Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 287
    Oct 2013
    Problem: Laging nauubos yung coolant sa reservoir tank. No leaks sa hoses, tank, connections. Operating naman yung radiator fan.
    So, kahit after 15 mins na naka idle, Aircon ON, night time, tumataas pa rin ung needle ng temperature. then, mauubos yung Coolant.
    Do you think water pump yung problem (no circulation ng coolant)?
    Pag binuksan ung cap ng radiator, vapor ng coolant ung lumalabas after sometime na pinatay yung engine.
    Sent from my SM-J700F using Tsikot Forums mobile app
    problem: what is your car, po?
    you are probably over-heating.
    1. is your radiator dirty, inside and/or out? are there deposits on the inside, that hinder heat exchange? are your cooling fins covered by dirt and grime on the outside? subukan nyo pong pa-linis ang labas ng radiator nyo. i would recommend engine overhaul, but by your picture, mukhang plastic ang radiator tub ninyo...
    2. is your radiator fan electric? if so, perhaps it is not turning as fast as it should. if so, replace it.
    3. how's your exhaust? kung medyo puti, that's probably tubig. you may have a gasket leak, causing coolant to be lost thru the combustion chamber.
    good luck, po.
    correction po. radiator overhaul, hindi engine overhaul.
    if only to save money. otherwise, radiator replacement.
    Sep 2005
    Dalhin mo kay Jorge sa Banawe katabi ni Jemson..
    Jul 2013
    Start with the simplest solution. Radiator overhaul.
    At the same time, ipa-leak test mo yung piston/cylinders mo. Baka may problema sa head gasket.
    What car/vehicle make po?
    Sent from my 5015E using Tapatalk
    Oct 2013
    Sorry, di ko na lagay yung model.
    Avanza 2010 1.5G AT
    Yung angle na water pump yung culprit, d ba realistic mga sirs?
    Also, would you advise na ibyahe ko sia (from Makati to any talyer or ipahome service na lang)?
    Jan 2009
    The thermostat valve might be stuck or does not open completely when the engine has reached the correct temp.
    How to Determine If a Car's Engine Thermostat Is Stuck | AxleAddict
    Quote Originally Posted by misterioman View Post
    Avanza 2010 1.5G AT
    What do you mean "angle ng water pump"? How did you determine that the water pump is the culprit?
    Since you said earlier, 15 minutes lang na engine idling eh na-overheat na, mas better pa ipa-home service mo na lang. Rather than having get stuck in a traffic going to your preferred talyer, baka maitirik ka sa daan due to overheat.
    Insufficient water/coolant runs in your engine cooling system will result to engine overheating. Kung nagbabawas ng coolant/water ng mabilis sa radiator, it means may leak.
    Have you checked or inspected your radiator drain plug lately? Baka maluwag at kailangan lang higpitan.
    Jun 2005
    +1 on the thermostat. My guess its stuck
    Next is rad cap.
    Ask you mechanic to remove the thermostat. If it doesnt overheat anymore, go buy a new thermostat.
    That is assuming your fan is working
    Mar 2017
    The leak could be anywhere. Radiator, hoses, reservoir, water pump, or heaven forbid the engine block. The last time I had a cooling system problem, my mechanic sent me to Keyser in West Avenue QC. Wasn't cheap, but they looked at everything before they gave me a diagnosis and estimate, which was exactly the same as my mechanic's diagnosis.
    May 2011
    Quote Originally Posted by sirkosero View Post
    Next is rad cap.
    Not all liquid cooling systems are the same. If the car has a three way thermostat, it will overheat even if it did not with a working thermostat removed. Read the description and system operation in the repair manual if you have one.
    Jan 2009
    Quote Originally Posted by mina_nuka View Post
    I doubt that the Avanza has a three-way valve.
    Jun 2005
    Ditto.
    Its an avanza. Dont think its cooling system is anywhere near fancy
    May 2011
    Not familiar with the engine used in the avanza but do you have pictures of the thermostat?
    May 2011
    What was the last thing performed to the engine that might involve the cooling system?
    Ās per this diagram
    toyota avanza thermostat - Google Search
    The system should have been bled at two places if at any point the coolant was low or was drained and refilled
    Oct 2013
    Ās per this diagram
    Last thing na ginawa ko for cooling system is nagchange ako ng motor ng fan ng radiator last year
    May 2011
    Before doing anything or having anything done to it, top off with antifreeze/coolant and bleed the system
    Jun 2007
    Sira na siguro cap ng radiator or worn out na upper radiator hose.
    why do radiators explode (or sumasabog as a fellow tsikoteer describes it in the other thread ) during hard driving ?
    given our fellow tsikoteer's rig was already long in the tooth (pajero fm), why did its radiator explode while traversing the tplex at a high speed? and wouldn't it have shown some symptoms or tell tale signs before it gave way violently?
Radiator / Overheating Problem
