Page 466 of 662 FirstFirst ... 366416456462463464465466467468469470476516566 ... LastLast
Results 9,301 to 9,320 of 13229
    Jun 2008
    #9301
    Quote Originally Posted by over View Post
    paano malalaman kung meron prob un shocks?para kasi mababa un sa driver side e..
    Same problem with dad's D4D Innova. Driver side front ride height is lower than the other side. Still being assessed...hay.
    Oct 2008
    #9302
    [quote=roberto_minosa;1166846]Same problem with dad's D4D Innova. Driver side front ride height is lower than the other side. Still being assessed...hay.[/quota
    saan niyo po casa dinala?free naman po diba kasi under warranty pa?
    guys help dun sa mga napalitan na.
    Aug 2005
    #9303
    Di kaya heavyweight yung driver? . Kidding aside, shock abs issues has been discussed here earlier, but if you don't want to backtrack, here are some helpful info about it
    Aug 2005
    #9304
    [quote=over;1167452]
    Quote Originally Posted by roberto_minosa View Post
    I had mine (front pair only) replaced at TAI few weeks back. It was no longer under warranty, but I insisted that it was, when they evaluated it last year, unfortunately the part wasn't available then, until I called them to have it replaced for free. To make the story short, my warranty appeal letter was approved and there it was, it's as good as new. In your case, di ko na experience yung list, meaning heeling on either side but rattles on potholes, matagtag na sya sobra at sa shock housing visible na yung oil leak around it. I reckon that your ride might be having problems with any underchassis suspensions. Shocks could be one. I would suggest you have to bring it to the casa while it is still under warranty.
    #9305
    [quote=leinahtan;1167483]
    Dec 2007
    #9306
    Quote Originally Posted by RR27 View Post
    yup!!! gensan ang hometown!!! meron akong nakausap last wednesday, 2005 innova G owner, d4d, green mica, nag usap kami, and then i asked him na kumusta po ang ride niyo sir? na-experience niyo po ba na nag choke or hard starting sa umaga ride niyo??? sinagot niya ako na wala naman daw' at ang gamit niya daw na oil eh mobil 1 daw!!! kaya sa 5k pms ko, mobil 1 na gagamitin ko. pakiusapan ko lang ang casa!!!
    Pareho tayo ng iniisip, Mag 8,000 km na ang ride ko and at 1OKkm PMS, I'm planning to use an OEM oil na I know is being supplied by Mobil. I already made an inquiry sa dealer na binilhan ko and they said na puede mavoid warranty ko pero I will argue my case. Nowhere in the manual does it say na TOYOTA OIL lang ang puede gamitin. Kailangan lang it is within spec. I work for a company who represent a world leading engine and equipment manufacturer. The core product is Industrial Engine and our product never requires use of the oil being supplied by our principal. So long as it is within spec, no problem with the warranty.
    May 2007
    #9307
    Quote Originally Posted by Mile2 View Post
    TMI charge P1050 for 10K PMS labor plus parts (Oil, Oil filter, Spark Plugs, brake cleaners) P1398, that was April 2007.
    sorry, i was quoted P1820 for 10K PMS labor - tune-up, change oil/oil filter, clean/inspect/adjust all brakes, tighten all body bolts and nuts.
    thanks Mile2
    May 2007
    #9308
    Quote Originally Posted by timo07 View Post
    same here... my odometer reading is 8,530km. and is nearing the 10K PMS... FYI, Tyt Otis allows bringing in of oil other than theirs... they also carry Mobil 1.
    Jun 2008
    #9309
    Toyota San Fernando Pampanga sabi ni erpats. Casa attempted to replace shocks and springs. Did not do the trick. Still under "assessment", or whatever they call it:D...jeez, what else is there to assess?! Anyway, the company will eventually settle it since it's a company car...
    Oct 2008
    #9310
    Quote Originally Posted by leinahtan View Post
    hindi sir.50 pounds lang ata ako e.haha..student pa lang ako.haha.thanks sa info sir.helpful yun ah..ung iba signs ng worn shocks naEEXPERIENCE ko na..
    Jun 2008
    #9311
    Student din ako...amf hirap ng malaking sasakyan! Nakakapanghinayang yung space tapos ako lang ang sakay...eh no choice! Eto lang naman kasi sasakyan namin dito pwera yung company car...Anyway, special occasions lang ako nagkokotse...kaw over?
    Apr 2008
    #9312
    ,,,ok"' mobil 1 na gagamitin ko next pms...''' hindi ko na nga nararamdaman ang engine brake baka mas lalo pang bumilis si inno j ko sa mobil 1...'''(mclaren f1 team'') piloto na, f1 driver pa!!! hehehehe!!!
    Sep 2008
    #9313
    Fellow innova peeps,
    After reading your problems regarding the issue above, i got curious and check my innova too..... OMG , my front driver side is really lower!!!!
    Sabi ng resident mechanic ng office, could be the torsion bar, uneven yung adjustment... and since most of the time ako lang yung sakay ( I'm about 265lbs ) kaya ganun
    Please advise
    Gil
    Oct 2008
    #9314
    ahh..ako for schooling..nursing kasi ako kaya gamit ko sa duty..pwede din sa chiks.haha..pero di ko sinasakay mga classmate ko..malalaspag e.haha
    Aug 2008
    #9315
    Gud day, I know that mobil 1 is a fully synthetic oil, ask ko lang kung what change oil interval will you follow then. Every 5k kilo or every 10k kilo with changing of oil filter lang and add some oil when u reached the first 5k. Heavy kc sa pocket kung mag fully synthetic kc and perform a change oil every 5,000 km intervals. My unit is a D4D din.
    Apr 2008
    #9316
    Quote Originally Posted by Terrence View Post
    ,,,hi''' sa next 5k pms pa lang ako gagamit ng mobil 1, i think every 10kms ang change oil ng fully synthetic oil, sa oil filter di ko sigurado kung papalitan, according to my church friend na naka innova d4d, depende raw, kase ang sa kanya, everytime daw na i_check niya ang oil, at iba na ang viscosity( i mean di na siguro malapot) kahit na di daw umabot ng 10k kms, eh nagpapalit na siya ng oil. (phil am life agent kase) kaya takbo dito takbo doon ang innova niya!!! innova niya kase na test drive ko kaya isa yan sa mga dahilan kung bakit naka innova d4d ako ngaun,hehehe!!!
    sensya na!!! napa_kwento na naman..!!!
    Jun 2005
    #9317
    I used my Innova J gas for more than 65,000 kms. before I sold it. From my first PMS, I only used the fully synthetic oil of Toyota. I changed oil every 10,000 kms. And, I hadn't encountered any problem with it.
    [SIZE="1"]3915[/SIZE]
    Jun 2008
    #9318
    Quote Originally Posted by gil_co View Post
    Please advise
    Gil
    That's interesting! Me and my dad both weigh 200lbs and 230lbs respectively (I think:D)...but we checked the clearance when we were both off the car...
    Dec 2007
    #9319
    Quote Originally Posted by liv View Post
    Ma'am Liv, sa Toyota Shaw Ortigas din eh allowed. Gawin kong justification ito sa Marikina.
    Dec 2007
    #9320
    I'm on Toyota Full Synthetic oil since my 5000km PMS but I have no plans of extending usage for 10000km. Medyo maitim na kasi, considering the oil is very light in color when freshly filled up. Somebody in this thread or on another thread (I can't even remember correctly if it was a Toyota car owner's thread) that they use Synthetic oil for up to 7000km only and for me, it is a good practice not to stretch the recommended life of the oil. I computed a change oil interval of every 5000km (or less) using mineral oil and mas mura ng konti kapag tinanggal mo yung mga labor and miscellaneous charges ng toyota. I am planning to do this and monitor the immediate effect on the engine performance if I could. I know one person who extends the use of his mineral oil up to 10000km. For me, this is not a good practice, moreso kung diesel ang engine.
Toyota Innova Owners & Discussions [ARCHIVED]
