Results 61 to 70 of 287
September 24th, 2017 10:31 AM #61
- 54,215
September 24th, 2017 11:39 AM #62i read somewhere, that these coolants are fluorescent. if the appropriate (UV?) light is used, the leak, even the small ones, can be more easily seen.
is this true?
- Dec 2016
- 16
September 24th, 2017 08:45 PM #63may nakita ako na prestone na color red sa ace hardware last week. tinatapatan ng UV light para makita leak. di ko masyado nabasa ano pinagkaiba ng red sa yellow coolant variant nila.
- May 2011
- 481
September 24th, 2017 08:51 PM #64
Not enough information.
Is the check engine light on when this happens? Is there a vacuum leak at the intake manifold?
Is the speedometer working?
Some GM cars have the speedo input to enable the cooling fan. Some, the radiator fans are pulse width modulated.
Any thing else not normal to the operation of the vehicle?
- Jul 2017
- 14
September 25th, 2017 08:46 PM #65Tnx 4 d reply sir jodski. Nakikita ko nga po sa harapan po basang basa po pero di po don sa taas
Sa may cap nanggagaling feeling ko since na buksan na sya di na ganoon na seal kaya nag leak. Hndi ko pa po natry palitan yung cap iyun pa rib po ung dati. Pag po ba pinalitan yung cap ano po ang possibilty na matanggal ung leak?
Tsaka po nag pa estimate po ko kung palitan na rad 5k daw ioorder pa raw po. Tsaka po pasingit na nga rin yung sa right side sa harapan ko pong shock may tagas na na langis palitin na rin 3.8k ang estimate. ano po sa say nyo po dun?
- Dec 2016
- 16
September 25th, 2017 11:34 PM #66Nakikita ko nga po sa harapan po basang basa po pero di po don sa taas
Try mo maglagay ng pansalo sa ilalim kung saan napatak yung leak, kung dumadami pagkatapos mo I garahe ang kotse mo, yung leak ay nasa ilalim.since sabi mo wala naman sa radiator cap.
- Mar 2010
- 4
September 26th, 2017 04:25 AM #67thanks for the response mina_nuka
re: check engine light
no, it wasn't lit. At least not until the fan was directly connected to the battery so it may be driven to wizzard's then back home.
re: vacuum leak
it wasn't checked in the shop (servitek), though I did check the oil cap and dipstick for signs of gasket trouble but they're clean. No vapors coming out either or anything that indicates gases are leaking into the cooling system.
re: speedometer
yes, it's fine at least when i drove it from servitek to wizzard's...already hooked up to battery. I'll drive it around just to check again. is there a way to find out if it's pulse width modulated?
other than the aircon not working again, there was nothing else acting strangely. i suspected a/c compressor issues but wizzard's didn't find anything wrong with it. their mechanic said the ecu/pcm isn't closing the ground. they wanted to remove the computer box and have it "repaired" by "someone in banawe". i'd really like to do my homework first before agreeing to that. by the way i've got the diagrams from the hayne's manual however i must admit i'm a noob with that.
any info would help in solving this "mystery"
nga pala, hammerl suggested checking out the coolant temperature sensor, it's never been replaced ever so i got a new one and will have it installed
- May 2011
- 481
September 26th, 2017 06:09 AM #68
September 26th, 2017 06:17 AM #69
pa piggyback lang mga bros...
normal ba na * 200k km, toyota coolant replaced every 2 years (after warranty); na di pa napapalitan or na repair ang radiator?
lagi kasi ako inaalok ng mga shops, kesyo need daw i overhaul kasi luma na; ok lang sana, kaso ang worry eh baka magka problema pa.
September 26th, 2017 06:33 AM #70
ilang years na bro? some toyotas really last long before that water pump fails or that thermostat. how does the used coolant loom like? malinis naman? if thw coolant is a premix-wala gaano rust.. some have rust kasi yun nga..distilled lng ang gamit... wala sya rust inhibitors..
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
