Page 455 of 662 FirstFirst ... 355405445451452453454455456457458459465505555 ... LastLast
Results 9,081 to 9,100 of 13229
    Apr 2008
    #9081
    hello po sa lahat ng innova lovers!!! next week po' naka silver innova j d4d na po kami!!!! may thread po dito na hard starting at choking, black smoke, pero based dun sa 2005 innova e d4d ng church friend namin di daw nila na experience yun' sabi niya na ''sa nag aalaga lang yan''. mobil 1 ang gamit niya na oil. tapos search na rin kaagad ako kung paano aalagaan ang common rail engine kaya share ko lang ng konte ang iba, mahaba kase, ''
    DIESEL ENGINE WON'T START
    A diesel engine that cranks normally but won't start regardless of the outside temperature either has low compression or a fuel delivery problem. If compression is okay, check the fuel gauge (out of fuel?). Then check the fuel filters and lines for obstructions.
    If the injection pump isn't pushing fuel through the lines to the injectors, it may have a faulty solenoid. Listen for a "click" inside the pump when the ignition switch is turned on. No click means the solenoid and/or pump need to be replaced. If it clicks but there's no fuel coming through the injector lines (and the filter and lines are not obstructed), the pump is probably bad and needs to be replaced.
    DIESEL TROUBLESHOOTING BLACK SMOKE
    Black smoke is usually a signal that there's too much fuel, not enough air or injector pump timing is off. One of the most common causes of this condition is an air inlet restriction. The cause may be a dirty air filter, a collapsed intake hose or even an exhaust restriction. Diesels are unthrottled so there is no intake vacuum to measure.
    DIESEL STALLING PROBLEMS
    If a diesel stalls when decelerating, it may indicate a lubrication problem in the injector pump. The first thing that should be checked is the idle speed. If low, it could prevent the pump governor from recovering quickly enough during deceleration to prevent the engine from stalling.
    Water in the fuel can also cause stalling by making the metering valve or plungers inside the pump stick. Use of a lubricating additive may help cure this condition. If an additive doesn't help, the pump may have to be cleaned or replaced.
    sana po makatulong po ito!!!! salamat po!!!
    mam liv' salamat po sa reply niyo sa akin, ingats po!!!
    May 2007
    #9082
    Quote Originally Posted by RR27 View Post
    very informative though a bit technical for people like me.
    no problem sir! glad to be of help! if you have any queries about your ride... don't hesitate to post it here... mababait po kaming lahat dito.
    May 2007
    #9083
    very informative though a bit technical for people like me.hehe
    no problem sir! glad to be of help! if you have any queries about your new ride... don't hesitate to post it here... mababait po kaming lahat dito.
    Aug 2006
    #9084
    RR27
    Nice article, but I have to warn to you that Casa don't use any other oil aside Toyota Motor Oils otherwise they will void your engine warranty and you can not play with your idle speed because it has to be done using Toyota programming software. You have 3 years of full warranty so get the most of it make friends with your suking casa servicemen so you can pull their arms and legs when you car gets into troubles
    Best of luck to you and your ride.
    Cheers
    Dec 2007
    #9085
    RR27, Mile2 is right, CASAs do not allow use of non-toyota oil. I view this as purely maximing earning for them but we don't have any choice lest mavoid ang warranty. If you can convince your dealer on using a different branded oil without affecting warranty then that's good. On taking care of vehicles, simple din lang ang puede nating gawin and we have to rely sa casa on problems. Strict implementation of maintenance schedules, loading up of fuel from a refutable gasoline station and probably maintaining that source as much as possible, keeping your car clean inside out and good driving habits will somehow contribute to a good performing vehicle.
    Ma'am Liv, this thread has had some discussions on Comp. Insurance premiums and you've contributed on establishing lowest possible rate from a certain insurer. My E Diesel Manual's 1st year insurance will expire nov. 10 and I received a proposal from Toyota Marikina for a renewal with premium amounting to Php16K, Is this reasonable? Yung value ng vehicle depreciated by about 10% from the original purchase price. Tama rin ba ito? Thanks in advance for the assistance.
    May 2007
    #9086
    Quote Originally Posted by timo07 View Post
    i've created a thread regarding our Innova's insurance in the Innova sub forum... kindly post the quotation that you got from Tyt Marikina... we'll see if Tyt Otis can match it, if not give you a much lower quote.
    May 2007
    #9087
    Quote Originally Posted by marvelxxx View Post
    I LOVE MY NEW INNOVA!!!!
    Congrats!.. parang may pagka Fuzion GLS Sport dahil sa fender flare color at ung body color..aha.. pero no offense ha...
    Oct 2008
    #9088
    hi, i'm new here. i also have a innova. peace!
    #9089
    guys, naunahan na tayo ng isuzu crosswind sa best auv car of the year ng autofocus.
    pls. vote for innova!
    thanks!
    Aug 2008
    #9090
    Hello every body. I have registered since last aug but i havn't had the chance to be active in the forum. but i always read the threads and i find it very informative.
    i would like to ask if somebody has tried "Bio-Diesel" in their innova. Ok ba yun? baka kasi ito yung sinasabi nila na low quality na Diesel. any experience and comments i would like to hear because i'm considering it kung sakali kasi mas cheaper sya sa regular na diesel.
    as my user name says, mine is a: E, Diesel, AT bought last Aug 08.
    Thanks in advance sa mga replies.
    Aug 2006
    #9091
    Quote Originally Posted by habibs View Post
    thanks!
    Don't worry majority of people do not believe in that voting where anyone can vote daily hehehehe
    Hackers can make a robot program to vote on it daily
    Unit count on the street is the true yard stick, no one can rig the figures
    Jun 2008
    #9092
    to all innova owners..
    tatanong lang po.. kung pwede po ba ikabit ang bagong bumper ng new innova sa old na innova? maganda kasi bumper ng bagong innova.. "bumper lang po gusto ko" wag na yung grill para kasing Avanza..
    Innova G VVT-i / MT
    Jun 2008
    #9093
    Quote Originally Posted by Mile2 View Post
    After two years and 44K kms run I had my front shock replaced by TMBC, I just told them about the leaky shock, they evaluate it and replace it quickly.
    Good Day po sir Mile! My wife had our Innova E M/T today for 10k PMS. They observe 1 of our front shock is leaking. They told us to return on Monday for warranty evaluation. Tanong ko lang di ba dapat talgang under warranty to. And how long did it take for toyota to replaced the shock? Dapat di ba pares ang papalitan nila kasi i read one of the thread here na dapat pares kasi maapektuhan yung lumang shock pag-di pinalitan pareho.
    Ay tapos yung side pillars daw evaluate din nila for warranty kasi natangal ti-nry nila kabit di nila maibalik.
    Thanks! Hope to get a reply from you mga ka-Innova!
    Aug 2006
    #9094
    Quote Originally Posted by TAP-TAP View Post
    Kasama sa warranty ang shock absorbers dahil di naman ito consumables at walang puedeng i-tamper ang owner dito, kaya pag nasira talagang papalitan dapat.
    Front shock replacement would not take an hour.
    They would remove the leaky shock and will evaluate it, if still functioning they will not replace it.
    I also tried that both front shocks be replaced, but they only replace one since they told me that the other one is still okay. They need the defective one so that they can also have a replacement from TMP.
    For now, I just always monitor all my shocks till the end of warranty
    #9095
    Quote Originally Posted by D4D AT808 View Post
    Hindi po ito naitanong nung nag-plant tour ang Innova Club Ph sa TMP.
    Ang naitanong po dun ay yung paggamit ng "E10" which is ok daw po sa Innova accdg mismo sa VP for Technical group ng TMP.
    Apr 2008
    #9096
    *mam liv,
    sir mile ,
    timo07,
    THANK YOU!!!
    bukas na po darating ang unit' monday, pero sabi tuesday ko na daw kukunin kase 24hrs daw ang curing ng rustproofing!!! tama ba yun mga sirs at mam????
    *bluebimmer,
    sir' papasyalan ko GS depot niyo, baka mabigyan mo ako ng discount!!! hehehehe!!! ok!!! thank you po!!!
    Aug 2008
    #9097
    Quote Originally Posted by reiji0463 View Post
    Sir reiji0463, Thanks sa reply. Sayang sana may nakapagtanong.
    Sir RR27, i've read your post on Diesel Common Rail Engine, it really is interesting and very helpfull. any idea sir regarding "BIO-DIESEL"? Ty
    Anyone else? with comments or idea regarding "BIO-DIESEL". or kung may nakasubok na. ano difference sa regular Diesel?
    Keep 'em comming. TY
    Apr 2008
    #9098
    D4D AT808, sorry' di ko pa na_try "bio-diesel" sa tuesday ko pa kase makukuha unit namin, pero interesado rin ako sa bio diesel kung ok ba siya sa d4d's, antayin natin mga members ng innova club na naka d4d's na mag post ng reply nila, si mam liv' at sir mile2 nakainnova vvt-i ride kase, ooopppsss, naka_LPG na pala kay sir mile2...!!!
    Mar 2007
    #9099
    Hi Liv, kamusta na ba ang club? Sorry for not visiting our site medyo busy talaga sa trabaho. I really wanted to be with the EB kaso regular work ko kasi ang Sabado. Should there be EB on a Sunday, please advise me, for sure I will be there.
    Haven't read our thread, ang laki na ng hahabulin ko kasi, just read a few.
    Am glad ur still very active, noticed Mile2 rin. Keep up the good work guys, the club needs more people like you.
    I miss the group, kelan ba nung nakasama ako sa EB, I think it was the 1st, tama ba?
    Regards to all, mabuhay ang innova club! Dumami na ba ang dumadating sa EB?
    Give my regards also to your hubby, pagumattend dapat magkainuman na para mas masaya!
    GLD
    Mar 2007
    #9100
    Quote Originally Posted by albriones View Post
    Innova G VVT-i / MT
    Di sir fit yung bagong bumper ng new Innova sa old version. Iba yung design ng head light ng bago, mas malalim yung sa sa bago, pati front grill di pwede.
Toyota Innova Owners & Discussions [ARCHIVED]
