Page 83 of 330 FirstFirst ... 337379808182838485868793133183 ... LastLast
Results 1,641 to 1,660 of 6591
    #1641
    Quote Originally Posted by rtp View Post
    Yes chief, I actually read everything. Madami ako natutunan...right now I'm trying to source an original air filter for my Gen II pajero...nung nabili ko kasi the previouse owner replaced the original with a simota filter...I didn't know much about pajeros at the time so natuwa pa ako hehehehe
    Bro here's a tipid tip..... major tipid tip.
    Instead of getting a washable filter or stock filter, just bring your old filter to any auto supply shop which sells ISUZU parts. The Isuzu Elf (i think) has an air filter which is the exact size as those in the Local Version pajero (Japanese versions have flat air filters). What i do is just cut out the plastic fin part and remount it on the Isuzu filter. Do not discard this as you need it to equalize the air pressure inside the airbox and prevent the filter from deteriorating prematurely.... medyo mahirap explain (pero if you guys like explain ko in a separate reply ).
    The best part about the Isuzu filter is..... IT ONLY COSTS Php150!!!!!! haha!
    #1642
    Haaay.... I remember the early days din..... pula pa yung pajero ko and sobrang sariwa...
    Pero four years on, i honestly still cant thing of selling my car and getting a new one... of course on one hand, wala akong pera heheh, but on the other hand for practicality.
    Not counting luho upgrades like the mags, the repaint, the sound system... sobrang no worries gamitin yung paj. i just stick to my 4k change oil/filter routine and drive away!
    #1643
    Quote Originally Posted by pajerokid View Post
    In terms of performance ba sir? Malaki po hehe. The Gen2 2.5L MT can out-accellerate a Gen2.5 2.8L AT. But you kinda get used to driving a pajero.... usually i just wake up and leave home a bit earlier and just enjoy the drive.
    The 2.8L MT on the other hand is acceptably fast (well, at least compared to the other models i mentioned). but very very rare.
    Thanks very very much sir PK for that info Kaya lang talagang very rare nga po ang M/T local 2.5 Gen.
    Jun 2007
    #1644
    Sir PK, i read your very informative inputs sa thread. tanong ko regarding my ride Gen 2.5 a/t .Observed ko that when i rev slowly i.e. less than 2000 rpm, i felt na magshift siya though not immediate but i really noticed the change gear. However, if i rev up immediately i.e more than 2000 rpm, i noticed (or felt ko lang) parang na stuck lang ang gear at hindi magshift or delayed ang shifting. is this normal? i also notice that after driving for more than 1 hour straight, it seems that matagal na ang shifting. Lastly , everytime i noticed delayed in shifting, i heard some sound near the right side sa engine (i think near sa exhaust/turbo) like an unfastened nut. thanks
    May 2007
    #1645
    Good Afternoon Pajero Boys,
    new here, just finished reading from page 1 (naka 2 araw din ako). Appreciated the unselfish attitude of people here, sharing what they know as far experience is concerned.
    anyway, isa lang ang isinama ng loob ko .... itinapon ko yung nasirang antenna ko ... repariable pala .
    btw ... I'm a Gen 2.5 rider from Pque ................
    #1646
    sir pk sa amin po pakiramdam ko mas mabilis yung 2.8L na matic kesa sa 2.5L manual.. or baka dahil mas luma na yung gen2 namin at wala na sa condition... 65tkms na eh.. while.. the gen2.5 only has 16tkms?
    kailangan ko na kaya magpa calibrate? and palitan mga belts at 65tkms? nasa magkano po kaya gastos sa ganun?
    anyone here knows the model code po ng oem na timing belt ng 4d56tdic? im planning to replace them with mitsuboshi fanbelts. and the code nadin po ng fanbelts sa alternator and compressor(code)... tnx po
    #1647
    Quote Originally Posted by andrewbugs View Post
    Why thank you sir!
    Hmmmm..... normally AT's dont shift or take longer to shift the harder you squeeze the gas pedal. this makes the car go faster for overtaking maneouvers etx. When i want to make mine shift up, i usually hold the accelerator steady at around 2k rpm. Or kung gusto mo you can actually shift from 2 and L hehe. just make sure you dont hit Reverse hehe.
    Just take care of your A/T and it will take care of you. i change my ATF yearly, regardless of what people say. Hey, it's the only regularly maintained thing in your tranny, why skimp on it? Also, of the Pajero tranny's ~8L capacity, only around 4L gets replaced.... unless you go through the laborious and expensive process of having the ATF sucked out. So 4L a year worth of ATF is reasonable. And at 1 total cost of around 1300 per year.... its a worthwhile expense imo. ;)
    #1648
    Quote Originally Posted by melto View Post
    Well, if you can actually find a replacement plastic stalk, please do tell us about it! the last time my antenna broke, i can no longer find the banawe boy who repaired it (asa pa ako). And i seached the eskenitas, wala akong makita nagbebenta nung stalk lang so i went with the next best thing.... surplus japanese antenna and some mounting conversion.... not bad na rin for P1500, considering the antenna assembly costs upwards of 8k.
    #1649
    Quote Originally Posted by AC View Post
    baka nga sir AC... your 2.8L is virtually brand new hehe. maybe it's just me, pero super bagal nung primera nung 2.8L ko....
    I still remember racing my cousin's 2.6L Gen1 3 door.... di siya manalo against my then Gen2.... naka turbo mod lang nga yung sa akin... the famous washers.
    #1650
    test drive niyo rin sir yung AT, who knows, maybe the speed (or lack thereof ) is good enough.
    Mar 2003
    #1651
    we still have our gen 2, minsan nadadala ko mas mabilis talaga sa arangkada yung gen 2. primera lakas ng hatak. nearing 200k kms na gen 2 namin, yung manibela nga nahahawakan mo na yung foam sa loob.
    PK i sold my 8650 for 11.5k mga 6 months ago, no remote nawala ko eh. super baba ng 8.5k. reasonbale siguro 10.5k. isa pa palang advantage ng alpine, yung antenna hindi tataas unless naka radio ka, kaya less wear sa antenna natin diba?
    AC pati ako binasa ko rin yung mga post dati, dati parang mas peaceful ang forums, naalala ko pa yung kotse.com puro away nababasa ko. si PK talaga pasimuno nitong thread na to. lahat nagulat nung binenta niya pajero niya. kaya pasalamat tayo di niya bibitawan pajero niya kundi mawawalan tayo ng tanungan.
    Apr 2006
    #1652
    Sir PK, Ito ang masakit. Tinanggal nung dating mayari yung buong housing(yung mukhang drum) ng filter and replaced it with those simota filters na kadalasan nakikita natin sa mga sedans..yung parang cone yung dulo...yung bang sa Isuzu Elf swak pati yung housing?
    Apr 2006
    #1653
    I'm also on the look out pala for those "buttones" for the interior..yung nakalagay sa sidings natin, yung parang mga bilog...i think el dorado have those pero 80 petot ang isa.....baka lang may alam kayong mas murang alternative hehehe...thanks in advance mga bossing!
    #1654
    Ganun ba boss? Medyo set na tuloy yung mind ko sa IDA-X001. Kaya lang, walang EQ. bahala na. Makagala sa banawe itong weekend, baka meron na dito.
    hehe.... lumalaki na ulo ko
    #1655
    Nyeekkkkkk!!!! Ay susmaryosep! Paktay tayo diyan. Siguro best bet mo will be surplus shops, kaya lang japanese version makukuha mo. It will fit, kaya lang im not sure kung magkano yung presyo ng filters.
    #1656
    hehehe, suwerte nga tayo boss meron pang available nito. Ang nakakainis sa mga butones na yan, sometimes, pang Gen2 mabibili mo.... iba ang kulay sa Gen2.5 (light gray vs. med Gray).
    Jun 2007
    #1657
    Why thank you sir!
    Sir PK, thanks again for the input. I will change the ATF next month, together with the regular change oil.
    Apr 2006
    #1658
    Yun na nga. Hay, ipagpasa-Diyos ko na lang. Sana makakita ako ng local na filter(housing) papasyal ako sa evangelista at maghahanap....paano ba madidistinguish ang japan from local?
    salamat ulit si PK
    #1659
    Here's the jap version. notice the filter box is rather oval and opens sideways.
    yung sa local naka harap sa grille/headlights yung filter opening tapos perfectly round ito.
    im trying to google pics hehe so far no luck
    Mar 2003
    #1660
    di bale PK magagamit mo yan sa posted mong occupation.
    about sa airbox, dati nagorder ako online ng 4m40 knn filter, ang nakuha ko yung japan version gaya sa pic, naghanap ako ng ganyang airbox para magamit ko yung knn pero wala ako nakita, may pinapunta ako sa kapalangan wala rin. I ended up selling the filter dito sa tsikot, subic unit yung kanya kaya nagamit niya. imho mas maganda yung airbox ng japan version, mas malaki surface area ng filter niya compared sa local, nagcost cutting yata mitsu kasi same din airbox sa 4d56 itd ng gen 2.
