Page 10 of 15 FirstFirst ... 67891011121314 ... LastLast
Results 181 to 200 of 287
    #181
    if the thermo$witch ha$ no moving part$ outside, cleaning it$ outside$ won't amount to much.
    good luck, $ir.
    we await the blow by blow.
    sa loob yun linisan ko bro, dun siguro sensor part
    that dulo on the left, is the sensor.
    #183
    Clean with vinegar or dab of Turco, if still not clean use industrial grde hcl acid. The silting on the cover numbs the sensor w/c is just usually a thermistor wrapped in polymer.
    May 2011
    #184
    seems like everybody is helping you chase your tail.
    check the voltage at the dlc3 terminal. see link:
    Getting Started with OBD-II - learn.sparkfun.com
    it is more than likely communication problem. please, give it a try and provide voltage readings after the test.
    no offense to anybody trying to help.
    Jan 2010
    #185
    what are the colors of the wire insulation connected to this component? is it a sensor or is fan thermo switch?
    tip looks fine..
    #187
    Quote Originally Posted by barako ba ma View Post
    fan thermoswitch bro if niremove aandar na aux fan , no more auto ON? tama ba?
    May 2011
    #188
    engine coolant temperature sensor (ECT) will have pink wire on terminal 1 and light blue on terminal 2
    ALLDATA
    on this one, the fan does not run when you unplug this sensor. this is, a negative temperature coefficient resistor or a thermistor (NTC resistor). unplugging it will simulate the coolant temperature is below freezing
    this link has a very short shelf life. open link, print the information ASAP
    #189
    Quote Originally Posted by mina_nuka View Post
    ALLDATA
    humihingi ng username and password bro.
    #190
    new water pump, OK pa yun luma. pinapalitan ko narin since nabili ko na prior to going to exalta banawe.
    wear and tear naman ito no? pwede reserve nalang yun luma?
    May 2011
    #191
    #192
    your old pump still looks practically new.
    it must be those new coolant formulations.
    the trick now is, how to store that new pump, so that by the time you need one years from now, you still remember where you tucked it....
    you know.. the old "i know i have one somewhere here... now where did i put it... that was back when hindi pa ako grandfather...?" heh heh.
    or, go back to the store and exchange it for something else.
    #194
    installed na yun bago bro. meron naman akong old stash closet, minsan kasi may tsamba na may kailangan or need ko ulit. pwede ko rin post sa o l x hehehe
    Mar 2004
    #195
    We won't really know the condition of the water pump motor ... Until it conks out ... So replacing it early is a good thing to do ...
    #196
    mga bros, any idea alin mas malakas dito sa dalawa?
    any ideas what the numbers mean?
    looks are ok, but how about the bearings? these can sieze up over time.
    Tingin ko pareho lang eh. Piliin mo na lang mas mukhang bago. That is if both are legit.
    Nov 2018
    #199
    typical po ba mga size ng waterpump ng sasakyan?
    May 2011
    #200
    If it fits and mounts directly to the fan shroud it should be okay. Try running it direct to the battery and measure the current draw and compare. If the current draw is higher you might need to change the wire size to carry the load without overheating the circuit
Radiator / Overheating Problem
