Page 4 of 15 FirstFirst 1234567814 ... LastLast
Results 61 to 80 of 287
    Sep 2012
    #61
    Quote Originally Posted by jdotxx View Post
    Makiki ride na po dito sa thread, nag pa overhaul po ako last July ng rad ko tapos napansin ko na nabawasan yung coolant ko sa reservoir check ko po meron leak sa rad ko. Ayaw ko na po ibalik don sa pinag paoverhaulan ko para ipabaklas pa ulit. Balak ko na po na palitan na lang ng bnew. Di naman po ako lumalayo layo dito dito lang ginagamit yung auto. May masasuggest or refer po ba kayo saan ako pwede makapag canvass ng mga radiators and thermostat? Toyota BB po ride ko. Salamat po.
    Wala ka nakikitang visible leaks na kakulay ng coolant mo?
    Have you already checked or replaced your radiator cap?
    Find out mo muna kung saan nag leak. If wala makita then next suspect mo na madali gawin is replacing the radiator cap...
    #62
    i read somewhere, that these coolants are fluorescent. if the appropriate (UV?) light is used, the leak, even the small ones, can be more easily seen.
    is this true?
    Dec 2016
    #63
    may nakita ako na prestone na color red sa ace hardware last week. tinatapatan ng UV light para makita leak. di ko masyado nabasa ano pinagkaiba ng red sa yellow coolant variant nila.
    May 2011
    #64
    Quote Originally Posted by mulawin00 View Post
    (Chevrolet Venture LS 2003, V6 3.0li Gas)
    Overheating Chevy Venture...
    never had a problem regarding this until about years ago.
    1) the Radiator, Radiator Cap, Water Pump, Thermostat are now all new. Recently flushed and coolant (Shell Reco-cool) replaced
    2) both Cooling Fans (driver side and passenger side) are now all new, including the Underhood Fuse/Relay Junction Box who's terminals burnt out (the new one burned also, apparently a design flaw...resolved by soldering the failed wire directly on the pin)
    3) A/C Compressor (Delphi) was replaced 2 years ago and should be still be relatively "new"
    These worked for a while until recently when it began overheating again!
    Wizzard recommended getting the ECU/PCM checked by "someone in Banawe" coz they find nothing wrong with the wiring. Apparently the computer is not closing the ground on the relay.
    They temporarily setup up a toggle-switch that directly hooks up the power from the battery to the driver-side aux fan so I may drive the van and not need towing. It works but of course the "Check Engine" warning light switched on.
    Has anyone encountered a similar problem before???
    Not enough information.
    Is the check engine light on when this happens? Is there a vacuum leak at the intake manifold?
    Is the speedometer working?
    Some GM cars have the speedo input to enable the cooling fan. Some, the radiator fans are pulse width modulated.
    Any thing else not normal to the operation of the vehicle?
    Jul 2017
    #65
    Quote Originally Posted by jodski View Post
    Tnx 4 d reply sir jodski. Nakikita ko nga po sa harapan po basang basa po pero di po don sa taas
    Sa may cap nanggagaling feeling ko since na buksan na sya di na ganoon na seal kaya nag leak. Hndi ko pa po natry palitan yung cap iyun pa rib po ung dati. Pag po ba pinalitan yung cap ano po ang possibilty na matanggal ung leak?
    Tsaka po nag pa estimate po ko kung palitan na rad 5k daw ioorder pa raw po. Tsaka po pasingit na nga rin yung sa right side sa harapan ko pong shock may tagas na na langis palitin na rin 3.8k ang estimate. ano po sa say nyo po dun?
    Dec 2016
    #66
    na check mo na yung drain plug baka dun leak mo?
    Try mo maglagay ng pansalo sa ilalim kung saan napatak yung leak, kung dumadami pagkatapos mo I garahe ang kotse mo, yung leak ay nasa ilalim.since sabi mo wala naman sa radiator cap.
    anong ibig mo sabihin na nabuksan na? na overhaul ba ibig mo sabihin?kung oo, dapat sealed na radiator mo kasi narepair na leak sa radiator mo.
    pag pinalitan mo sir yung radiator cap at kung doon nangagaling po yung leak mawawala na yun.
    palit shock absorber? palit ka pareho sir, baka masira na din yung kabila kung may sira na yung isa para isang gawaan nalang
    #67
    Quote Originally Posted by mina_nuka View Post
    thanks for the response mina_nuka
    re: check engine light
    no, it wasn't lit. At least not until the fan was directly connected to the battery so it may be driven to wizzard's then back home.
    re: vacuum leak
    it wasn't checked in the shop (servitek), though I did check the oil cap and dipstick for signs of gasket trouble but they're clean. No vapors coming out either or anything that indicates gases are leaking into the cooling system.
    re: speedometer
    yes, it's fine at least when i drove it from servitek to wizzard's...already hooked up to battery. I'll drive it around just to check again. is there a way to find out if it's pulse width modulated?
    other than the aircon not working again, there was nothing else acting strangely. i suspected a/c compressor issues but wizzard's didn't find anything wrong with it. their mechanic said the ecu/pcm isn't closing the ground. they wanted to remove the computer box and have it "repaired" by "someone in banawe". i'd really like to do my homework first before agreeing to that. by the way i've got the diagrams from the hayne's manual however i must admit i'm a noob with that.
    any info would help in solving this "mystery"
    nga pala, hammerl suggested checking out the coolant temperature sensor, it's never been replaced ever so i got a new one and will have it installed
    May 2011
    #68
    Quote Originally Posted by mulawin View Post
    re: vacuum leak
    re: speedometer
    There are four versions of 2003 Chevy venture.
    Base
    LS
    LT
    Warner Bros. Edition.
    What is your VIN? At least the first eleven characters.
    #69
    pa piggyback lang mga bros...
    normal ba na * 200k km, toyota coolant replaced every 2 years (after warranty); na di pa napapalitan or na repair ang radiator?
    lagi kasi ako inaalok ng mga shops, kesyo need daw i overhaul kasi luma na; ok lang sana, kaso ang worry eh baka magka problema pa.
    ilang years na bro? some toyotas really last long before that water pump fails or that thermostat. how does the used coolant loom like? malinis naman? if thw coolant is a premix-wala gaano rust.. some have rust kasi yun nga..distilled lng ang gamit... wala sya rust inhibitors..
    #71
    11 years na next month yun auto
    nung pinalitan 1 1/2 years ago bro, OK pa daw coolant ko sabi nung mechanic. sabi ko palitan parin namin since, 2 years ago pa last replacement (last time). now, ok pa; pink na pink pa naman nasa reservoir
    sa radiator cap ang tignan pag malamig... silip lng😉
    #73
    will do bro, thanks!
    Sep 2017
    #74
    The radiator fan of my Honda City VX 2014 is not working which caused my car to overheat 3 days ago. Sadly, my 3 year warranty just lapsed 4 months ago. Meaning, I would have to shoulde the cost. Badtrip!!
    I live far from a Honda service center -- so I asked the nearest Shell gas station for an estimate. Per the mechanic, original Honda raditor fan would cost around ~P14T. But he said that I can instead buy a brand new Japan radiator (Denso) in Banawe for about P7K and they (Shell mechanic) can install it for P400 labor.
    Any City onwers here experience with their radiator fan not working? What did you replace it with & how much.
    Thanks in advance for the help.
    IM2017
    #75
    Quote Originally Posted by IM2017 View Post
    IM2017
    check first, if the fan is definitely the culprit. baka yung ibang piyesa na nag-a-activate ng fan, ang prublema.
    May 2011
    #76
    IM2017
    Most Honda cars have the radiator fans switch normally open (N.O.) and closes when the threshold had been reached. To eliminate possibilities , unplug the radiator fans switch at the bottom of the radiator and jumper with a paper clip ( with the ignition switching the ON position). The fan should run at full speed,if not, check the rad fan relay or the fan motor. This time, unplug the relay and jumper (with a fused jumper wire)between the two larger female terminal of the relay block where you unplugged the relay. If the fan still won't run, the motor is probably bad.
    Dec 2017
    #77
    Good afternoon, I am seeking assistance from you guys to solve the issue I'm experiencing with my Nissan Urvan model 2009 (UV express). Since the van is experiencing high pressure recently, we brought it to our mechanic, he then performs the following on consecutive days, 1) Removed the Thermostat but still there is high pressure; 2) replaced the water pump and fan blade with brand new ones but again still high pressure while running; 3) cleaned both the radiator and sub radiator but last night my driver called and told me again there is high pressure, he then turn off the engine check the radiator (still full and no water leakage). He restarted the car after a few minutes and it became normal until he finished his duties. Any ideas what other possible factors that causes the high pressure? thanks a lot.
    Aug 2009
    #78
    Quote Originally Posted by Dohabibi View Post
    Check the radiator cap boss baka it needs replacing...
    Feb 2009
    #79
    It couldn't have "higher pressure". The radiator cap that relieves the built up hydrostatic pressure couldn't get stronger but the other way around. Maybe, what you're trying to say is that the temperature is higher.
    Your rad cap is designed to open at 0.9 kg/sq.cm or roughly 13 psig.
    If your situation is overheating, try bleeding your cooling system.
    Oct 2016
    #80
    What are the signs of radiator hose replacement? Thanks!
    Sent from my SM-G930F using Tsikot Forums mobile app
Radiator / Overheating Problem
