaoil e10 unleaded e 95octane.
while me post sa taas na shell e10 has 93octane?
lotus elise all the way! 2004 edition
Lotus returns...
