eto yata idol. part no. P7406
JS Filters :: Application Cross Reference and Image for JS : Oil (Element) : OE0071
dvldoc
Re: Remote bypass oil filtration
Parts masters are about as good as wix so 10000klm is no problem. for the td27 I would use the B7022 you can find it. its also the same filter for the Td42 engine. These engines to include the QD series have internal bypass valves so u can't us a B2.
I would also find a better oil that oils tbn is crap. You want at least a 10 for the tbn. I would for a good diesel oil that has under 1200ppm phosphorus so u can use it in gas engine. you will get way more engine protection.
*dvldoc
Sir can you please enlighten us why we cant use B2 for QD32,TD27 and TD42 engines as you stated above?since B2 is the equivalent also of LF551A.TIA
Because nissans have the oil bypass in the engine, You have to use a filter without a internal bypass valve on those nissan engines. So there is no way of knowing what the stock bypass setting which i have tried to find out, it should not make a difference because either one will send it into bypass mode, there would be no oil starvation issues but I prefer to use the correct filter set up.
What baldwin is the best application for my adventure 2011 model ?
Prefer oversized yet fits perfectly on the slot
Thanks
Ilan oil capacity ng adventure 2011 ? Thanks thanks sorry too lazy to backread.. Need to buy now na eh..
hirap pala hanapin nung volmax hehe. Okay lang ba na parating DGU gamitin sa vios?
