Results 201 to 210 of 1447
- May 2011
- 2
May 31st, 2011 02:47 PM #201I have a 1998 Toyota Revo, all stock. Medyo nabababaan ako. Pwede bang i-modify yung suspension nito (or something else) to lift the whole body up? Not too high naman. Gusto ko lang medyo mataas ng konti. Pwede kaya yun?
- Nov 2010
- 57
June 2nd, 2011 01:14 PM #202hi saan pwede mag download ng manual para sa revo?GLX gas po sa akin.
saan rin po maganda mg pa cleaning ng aircon natin?salamat!
June 2nd, 2011 11:45 PM #203
- Apr 2008
- 6,235
June 16th, 2011 12:13 PM #204Can't seem to find the right thread so dito na ako tatanong. Nakakahiya to, we have a 2001 Revo GLX diesel, naubos ang laman sa rear window washer niya. Ire-refill ko sana pero hanap ako ng hanap pero hindi ko makita ang reservoir.
Nasaan ba yan?
June 16th, 2011 08:50 PM #205
- Apr 2011
- 588
June 17th, 2011 07:05 PM #207
Dati naka 16 inch rim yung ride ko, kung 55 series na gulong matagtag ng konte, ok kung 60series pero kung mataas pa sa 60 series naman malaki na masyado, lalo na cguro ang 17inch, matagtag na low profile karamihan ng 17inch na mga gulong, maporma tingnan kung naka 16-17inch ka, pero kung masakyan ng seating capacity yung revo mo matagtag na, at hirap sa arangkada kung ganun size ng rims, maginhawa sa ride mo kung talagng 14inch ok pa cguro kung gang 15inch, its my opinion, its your choice pa din sir
- Apr 2008
- 6,235
June 18th, 2011 03:09 PM #208
June 18th, 2011 06:26 PM #209
- Apr 2008
- 6,235
June 21st, 2011 12:27 AM #210Kapag ganun hindi na. I'm not good with DIY and I might bust even the front washer if try to make kalikot-kalikot. At least the wiper works.
But I have a more serious problem and that is smoke belching. It doesn't seem to go away despite all my efforts to do away with it. I've changed all the oils, cleaned the air filter, replaced the fuel filters and cleaned the exhaust. But in the end, even if the engine did run smoother and the smoke did lessen, the smoke is still very intolerable. It immediately shows that once I get to about 3000rpm there will be a thick cloud of grey smoke at my rear. Any suggestions?
It helps that the three generations of the leaf share the same battery formfactor and can use the...
2021 Nissan Leaf
