Results 1,201 to 1,210 of 1441
- Apr 2008
- 6,237
September 28th, 2017 11:16 AM #1201
- Jan 2017
- 29
September 28th, 2017 01:35 PM #1202Sana battery lang. pano ba majustify na dying na ang battery. Actually under warranty pa yung battery. Kung during cranking is bumaba ang voltage below (12V) will that qualify as dying and pwede pa warranty.
- Aug 2017
- 37
September 29th, 2017 02:41 PM #1203not necessarily, the battery voltage can go as low as 9 - 10 volts during cranking and should return above 12 volts after starting. you should also check connections and terminals, fuses for loose contacts
Sent from my F5321 using Tsikot Forums mobile app
- Aug 2017
- 232
October 6th, 2017 07:25 PM #1204Hi, can anyone share what oil they use for a 99 revo glx a/t gas? Thanks!
Sent from my EVA-L19 using Tsikot Forums mobile app
October 6th, 2017 07:41 PM #1205
any 15w40 mineral oil will work. shell mechanics probably know the total liters...
- Nov 2008
- 641
October 7th, 2017 09:34 AM #1206
- Aug 2017
- 232
October 7th, 2017 10:44 AM #1207Got it. Thank you! And what about for atf dialysis?
- Aug 2017
- 37
October 7th, 2017 09:14 PM #1208use original toyota type t-iv atf
- Aug 2017
- 232
October 18th, 2017 02:09 PM #1209Does anyone know how much is a clutch fan/fan clutch (?) for the revo? Had our aircon fixed, put freon, also put silicone oil, but now it's not cold again. Mechanic noticed before that previous mechanic put a some type of cloth ot rag inside. Just wondering how much damage this item would cost. Thank you
- Aug 2017
- 37
October 19th, 2017 08:23 PM #1210i had mine replaced with a replacement clutch fan, its around 2k of price, works great, disengages when engine is cold and engages when hot helping the engine run more efficiently
"they had to go and work". aside from the money, there may also be the threat of penalties...
Traffic!
