Quote Originally Posted by regor_nono View Post
Hi 12vdc,
Is that a DIY oil catch can? Where'd you get it? TIA!
it is a cartidge filter body, you can find it at Ace Hardware. Best installed reverse that of the water filtration normal use. Just insert a tube/pipe to direct the flow downwards first before it exits otherwise it'll just short circuit the flow. The objective is for the blowby containing mist will downward until the bottom and when it it flows upward the oil droplets will be left behind by gravitational pull. The longer cartridge the better.
