Page 469 of 662 FirstFirst ... 369419459465466467468469470471472473479519569 ... LastLast
Results 9,361 to 9,380 of 13229
    Aug 2006
    #9361
    Quote Originally Posted by zhardan View Post
    Guys, 3 months every oil change is too short for modern cars. I think pinagkwartahan lang tayo ng casa. If you look at the owner's manual it's now 1 month or 1000km whichever comes first, 5 months or 5k kms 10 months or 10k kms and so on and so forth. It's easy to remember and considering that an average kilometerage is about 1000 km per month. Yung warranty book ang naglagay na 3 months or 5k. It's lawyers who will argue which one to follow considering that both are Toyota's official documents.
    If you read the manual, PMS schedule depends which country you are in. If TMP set it at 5K or 3 months you have to follow.
    Oct 2008
    #9362
    Question po, normal ba na may formation na ng white powder sa battery terminal kahit na 2 mos old pa lang? Sino na po ba nakapagcheck ng battery terminal nila? Ganon ba talaga pag low maintenance ang nakainstall (stock battery for innova G)? Kasi ung nilagay ko sa corolla gli ko na maintenance free 10 mos ago wala pa traces ng ganon. Advice please.
    Aug 2006
    #9363
    Quote Originally Posted by armando_solis View Post
    That's normal, just clean it with water once in while.
    Bad trip din ako sa low maintenance battery na nasa G variant, tumatalsik nga minsan ang solution sa breather caps at nagpatse-patse na yung pintura sa malapit sa battery.
    Oct 2008
    #9364
    Quote Originally Posted by Mile2 View Post
    Thanks Mile2, dapat pala regular ang silip ko sa engine bay, sayang naman ung pintura!
    #9365
    Hindi ba maintenance free ang battery sa Innova G? If so, how and what will I check sa battery? Pls help, newbie lang po.
    May 2007
    #9366
    Quote Originally Posted by attyallanlatras View Post
    Casa charged me for 6 liters of mineral oil as evident in their bill, and if they only placed 5.5 liters, why did they not return to me the excess (for future use). By the way, how effective is Toyota's 20W50 mineral oil?
    You must inform the SA that you want the excess motor oil be given to you. Specially if they bring your vehicle inside their lube for the PMS. In my case in TMB (Toyota Motors Batangas), PMS are mostly done in their 'quick lube' which is outside their main facility. So I can see for myself what they are doing. And I just ask the mechanic to give me the remaining motor oil and the old spark plugs. I usually give the old spark plugs to my brother-in-law who have an old car.
    Oct 2008
    #9367
    Low maintenance 1smf lang po ang stock battery ng G variant. Kahit ung sa classmate ko na 2006 model same lang ung battery compared sa nilabas ngayon 2008. Ung battery terminal saka water level ang dapat i check. I think sa positive terminal ng battery nag accumulate ung white powder sa innova ko. Then you could apply grease sa terminals after cleaning. Sabi ng battery dealer dito sa amin, sign of leak daw pag may formation ng white powder ang terminals ng battery, pero i don't know kung normal ito kahit bago pa ung battery. Maybe kung mag 1 year na ung akin, di na ko magtataka sa nakita ko, kaso kaka 2 mos pa lang e.
    Aug 2005
    #9368
    Hi a_s, since our stock battery is a maintenance type, you have to once in a while, say every week at the most, check your battery terminals wherein your battery ages in time thus sulfur deposits appear. To properly remove and clean it, you will need the following materials:
    1) baking soda
    2) h20
    3) cleaning brush (an old toothbrush or paint brush will do)
    4) rags and
    5) a small dipper.
    Procedure: Mix a small amount of baking soda with water to produce a pasty solution in a small dipper. Dip the brush into it and brush the affected parts of the battery. You will notice, the deposits to react with the solution. Let it stand for a couple of minutes thence clean/wipe it with rags. Voila! the deposits are gone. Hope this helps.
    And to add, to prevent acid splashes ruining your paintwork, apply synthetic (polymer) sealant onto painted underhood areas where battery acid splashes will likely stick.
    Aug 2005
    #9369
    If you have your Owner's manual on hand, flip to pages 293-294. You will have all the info you require.
    #9370
    My Innova G is a 2008 release, Does this mean that my battery is maintenance free na? But the manual still show the same pages in the earlier post. Does this mean that my Innova G 2008 is still low maintenance?
    May 2005
    #9371
    If its maintenance-free then the battery caps are sealed and can't be opened until the battery's warranty expires.
    #9372
    Thanks. The battery caps are not sealed so hindi maintenance free.
    Another question. I have not seen in the Innova manual any topic or discussion regarding washing the engine. Does this mean, it is discouraged or prohibited? Unlike the manner of cleaning the exterior and interior part of the car. What can you say on this?
    Aug 2005
    #9373
    It's a matter of owner's prerogative if he want his car engine washed or not. For me, I never washed my car's engine with high water pressured equipment. If you really wish your engine bay washed, avoid concentrating on ignition system and exposed electrical components. Better cover them to avoid each getting wet. Since I acquired my unit naspu naspu lang sa engine bay and using compresssed air under running vaccum cleaner to remove stubborn dust. I googled one article for you to quench your curiosity: http://www.dccarcare.com/tipowk/tipowk13.html
    Apr 2008
    #9374
    [size=6]happy new year!!!!![/size]
    #9375
    After mag-red na ang fuel gauge sa Innova natin, ilang liter pa ba ang reserve fuel nya?
    Jun 2005
    #9376
    Around 10 liters. Malayo pa ang mararating mo bago mag-totally empty. Theoretically, if your FC is 10 kpl, you could still travel for about 100 kilometers.
    Please check my experience here.
    :eat: [SIZE="1"]3993[/SIZE]
    Oct 2008
    #9377
    Happy New Year sa lahat ng mga ka-Innova natin! Ask ko lang po sa mga nakapag 1000km pms na, particularly sa mga VVTi owners.
    Pinalitan din ba yung oil filter sa 1st pms nyo?
    Ano pa po ba ginagawa sa 1st 1000km pms?
    I'll be having my 1st pms on the 2nd week of January and im planning to shift from mineral oil to fully synthetic 15W-40. May nakagawa na po ba nito?
    Balak ko sana sa dealer ko na rin ipagawa, Toyota Makati, pwede kaya manuod habang nag cchange oil sa dealer na un?
    Thanks in advance!!
    #9378
    Thanks in advance!!
    I just had my 1000 pms last Friday sa casa. I only had mineral oil since it cost me only PHP 1,400, way less than the P 5,200 for full synthetic. I've also read in the previous thread that since there are some adjustments sa lubrication and the like, mineral oil is better than full synthetic as for now.
    In my experience, parang hindi pwedeng manuod during the change oil process.
    By the way, also ask for the remaining oil dahil only 5.5 liters lang and ilagay so ask for what is left for future use. otherwise, if you will not ask hindi nila ibigay.
    As to the oil filter, they will also change that. The P 1,400 actually includes already the filter. Have a nice day...Happy new year...
    Jun 2005
    #9379
    Thanks in advance!!
    Pag sa Toyota Makati, pwede kang manood lalo na pag sa labas tratrabahuhin ang car mo. Pero, ask permission first kung lalapit ka mismo sa car mo.
    :car: [SIZE="1"]3996[/SIZE]
    #9380
    Quote Originally Posted by j_avonni View Post
    Buti pa sa Toyota Makati pwedeng manuod. Toyota Cebu, mahirapan ka...
Toyota Innova Owners & Discussions [ARCHIVED]
