FYI, sa mga naka SOLEX na Spare Tire lock. Better remove and inspect your spare tire. Two weeks ago, I heard a squeeking sound under my vehicle. I thought " kay aga namang bumigay ng shocks o mga bushings ko?!" Upon inspection, I found out na nanggagaling sa spare tire. When I removed the tire, there it was!! Two deep gashes on the alloy rims made by the mounting bolts of the tire lock assembly!!! Very annoying! I had to put two layers of rubber sheet to provide some cushion and protection.....
Thank you sir! - Will check kaagad.... buti na lang weekend tomorrow - have time to do it.
By the way, I asked how the spare tire is stolen. They said (Both the Toyota SA and the one who installed the tire lock), the air is taken out by removing the pin. Once fully deflated, the wheel will be loosely (slightly) hanging free and the thief can easily slide the bar into the middle of the magwheel. Takes about 3-5 minutes daw. Fyi
http://www.autoshop101.com/forms/h20.pdf
The link above is an Electronic Fuel Injection System Overview from Toyota in Adobe pdf form.
'Hope this might help a lot.
Thanks.
Sir, kayang-kayang putulin ng bolt cutter yang deterrent mo. I myself was victim, then with a large chain and padlock as locks. Sinisiw lang ng mga buhong. Ang masakit don, hindi ko pa nagamit yung spare tire. Now I have this Solex type lock. Giving me the peace of mind wherever I park the unit.
Liv,
I got a quotation from our insurance. Renewal na kasi ako this month.
Eto yung details
2007 TOYOTA INNOVA J VVT-i M/T.
Coverage Amount
Own Damage & Theft P 686,000.00
Bodily Injury 300,000.00
Property Damage 300,000.00
Auto PA 600,000
TOTAL PREMIUM 12,339.19
DEDUCTIBLE 3,000
Hindi ko pa sure kung makakakuha pa kami ng discount. Sa banko ni misis ito.
no problem with innova, very efficient and roomy. ganda pa ang ride!!!!
[SIZE="3"]post ko lang, i am selling 2005 innova j diesel plate ending 2 color blaze red with back up sensor, tint, chrome sideview mirror cover, power lock and power alarm. selling price is 500k. sacrifice sale since i am migrating to new zealand.
please reach me at 09189022154 and 09228436961. [/SIZE]
Checked out how the solex spare tire lock works. This is what i found out.
The brackets will not cause any scratches as they are well within the brace as seen in the picture. However, because of the spare tire lock, the spare tire will not be centered. Looked for other means of attaching the rod but there are no other holes to put through (unless you want to drill one - which can be a source of rust in the future). Since the tire is not centered, the chain will not shoot directly in to the center hole and will instead be pinned against the mags - which will cause the scratches. Placed some rubber in between in the meantime to prevent the scratches. Think the solex kit is slightly mis-designed - Thinking of having it bent so that the wheel will be centered. Attached some pics so you can see.
Also, in the event of a flat tire, I suggest that you do not immediately return the spare tire underneath and just put it inside the car. The effort of returning the tire, especially with the tire lock was tedious.
yaiksss... hindi pala talaga naka centro.... pero ok yung goma ah... hindi magasgas yung mags...![]()
Your lock is different from mine. I remember you mentioned buying yours outside while mine was bought from toyota. The casa supplied lock has a wrap-around bracket that attaches to the underside frame and two locking screws hold it in place. iyon ang maling design kasi it will definitely touch the rim if you tighten the spare tire in place. The lifting chain definitely goes to the center of the rim while the lock bolt goes to one of the stud holes. For those with steel rims, yes no worries dahil me hub cap and steel is harder than the alloy rims.
Wala pa po bang Projector Headlight ang Innova tulad ng Fortuner at Hilux? thanks!
This is the Solex/ genuine Toyota spare tire lock sold in Toyota dealers. Notice the stainless steel rod is held by a tab which is attached to the frame. The steel rod is not centered since the part of the frame which it is attached to is not straight to begin with. So far, I haven't noticed any scratches on the rim.
We have the same tire lock, but mine was installed at the right. I don't know if that was the reason but those two locknuts (at each side of the lock shaft) did scratched my rims. The rubber tire itself will touch the frame but is flexible enough and if you over tighten the chain harness, you may scratch the rims. The best way is to inspect your tires and put some rubber sheets for protection. The casa mechanic might have over tightened the spare tire in place.
Guys tanong ko lang kung paano ininstall yung spare tire lock. I got mine from karplus makati, 4x4 yung brand. May kailangan pa bang butasan sa auto o wala na? Hindi ko kasi dala ung auto nung binili ko yung lock so hindi nainstall nung mekaniko dun. Ang ginawa ko, pinacheck ko sa petron, sabi nila may kailangan pa daw butasan. Hindi ko na pinagawa kasi baka mavoid warranty.
Replies will be appreciated. Salamat!
