Page 7 of 15 FirstFirst ... 34567891011 ... LastLast
Results 121 to 140 of 287
    Apr 2014
    #121
    *ninja
    Nagbabawas ba nang coolant or may leak sa sahig? If yes, sign of water pump failure yan.
    I forgot how much it cost for water pump replacement since it was a mere decade ago.
    #122
    Quote Originally Posted by chronicle View Post
    *ninja
    wala naman nagbawas bro. pero kahapon kasi nabanggit lang dun ng mga tumingin.
    Oct 2018
    #123
    Quote Originally Posted by misterioman View Post
    Problem: Laging nauubos yung coolant sa reservoir tank. No leaks sa hoses, tank, connections. Operating naman yung radiator fan.
    So, kahit after 15 mins na naka idle, Aircon ON, night time, tumataas pa rin ung needle ng temperature. then, mauubos yung Coolant.
    Do you think water pump yung problem (no circulation ng coolant)?
    Pag binuksan ung cap ng radiator, vapor ng coolant ung lumalabas after sometime na pinatay yung engine.
    Sent from my SM-J700F using Tsikot Forums mobile app
    sir, maraming possibilities yan, either marumi na at hirap na flow kaya may overheating or pdeng sa water pump din or within sa engine na mismo. critical na part yan so better have it checked para ma identify talaga
    Dec 2013
    #124
    Any of you guys have an idea how long an engine can run without coolant before it overheats? The plastic drain plug of my radiator is broken/leaks and the radiator cannot hold water in longer than 3mins(parang gripo talaga). Sad thing is the plug broke in two such that half of the screw is stuck inside(handle broke off) so i cannot plug the leak...not sure kung aabot pa sa shop mga 20mins away and i dont want to risk overheating the car. Thanks!
    Apr 2014
    #125
    Quote Originally Posted by n_spinner06 View Post
    Only a few minutes. Swerte na 5 minutes.
    If you go fast, then it can still run. But then chances of damaging your engine is pretty high if itatakbo mo pa.
    Have it towed.
    Jul 2013
    #126
    Use those clay-like leak plugs or quick-dry epoxy (steel) to temporarily seal the drain plug. Kung may radiator cap, alisin mo muna papuntang shop para hindi mag-build up ang pressure.
    #127
    may pic ka bro?
    baka makuha sa epoxy 5 or yung epoxy plug; since malapit lang naman gusto mo takbuhin
    Mar 2004
    #128
    Any of you guys have an idea how long an engine can run without coolant before it overheats? The plastic drain plug of my radiator is broken/leaks and the radiator cannot hold water in longer than 3mins(parang gripo talaga). not sure kung aabot pa sa shop mga 20mins away and i dont want to risk overheating the car.
    It will just take 3-5 minutes for the engine to overheat ... What you can do is drive to the shop 3-4 am ... Stop every five minutes and let engine cool for 30 minutes then drive again another 3 minutes and let it cool 30 minutes ... Repeat until you reach the shop ... Or you can try to refill the radiator every 2 minutes but it would be risky and you might get scalded ...
    Or you can have mechanic do home service and remove radiator then bring to radiator repair shop ...
    Had car towed on flatbed before for 1,500 to fix a broken hose worth 80 pesos plus 300 labor ...
    Jul 2013
    #129
    Most drain plugs are made of plastic. Kung ganun ang sa sasakyan mo, on the spot, pwede mo mapasikwat sa isang mekaniko yun.
    Jan 2013
    #130
    Not a mechanic here. Naisip ko lang, kung may butas radiator mo, and your only goal is to bring it Sa talyer, di kaya pwede yung mga pantapal na heat resistant, Yung parang tape na parang foil. Pansamantala lang. Para madala mo sa mekaniko.
    Na putulan ako dati ng throttle cable sa old pajero ko. Nasa hiway ako nun. Dinugtong ko muna yung cable using para cord para lang mauwi yung kotse.
    Sent from my ONEPLUS A3000 using Tapatalk
    if you have a pair of long nose pliers, you might be able to reach for the broken part and screw it out. then you can screw in a brand new drain plug.
    Dec 2013
    #132
    Quote Originally Posted by remzam View Post
    Thanks dr d and remzam. Sourced a new plug and used a small flat screwdriver to remove the old plug successfully albeit with great difficulty..ang sikip kasi and mahirap maabot. Nonetheless ok na ulit.
    Jun 2008
    #133
    vios 2006 (gen 1.5/1.3 L).
    mga bros, temp warning light came up.
    even when aux fan is running, i still get the temp warning in dash .
    no recent change in the system naman, except for brake pad change about 1.5k km ago and lugnut stud issue the other day.
    had it checked in jpwheels yesterday, was told that it was a bad fan, their comment was mahina daw. then went to exalta banawe, they said fan looks OK, as well as the water pump and no leak in system (cap also OK); since they could not identify the problem, they can only recommend to have the radiator checked and/or cleaned.
    then i realized, i can check the temp via obd scanner, so i did. from banawe to maybunga pasig, temp never went over 98c (prolly cause it was 5:30pm narin). will update my post later around 12nn.
    dati until about 98c (or 100c IIRC) ang inaabot ng coolant temp ko sa obd scanner reading via torque app.
    ngayon 90c or lowest * 88c nag blink na ang temp warning sa dashboard. issue just started yesterday. naka toyota long life coolant naman, was replaced just about less than 10k km.
    at first i thought it was a bad coolant sensor, but i can read naman via obd scanner that coolant temp is fine, so baka di naman sensor. any ideas kung ano pwede problem?
    btw AC works fine even when the temp warning came up.
    I'd go with dr.d here.. Change the aux fan.. Minsan kasi ang nangyayari sa Aux may time na kung kailan mo i-check eh gagana yan at may time na biglang titigil o babagal kapag hindi mo ni-check..
    Jun 2008
    #134
    Quote Originally Posted by scatmanAE92 View Post
    Sir, kung ako sa sitwasyon mo ipa-home service ko na lang sasakyan ko kesa ibiyahe ko.. Mahirap isapalaran yan.. Bilis uminit nyan..
    #135
    Quote Originally Posted by ChoyJo View Post
    that is # 4 sa to change list ko bro LOL
    water pump is # 3
    already done with 1 and 2 (clean rad and change thermostat)
    tamang tama mainit byahe ko today from cubao to market market then pasig.
    thats probably an hour and a half of driving.
    gusto ko nga sana no AC para ma testing ko talaga yung fan eh LOL
    Dec 2017
    #136
    water pump is # 3
    You might want to check the thermoswitch. I think this is the one sending the signal when to turn on and off the auxiliary fan.
    #137
    where is it located bro?
    update again ..
    AC off ..
    confirmed automatic fan turns ON * 95c
    but seems too late as by 96c, temp warning light turns ON already.
    #138
    tried cleaning this with wd40 then brake cleaner
    nada
    still triggers the fan to run * 95c with temp warning ...
    how to set the aux fan to run at maybe 88c? [emoji848][emoji848]
    #139
    nada
    Ummm...a new 1? Or hobo tweaking....bypass it w/ a manual switch or full time service?
    Oct 2009
    #140
    bypass .rekta ibig bang sabihin...pano na ung cold start
    try mo muna palitan 300 lang bili ko sa ganyan...
Radiator / Overheating Problem
