Page 27 of 171 FirstFirst ... 172324252627282930313777127 ... LastLast
Results 521 to 540 of 3407
    #521
    Consumable po ang cabin AC filter ng lahat ng sasakyan. Pero yung ibang old vehicles wala nitong feature na ito kaya wala ng pinapalitan.
    There are more affordable options for consumables but generally, don't expect banawe parts and prices for subaru. It's also the reason it's not takaw-nakaw though.
    #522
    Guys, my sales agent texted that my forester unit is available. He said for LTO registration they are charging about P12,000 and I could ask for a plate number ending in 8. How much should I pay for LTO registration? Since it's only February, would LTO registration be cheaper if I choose a plate number ending in 1 or 2?
    #523
    guys, ano ba pwede ko sabihin sa dad ko para mapabili na talaga siya ng xt? super gusto ko talaga yun xt, siya rin gusto niya rin pero isip niya un gas saka baka hirap daw maintain dahil tarlac pa kami
    #524
    Quote Originally Posted by ralphgo3 View Post
    Fuel consumption should be about 7.5 km/lit. Check out subaruclub.ph -- there are units even in the Visayas and Mindanao.
    Jun 2009
    #525
    Pabasa mo 'to sa kanya: http://www.topgear.com.ph/features/c...ubaru-forester
    It's a TG column on fuel economy: Rav4 vs. CRV vs. Forester XT. Quite surprising that the writer was able to hit 8km per liter on the Forester. Re hirap i-maintain, baka may point dad mo diyan since nag-iisa lang ang dealer sa EDSA (althoug in theory, Subaru PMS is supposed to be every 10K, so i-timing niyo na lang na may biyahe kayo sa Manila). Kung may kakilala kang Subaru owners sa Tarlac, baka may mga tip din sila.
    #526
    thanks sa reply, napabasa ko na rin un sa topgear, pero di parin ata siya naconvince, i hope pumayag na siya, how about un PMS mas mahal ba?
    #527
    powerloord, congrats sa new ride mo, what color kinuha mo? may choice ba or kung ano lang available colors un lang pwede pagpilian
    #528
    Ralph, I got the Dark Gray Metallic. Choice of colors: Satin White Pearl, Newport Blue, Obsidian Black, Dark Gray Metallic, Camellia Red Pearl, Sage Green Metallic and Steel Silver Metallic. I think they make their orders to Japan based on the buyer reservations. Tinanong kasi ako kung ano preferred color ko: 1st option- Dark Gray Metallic, 2nd - Satin White and 3rd - Newport Blue.
    Dec 2007
    #529
    Good day guys!!! napadaan lang...
    More power to SUBARU FORESTER owners!!!
    #530
    nice choice powerloord , un rin gusto ko color eh
    Jun 2007
    #531
    Guys,
    Got my forester in aug '08 and now at 19Tkm, the front brake rotor disks has to be refaced due to uneven braking (covered by warranty though). Motor Image SA told me that this is a common prob with forester. I told them that instead of just refacing, the rotors and the pads should be totally replaced too. Would like to know your experiences on this and what was done by MI to correct. Thanks.
    #532
    Quote Originally Posted by batang pasig View Post
    Guys,
    What kind is your ride po and what is the common use and is it all stock? My 07 FXT is 50-50 mixed driving. It has just had a pad change after 2 years and 35Thou Kms. No reface yet but was told malapit na.
    AFAIK, pads and rotors are consumable like oil -- they really don't just replace it under warranty. I guess yours just wore out too fast compared to others that's why they replaced it.
    My 02 Civic also had a reface after 3+ years so the reface itself isn't really the issue (mura lang yun pati) but more on why yours warped too fast. Three culprits are common -- harsh aftermarket pads, hard driving, and moisture accumulation in the pads/rotors.
    The latter is the MOST common problem that is not so well-known by drivers. Frequently putting on e-brake right after after driving (without cooling down) will result in rotor wear -- it's sort of like putting on the e-brake after just coming from a flood -- the brakes will stick. Worse is having the car washed right after a long drive -- just a few of those and the rotors are sure to warp.
    From experience lang po.
    May 2008
    #533
    Tanong ko lang sa mga owners napansin nyo ba yung rear speakers na nakakabit sa doors kung sinet nyo all the way sa rear ang fader kung may sound na lumalabas? Napansin ko lang kasi nagrereklamo yung passengers sa likod di nila marinig yung radio samantalang ang lakas na sa harap. Nung try ko iadjust yung fader dun ko napansin na wala palang sound na lumalabas, ugong lang parang sub kaya pala wala sila marinig. I went to MI to check sabi ng technician ganun daw talaga kasi parang midrange lang ang speakers na nakainstall sa likod. Pati MP3 connect ko wala parin, kala ko kasi nung una weak signal lang from radio station kaya mahina. BTW mine is XT di ko sure kung may difference sa speaker set up ng 2.0 sa XT.
    #534
    Ganun talaga speakers ng forester.
    Midrange lng sa likod. So medyo low frequency. Pati impreza ganun e.
    What I did was change the headunit. Its worlds apart. May boses na sa likod. :D
    Jun 2007
    #535
    Thanks pup2 for the reply. Mine is '09 model Forester 2.0, all stock. Commonly used for city driving only, sometimes lang sa highway. MI had the front rotor disks refaced under their warranty. I insisted it should be replaced but they said as SOP, initially they will reface the rotors but if it recurs, even beyond warranty period since there's history already, that's the time the rotors would be replaced. The pads were replaced also, wow too expensive at P8.5T, due to uneven wear. I guess you are right in saying that we should avoid carwash after heavy use. But the SA also mentioned that the pads and the rotors are of the soft surface type. Whatever that means, I hope it does not mean regularly dealing with uneven front brakes. TY
    #536
    Yep, I just checked -- my rotors are still 'virginal' -- not even refacing after 2 years and 30K kms. Pero sa Subaru Club, several peeps have already succumbed to early rotor replacement due to washing without cooling down. I think there's even more in other countries.
    IDK why they use soft rotors, but so far, all its shown is increased sensitivity to temp change. Its not even prone to fading. The 'bite' on my brakes seemed 'mushy' to me initially but a change to Motul brake fluid fixed that.
    #537
    Batang Pasig, what's your mileage at the time of re-facing your rotors? My Impreza has the same problem. It came up at around 18k kms. 20k na ako ngayon. Casa is saying I should re-face the rotors at a cost of P2,500. I'm thinking if pwede sya ipa-warranty.
    #538
    sup guys,
    i'm new to this forum, i have a 2009 forester x. back in the states i use to own a 1999 impreza then when the 05 sti came out i bought one as soon as it came out. pero since i have a family na, kelangan na maging practical kaya i switched to a forester. anyway i'm also a scp forumer, di pa maka pag pa member kc i can't attend the meets since i travel a lot. my name in scp is grannyshifter, dito kc taken na grannyshifter kaya naging foresterx tuloy.
    Jun 2009
    #539
    ano ba oil viscosity the the shell ultra helix na nilalagay ni MI sa FXT natin on its first PMS?
    Aug 2006
    #540
    Quote Originally Posted by walldgreat View Post
    they use shell helix ultra 5W-40. but if i were you, i'd buy from outside then have it serviced sa MI. may corkage fee lang nga na P50/ liter but still, mas mura pa rin from outside
Subaru Forester
