Page 58 of 195 FirstFirst ... 84854555657585960616268108158 ... LastLast
Results 1,141 to 1,160 of 3899
    #1141
    Your absolutely wasting your money run them both 10,000kms. Some vehicles will have black oil no matter what unless you have true 2 micron bypass filter. Cumming diesels here in the states turn the oil black in 1 day even with a synthetic media filter. That's just how it is. But they still do 12000km oil change intervals.
    Thanks doc. Maybe thats just how CRDI's is, non CRDI's are not as dark as observed.. And gas engines remains as golden oil for a long time.. I'L just stick to 5k filter interval on manual just to be safe.
    Quote Originally Posted by regor_nono View Post
    Hi 12vdc,
    Is that a DIY oil catch can? Where'd you get it? TIA!
    Just a regular water filter pero pwede din sa oil. Available at ace or handyman. Here's the thread of DIY http://tsikot.com/forums/nissan-cars.../index152.html
    #1142
    Hi 12vdc,
    Dec 2011
    #1143
    Quote Originally Posted by joeasp View Post
    it is a cartidge filter body, you can find it at Ace Hardware. Best installed reverse that of the water filtration normal use. Just insert a tube/pipe to direct the flow downwards first before it exits otherwise it'll just short circuit the flow. The objective is for the blowby containing mist will downward until the bottom and when it it flows upward the oil droplets will be left behind by gravitational pull. The longer cartridge the better.
    Nice! Saw one in Ace, I guess they're too tall for my engine bay, but I did saw a short one that could maybe fit. So you take out the filter, and place a long tube almost bottoming out in place of it?
    Dec 2007
    #1144
    Those are 100% Baldwin filters, there has not been a issue with Volmax with Baldwin Filters, That Bosch filter looks like crap compared to the Baldwins, No crimped gaskets, some weird plastic looking thing in the first part of the filter, wonder if that's part of the bypass section or not. Plus far less flow since it has fewer holes for flow. The overseas Bosch are not the same quality as the US made filters. Would be interested on what that looks like cut open.
    #1145
    Thats why i call it the largest OCC. I've installed a pleated media and still observing if downpipe will be needed.. Here's the link for my mod http://tsikot.com/forums/nissan-cars.../index152.html
    #1146
    Quote Originally Posted by paj4x4 View Post
    Thanks CB. Ill try out Top1 soon. Although Ill most likely get from the states. A lot cheaper. I get Mobil 1 FS oils for the LC's at only about $20 for 4.73liters/5quarts. So ill also get the Mobil TDT oil from there.
    OT - I'm not selling my extra set of tools for our Gen2.5. I'm keeping it as a spare set. PM perazi in 4x4ph. He sells these from time to time. Will pass on the aluminum rad for the 4m40. I have an ongoing restoration project - restoring my dedicated trail rig now - Samurai - so funds are reserved for that.
    sir im also thinking of ordering oil in the US and have it shipped here. i wonder if i have ship it via balikbayan box? i also PMed perazi already a few days ago hehe only waiting for his reply
    dvldoc there is a cut open picture of bosch oil filter a few pages back. its also a locally bought oil filter. i will try to look for the oil filter part number of the 4M40 engine for the Royal Purple oil filter counter part. and have it shipped here nalang
    Dec 2007
    #1147
    Royal purple does not have a filter to fit the 4M40, it's not a common sized filter used in the US.
    Quote Originally Posted by miked View Post
    as promised, here is the bosch oil filter 986 af1 036:
    bypass is circular compared to vic which is hexagonal iirc
    no gasket crimps
    bypass section held by "that wire"????what's that?
    Here is the post of miked. This is a Bosch for the 4d56 engine. But it can also fit the 4m40 but it's smaller so I don't think it should be done if you're gonna use it for more than 5,000kms.
    At least Bosch is better than Vic.
    Jan 2011
    #1149
    sir paj4x4, interested to know how you can get the oil from the US. most of the airlines does not allow this even sa check-in luggage. pag ship naman online, almost the same price na din compared dito dahil sa shipment cost. TIA.
    #1150
    changed oil sa mitsubishi ko today. pinalitan ko na yun idemitsu ng Mag1 5W-40 european formula full syn. smooth naman. observe muna FC kung mag improve. ito specs nun oil
    Inspection Data
    Specific Gravity * 60°F (15.6°C) ASTM D4052 0.8507
    Viscosity * 40°C cSt ASTM D445 76.77
    Viscosity * 100°C cSt ASTM D445 12.95
    Viscosity Index ASTM D2270 170
    Pour Point °C (°F) ASTM D5950 -45°C (-49°F)
    Color ASTM D 1500 2
    Cold Cranking Simulator at (°C), cP ASTM D5293 5266 (-30)
    High Temperature / High Shear Vis at 150°C, cP ASTM D4683 3.7
    Noack Volatility, % loss ASTM D 5800 10
    Calcium, wt. % ASTM D 5185 0.26
    Zinc, wt. % ASTM D 5185 0.102
    Phosphorus, wt. % ASTM D 5185 0.092
    Sulfur, wt. % ASTM D 4951 0.19
    Boron, wt. % ASTM D 5185 0.007
    Nitrogen, wt. % ASTM D 4629 0.089
    Pumping Viscosity at (°C), cP ASTM D4684 28,400 (-35)
    Gravity, °API ASTM D287 34.83
    TBN, mgKOH/g ASTM D 2896 9.8
    Ok ba to mag1 dvldoc? salamat
    Dec 2007
    #1151
    Looks like a pretty solid oil, but that depends on what your using it for, for a diesel engine I would use something with a better API rating. especially if it's a older diesel. Zinc is 1002ppm and Phos 920ppm and 7ppm boron great oil for a gas engine though. and TBN of 9.8 is not bad but most Diesel oils are 10 and higher. I would not use it in a vehicle that does not have roller lifters like most older diesels do.
    But as I said perfect for any modern gas engine.
    Jun 2004
    #1152
    Thanks Doc. Good to know I got genuine Baldwins.
    I have the Bosch oil filter now on the Pajero Gen 2.5. Since it's not that good I'll stick to just 4,000 km OCI for now. Will extend it to 8,000-10,000 km with the Baldwin BD 28.
    Also got today from Superior Motors 2 Wix oil filters - a 51515 for the LC 80 and a 51348 for the LC 100. I'm now collecting oil filters like you Doc. Hehe.
    Doc, for the LC's I've been using Mobil 1 High Mileage Fully Synthetic oil. API rating of SL/CF. Is this a good oil? What Group/Class does it belong to? On a Toyota OEM oil filter + Mobil 1 HM FS oil I do a 6,000km OCI. Can I extend this to 12,000 km OCI with the Baldwin, Fleetguard, or Wix filters? Thanks.
    Jun 2004
    #1153
    Hi CB. I do send my Mobil 1 oils via Balikbayan box. From time to time I also include Castrol/Mobil 1 Hypoy/Hyphoid Gear oils for my rigs differentials. No issue naman. I use either Manila Forwarders or Alas. Been doing this since 2002. Charge is about $70 for the jumbo box. I have a friend in LA who gets the oils from Walmart (in 4.73 liter/5 quart bottles) and he packs it properly in the Balikbayan box. The forwarder then picks up the box from his house and ships it to my Manila address.
    Shipping takes about 4 weeks on average - delivered straight to my house. Takes longer during the Christmas season. HTH.
    Jun 2004
    #1154
    Quote Originally Posted by tuazon7 View Post
    Hi. Airlines do not allow oils even sa checked in luggage. Don't ship it on line. Ship it via a jumbo Balikbayan box. I'm able to get 9-10 bottles (4.73 liters/5 quarts per bottle) + at least 10 to 15 one liter bottles of gear oils into one jumbo Balikbayan box. Cost of the jumbo BB is only $70. So the value equation is still very good. The Mobil 1 FS oil in 4.73 liter/5 quart bottle cost only about $20 in Walmart stores - that's only P900 for almost 5 liters.
    #1155
    thanks doc. im using it for my 04 outie
    Aug 2011
    #1156
    Any feedback to W&L? Do they sell fake fleetguards like Pacer?
    Dec 2007
    #1157
    Well the fake Fleetguards are rampant, You just have to inspect what they are selling before you buy it.
    Aug 2004
    #1158
    doc, i'm currently using RP 10W-40 for my altis. what oil would you recommend as an alternative for RP? i'll be using BT223 for my next oil change (10000kms OCI). thanks.
    Almost P234/liter. Indeed its a good deal. hmmm
    Group buy anyone. hehehe
    #1160
    Yes sir, but still best if you fit in a longer casing. Remember the longer the flow upward the better chances of leaving behind those oil droplets.
Remote bypass oil filtration
