To 1RZ-E Revo owners - Saan ang diagnostic link connector (DLC) nang Revo? OBD1 ba or M-OBD or OBD2? Di ko sure if siya yung nasa likod nang battery sa engine bay, or kung nasa ilalim nang passenger seat na naka piggy back sa TVSS... Help naman. Kung meron maka post nang picture, malaking tulong po.
I'm looking for Toyota Revo VX 240D. Anyone selling theirs?...saan po ba pwede makahanap na sariwang VX240D? preferably manual. Thanks
All diesel Revo's are manual. The VX240D seems extremely rare in the 2nd hand market. The best place to look online is still Sulit. The most frequently updated ads are there, and it has the most choices. The lower diesel variants are about just as good with only a few additional features and paint jobs being the only differences
Sent from my GT-I9100 using Tapatalk 2
Hi guys. I just bought the REvo of my mom. It is 2003 GL. The problem is she doesn't keep track of the maintenance and repairs. What should I initally do? Is it okay if I do the following as percautionary measure or oa naman ako sa mga gagawin ko?
1. Change Oil
2. Change Spark Plugs
3. Wheel & Camber Alignment
4. Change Air and fuel filters
5. Change Radiator Coolant
6. Change Belts (What belts do I need to replace?)
7. Change Radiator Cap
8. Check radiator hoses for Leaks and change if necessary
9. Change the gear oil
Do you have the estimated prices for each part / service and where is your recommended shop / store?
Sorry madami po tanong. I am not in the Phils. kasi and para mabudgetean ko kasi balak ko sana ipagawa yan when I go home April next year.
Thank you to all those who will answer and help.
Guys just ignore my post above as I already has the answers.
I have a new question.
Since I am planning to store my car for 6-8 months, will disconnecting battery bring issues to my 2003 Revo GL? I read somewhere that some computer memory will be lost and will need some sort of security code.
So far I only have an aftermarket alarm and aftermarket Kenwood Headunit.
What is your take guys? Thanks.
Tama yan, if you're leaving for a long time at wala kang mapag-iiwanan, just disconnect the negative battery terminal, about thun sa sinasabi mong mag-rereset....yun samin hiniram ko yung battery, then pagsalpak ko ulit, wala naman problema, wala naman atang ganon ang computer box ng revo...yun nga lang you need to adjust the time on the dashboard again.
Mga boss, anong brand and part number ng oil filter, air filter and fuel filter for Revo with 7KE engine? Thanks
mga sir, nadisgrasya po yong revo namin last week. sino po merong mga parts sa front like front grill, fog light at bumper? 2003 model po revo namin. sana matulungan nyo ako. please contact me 0949 767 3196 kung may alam po kayo, need your help po. thanks
Any estimates on how much pwede ko ibenta ang Revo ko na 1999 GL MT w/ 75k mileage? Thank you.
diesel is probably more desirable now, than gas.
and to the average used buyer, cosmetics counts a very lot.. how beautiful is the car's make-up?
and forget sentimental value.. that's not in the buyer's dictionary.
try looking up the used car addresses in the internet. but remember that these are the asking prices, not the going prices.
good luck.
Sirs san kaya ako maka bili ng gas float ng revo ko dlx 99 model.ang dami ko na napuntahan puro three terminal type with sensor ang binibigay, need ko two terminal type hindi kasi lapat, hirap na ako hanap ng replacement parts
sir, i ask you to consult a qualified technician.
a number of spare parts are improved or modified over the years to accomodate new developments. but these improved parts may still function in older models. for example, i recently had to replace my starter solenoid. the replacement part they were showing me had its terminals different from the old unit it was replacing. what we did, was to simply rotate it 180 degrees and voila...
is it possible that the three-terminal model just needs to have one terminal bent, so's it will fit?
new owner po ng vx200 here. ask ko lang po kung may nabibili bang replacement casing ng keyless remote? basag na kasi yung sabitan nung nabili ko. mayron sa sulit kaso 3 button may panic sa ilalim, yung nakuha ko kasi 2 buttons lang? tia
thanks sir. mine is 2 buttons. jurassic style kaya walang mahanap hehe. wala pati dun sa kiosk sa mall. yung pangtrigger ng on/off gamit lang yung top button. based on the manual, the other button maybe used to other toyota car after programming. anyway hanap hanap muna. ano pala usual na consumption nito? parang 4km/l lang yung nacompute ko sa unang pa gas although hindi full tank method
