though may plastic divider yun batt terminals, thanks for the warning [emoji4]
btw re: thermoswitch (yun pala tawag dyan sa pic?)
weird lang kasi, 95c nag detected nya which should be within optimal temp range? dati kasi as far as 98c (hottest i was able to record), wala pa warning; bakit ngayon meron na? also at 95c dun lang nag kick in ang aux fan, why not at 90c or lower? and if this sensor is busted, why am i still able to see the coolant temp?
sensya na madami tanong, medyo nagtataka lang ako talaga.
As per your writeup, the engine is obviously not overheating. It is the overheat warning light that you are concerned with. Depending where your car was manufactured, the THW or CTS or the coolant temperature sensor feeds this information to the ECM and is forwarded to the body control computer or BCM and is given off as a signal to the IPC or instrument panel cluster.
Your car might have inter-computer communication problem or your CTS is giving wrong signals. Have your car scanned for communication or U codes. What you are doing is way too far from the possible cause. You might even have IPC problems. Be very careful of mickey mouse trouble code readers and dongles.
yan ang iniiwasan ko bro, yun bypass part. even when mang jorge suggested i just remove the thermostat, i insisted to install the new one (orig toyota).
btw yun sa thermoswitch, yun ba nasa pic? 3k orig brandnew eh, if 300 php lang replacement and good for kahit 1 month bili ako just to test; but where can i source them?
With all due respect to manong jorge, stay away from macgyver style or approach. This is where the fine line lies between technicians and anecdotal mechanics
To test, you need:
A good reliable thermometer
A digital multimeter
A sauce pot of at least 1 quart capacity
A stove
1/2 quart water
Two wires with connectors for the sensor terminal
Connect the thermoswitch to the wires and connect to a digital multimeter in Ohms range or continuity mode.
Submerge in water in the pot as the water is being heated
Note the temperature at which the resistance in Ohms is zero or close to zero or the continuity mode beeps.
(MITSUBISHI recommends doing this in hot oil -which is a fire hazard)
What is the mileage? Red LLC is good for 150k and by the looks of the sensor, its silted. Could be a busted pump impeller the water is not circulating well and causing heat spots in the engine.
WPump Aisin for 1.3 is arnd 1.2k while for the 1.5 GNB arnd 1.5k and 2.5k for the Aisin.
If the computer can't read the problem for you, you are down with doing basic elimination method which will costs you time.
bro ano yun red LLC?
mileage is 221k km
btw bro, yun aisin and GNB water pump price, thats for vios na? palitan ko nalang din kaya since wear and tear naman ito, if OK pa condition atleast may reseba ako.
kasi nung mag inquire ako sa mga tao sa banawe parang 4k daw yun plus 2.5k labor O_o
palitan mo na yun water pump. with 221,000km+
thats over 10,000hrs already on the bearing if the aveage speed is 20kph.
salamat bro! watching vids online, i think kailangan ko pagawa sa mechanic muna; para makita ko paano pasukin LOL
pero mukhang kaya DIY after ko makita pano baklasin hehehe
btw found this thread in vcp .. not exactly the same issue but close
Login
author=jcboy link=topic=40695.msg927223#msg927223 date=1414676153
Go with the cheapest route ALWAYS. (well as much as possible)
1) replace with original Radiator CAP --often neglected.
2) replace thermoswitch --original as what has been mentioned, since aftermarket thermoswitches are not calibrated with OEM specs (degrees Celsius when opening), let alone racing thermoswitches have a lower "open" temp.
3) replace thermostat --or just check it. rarely do thermostats break down. siguro 10-15 years is the average lifespan sa mga nasisiraan nito, pero of course 7-10 years pwede mo na siguro palitan.
4) check/replace rad fan --minsan kahit umiikot hindi na pala ganun kabilis/kalakas, kaya you need to have 2nd opinions kung kumusta ba pagikot ng rad fan mo.
5) replace radiator --minsan barado na pala sa ilalim kaya hindi umiikot tubig. yung kalawang kasi ng radiator sa ilalim nagaaccumulate. kaya minsan kahit malinaw pag sinilip sa butas yung water/bakal na fins nya, nagooverheat ka pa din. yun pala hindi nakakadaan yung coolant/water.
6) head gasket --ayan tinamad na ako, so pag the 5 steps do not seem to work, paconsult mo na sa trusted shops.
HTH.author=deathscythell link=topic=40695.msg927408#msg927408 date=1414994054
Maraming salamat mga sirs. Lahat nung mga suggestion nyo chneck namin - ok nman. Ni-trace din namin ung mga dinadaanan ng tubig baka may leak pero wala naman. Before kami dumiretso sa head gasket (kasi mahal daw kapag kinalas un) chneck muna nmin water pump and ayun, water pump daw yung sira. Nung ni-replace nmin nag-ok na. Dagdag kaalaman.
Thank you ulit mga sirs.
*Ninja
Note lang. Yung belt kelangan tama ang pagkabalik / higpit kung mag diy ka.
found this pricing too ..
sana di malayo sa 2015 price ..
Login
author=jeffman link=topic=41830.msg939375#msg939375 date=1432361702
Aisin Clutch Disc + Cover
1NZ 1.5L = 2,600 pair
2NZ 1.3L = 2,500 pair
Aisin Water Pump
1NZ 1.5L = 900 each
2NZ 1.3L = 900 each
KYB Gas Shocks
Robin Front = 2,500 each
Robin Rear = 1,400 each
Batman Front R =2,950 each
Batman Front L = 2,950 each
Batman Rear = 1,500 each
MKK Brake Pads
Robin Front = 600 set
Robin Rear = 500 set
Batman Front = 700 set
Batman Rear = 500 set
Destination charges may apply
