Page 77 of 330 FirstFirst ... 276773747576777879808187127177 ... LastLast
Results 1,521 to 1,540 of 6591
    #1521
    Photo of a typical tire pressure monitor system [they come in different brands but look pretty much the same]: http://www.wkjeeps.com/wk_tpms.htm
    Aug 2006
    #1522
    Mga sir,
    I wonder if anyone can help me diagnose a problem I have with my '99 Fieldmaster. Anyway, napansin ko lang na upon slowing to a speed of around 30 to 40 kph, I hear a whine/groan (whooo.....whooo.....whooo sound) at the front part of the car.
    the funny thing is, if I switch to 4 wheel drive, nawawala yung tunog.
    Has anyone experienced this? Any thoughts?
    BTW, automatic yung unit ko.
    Thanks,
    Philip
    #1523
    I'm planning to replace the stock rims of my 07 strada with ralliart. Can this tire pressure sensor be transferred to the ralliart? Or does the ralliart rims have this since ralliart naman ata ang stock rims ng fielmaster? Many thanks!
    #1524
    Quote Originally Posted by phildg2000 View Post
    Mga sir,
    Thanks,
    Philip
    That happened to me. It happened along with the dreaded 'flashing front wheel icon' symptom so I knew there was a problem with the 4x4 system.
    I just switched it to 4H for about two months since I didn't have time to have it checked. When I finally switched it back to 2H, the problem was gone! hehehe. It might have been a vacuum leak. Some of my vacuum lines were oily and had some sludge on it (maybe the sludge covered up the leak?).
    Mitsubishi claims that switching to 4H (which is designed for road use unlike the off-road only 4Hlc and 4Llc) adds only about 2% to the fuel consumption because whether or not the Pajero is powering all 4 wheels, the front drive components are still rotating at road speed. The front axle does not really freewheel unlike those on old school 4x4's.
    JET,
    Supposedly you can transfer them. But you'd need to replace the gasket if they are not in good shape already.
    Apr 2004
    #1525
    has anyone heard or used ATLAS brand ball joints and tie rod ends??? I plan to use it on my paj, i need a front end rebuild soon.
    Aug 2006
    #1526
    Wow, thanks sir Otep. It's good to know na may ibang naka-experience nito. And I also have the flashing front wheels icon. Similar to your experience, pagbalik ko sa sa 2WD after using it for weeks in 4WD, okay na ulit. then babalik ulit yung ingay so switch na naman to 4WD. Will check the vacuum lines, I guess it's worth a try.
    Aug 2007
    #1527
    Bro need some help sa 2000Pajero ko, may mga leak na A/t nya and plano ko sana ipa overhaul ang engine, saan ko pede dalhin? how much kaya estimated cost?
    Mar 2003
    #1528
    pajero peeps nagpalit na ba kayo ng wheel bearings and repack? nas 91k na kasi mileage ko di pa nagagalaw, wala namana akong naririnig or feel na kakaibang sound. dapat na ba palitan?
    jessie saan nanggagaling leak ng AT mo? sikat na taga ayos ng pajero dito si Mr. atutubo, a few pages back si pajoz nagpagawa sa kanya, super ok daw.
    Apr 2004
    #1529
    nag pa repack na ako, bought my SUVic clocked at 102T kms, did all the recommended maintenance, sinabay ko na din repacking.
    #1530
    Front bearing lang napa-repack ko. Yung rear pressed-in ata yun. Natulog yung Pajero ni woodfire sa shop ni chieffy dati para magawa yung rear bearing.
    #1531
    Wala bang battery itong sensor? Where does the sensor get its power to transmit the tire pressure?
    #1532
    Meron. 10 years daw ang lifespan.
    Aug 2007
    #1533
    Sir promdiboy , d ko sure kung saan nangagaling ang leak, kita ko lang na parati basa yung A/t nya, how much will it cost me kaya sa pagpababa ng a/t? may natanong ako na 15thou daw labor then more than 10thou ung para sa set of O-rings, papasabay ko na sana pa overhaul ng engine e, medyo may pressure na lumalabas sa ibabaw pag binubuksan ko yung lagayan nga langis habang umaandar engine nya, baka may ma recomend kang maayos mag trabaho and d masyado mahal sumingil? by the way m from cavite pala
    Mar 2003
    #1534
    mahal pala orig bearings, 1,200 x 4 daw para sa harap. repack nalang siguro muna. thanks peeps
    jessie, paquote karin kay joseph atutubo, baka mas mura,
    Aug 2006
    #1535
    Another question for the Pajero Masters.
    I would like to have my steering wheel grip redone.
    How do I remove my steering wheel?
    May SRS na kasi ito eh.
    Thanks in advance.
    Philip
    Mar 2003
    #1536
    share ko lang, grabe na pala dumi ng atf ko, 99 pajero. i drained my AT oil twice in its lifetime, 40k kms and 80k kms. im now at 91k kms. kala ko enough na yun, narinig ko lang sa katabi ko sa casa about his transmission problem, kaya napapalit ako ng filter. sabi ng service adviser, replace daw dapat filter and oil every 40k kms. check niyo rin rides niyo para makaiwas sa transmission problem, or ako lang ba nakalimot about the transmission,
    Attachment 9182
    Attachment 9183
    parang bnew na!!
    May 2005
    #1537
    How much ang gastos?
    Aug 2006
    #1538
    Guys may question ako - Meron din akong fieldmaster 2.5 , gusto sanang gawing more aggressive yung look. Meron akong nakitang modz like this plastic thingy sa ilalim ng foglamps. Meron bang shop na pedeng pag bilhan ng mga parts na to? QC,Manila ?
    Tank cover saka yung Engine Cover...
    May idea ba kayo how much would this cost?
    #1539
    Tank cover yata [for cosmetic purposes] meron sa Carryboy Banawe. If you want a functional [but not as pretty] fuel tank armor, 199 OffRoadHouse in Tondo can make 1 for you.
    JAOS items are also available from Campershells (near Carryboy Banawe). But they cost a pretty penny and the for armoring purposes, the less prettier stuff from 199 and other local fabricators seem to work better.
    The front bumper airdam is available from A-Toy West Avenue. No idea on price. I think Garage Custom in Libis also sells them.
    Aug 2006
    #1540
    Thanks for the info bro. I saw the website of jaos meron nga silang local distro dito sa pinas. Sana wag ganon kamahal
    May problema nga pala ako sa steering, may wierd sound " Eeeeeeeeeeiiiiiiiiiiiiiing" lalo na kung ilalabas ko sa garahe. Is this normal? But after running a few kilometers wala na sya. So I asume thats normal because cold metal contracts then kung mainit na expands lolz.
