Page 471 of 662 FirstFirst ... 371421461467468469470471472473474475481521571 ... LastLast
Results 9,401 to 9,420 of 13229
    Jan 2009
    #9401
    hello everybody... a newbie here... just got my innova this december as a christmas gift from my loving hubby...naawa na siya del ung kotse ko na ginagamit nung dalaga
    pa ako kaya almost 11 years na siya at kailangan na magpahinga hehehe!!! neways,
    i have a question regarding the OR and CR help me naman po... just wondering how
    come the S.A. only gave me a xerox copy ... ganun ba talaga? thanks and Happy New Year to All!!!
    May 2005
    #9402
    Quote Originally Posted by InNoMaMa View Post
    what they gave you are probably several photo copies of the sales invoice with many advanced dates from the date of purchase. These copies are meant to be shown to the police when they accost the vehicle under their no plate no travel policy.
    They will give you the original copy of OR and CR when it becomes available.
    #9403
    Welcome, InNoMaMa. Yes, ganun di yung binigay sa akin, I also got my Innova G a/t gas just last Nov. 28, 2008...Soon you will get the original copies...Moreover, less than a month they will also provide you the plate number...Happy riding....
    Aug 2005
    #9404
    did you get it cash ba or installment? if cash, they should give the original OR and CR. If installment, i believe yung original CR nasa bank.
    Jan 2009
    #9405
    thank you po for the info. havanycdei!!!
    Jan 2009
    #9406
    Quote Originally Posted by attyallanlatras View Post
    thanks for the info po. yup...just got my plates yesterday. havanycdei.
    Jan 2009
    #9407
    Quote Originally Posted by imperialv View Post
    we got it thru installment po. which means i can only get hold of the
    original once its already paid in full? OIC!!! thanks! havanycdei
    #9408
    yung orig CR at OR po ibibigay sa yo kasabay ng plates...its under process pa with LTO and it takes around 3 to 6 weeks...for now yung muna pong sales invoice ang proof of ownership mo...pero dont bring the original within the car, xerox lang po dalhin mo.
    Aug 2005
    #9409
    Good day mates, up ko lang, unfortunately after 3.5 years my stock Oriental batt have to go. Found the engine too hard to start in the cold morning. And the poor thing casing was noticeably become bloated. I had it replaced with GS maintenance free with status indicator.
    Now my engine is up and running again.
    #9410
    Quote Originally Posted by leinahtan View Post
    Mag-kano ba yung GS maintenance free baterry mo? How many months and warranty? Ilang plates? Sorry newbie lang po...THanks in advance...
    Oct 2003
    #9411
    Quote Originally Posted by Mile2 View Post
    Most of the body weight is on the drivers side, just remember that the gas tank is on the driver's side. So if you are using the car all alone most of the time, then there's no counter weight balance on the passenger side.
    Kaya share a ride para may balance hehehe
    i've check the front height of my innova, and true! the left (driver side) is lower than the right! i placed my car on a level ground (seems like it) and measure it from the ground up to the side fender (sa may wheel well ba yun) using the center of the tire as reference. the left side measures 70cm and the right 71cm. both tires on front have the same 34psi reading.
    i have checked also with my officemates (4 owners kami) and all have the same ride height as mine! is this a factory defect?
    peeps, pls also check your front ride height!
    Aug 2005
    #9412
    a) Price = P2900 inclusive of old batt trade-in
    b) Warranty = 20 mos
    c) Plates = 13 (better than the 2SN x 11 plates)
    Aug 2006
    #9413
    Does GS have a reliable warranty claim center now? I guess 13 plates is standard for premium batteries.
    I had a bad experience long time ago when I bought a GS and it went dead 9 months later and the shop where I got it never had a chance to replace it up to now and blame their dealers inaction So from thereon, I only had Oriental from a refutable store to be safe.
    My stock battery is now bulging on the sides after 2 years 3 moths, guess it will be soon that I'll be replacing it also.
    Aug 2006
    #9414
    Quote Originally Posted by wakin View Post
    Have you guys, checked your front shocks for leaks? Mine was still having the same height on both sides, though I had a replacement front passenger side shock from casa few months back.
    You can actually do a shock test to your ride, push down hard each side of your front fender and release it quickly, if you see that it bounces up more than once then you have a dead shocks. Or let your dealers do the actual shock test on your rides and if all your shocks are ok, then ask your dealer to interchange the coil springs to verify that one of your coil springs had retired prematurely.
    Aug 2005
    #9415
    Will give the GS a shot. Shop owner is an acquaintance so I trust there won't be any problem on warranties. My stock Oriental batt can't take up any charging anymore, once you keep it idle overnyt, you'll end up commuting the next day. Same, bloated na rin on both sides. Poor thing really got to go. 3 and a half years isn't bad for a low maintenance batt like Oriental.
    Oct 2003
    #9416
    have you already tried measuring your ride's height? by just seeing it, it may look balanced but when you measure it will reflect your ride's height. I've check and we dont have any leaking shocks. We also tested the shocks if it bounces up more than once and the result is ok. I will let casa interchange the coil springs.
    Jun 2008
    #9417
    Naku po, eto yung problema nung D4D na Innova ni dad. 1 week old pa lang hindi na pantay. Dun sa VVT-i naman pantay na pantay ang ride height. Wala pang response ang casa...last year pa na-report yun! Amfffff...
    #9418
    Thanks for the info. My brother in law just purchased a maintenance free battery two weeks ago (oriental ang brand) for almost 5k with the same number of plates and the same warranty. I hope sulit yung battery mo, so that if my stock low maintenance battery dies, I have an option to buy GS Battery.... Again, thanks for the info....
    Oct 2003
    #9419
    Quote Originally Posted by roberto_minosa View Post
    saan casa po ba yan?
    Aug 2005
    #9420
    I can't guarantee how long this GS battery will live. I'm just hoping it will surpass it's predecessor . A fellow tsikoteer post about GS is quite assuring: http://tsikot.yehey.com/forums/showt...t=38220&page=3
Toyota Innova Owners & Discussions [ARCHIVED]
