Page 60 of 67 FirstFirst ... 1050565758596061626364 ... LastLast
Results 1,181 to 1,200 of 3899
    Sep 2013
    Ang bypass valve ng para sa corolla around 14 psid by pass valve. Pwede ka mag 8psid or 20 psid.
    Yung 30 psid masyado na malayo.
    Aug 2013
    Quote Originally Posted by chookchakchenes View Post
    From what I've read sa mga forums about filters, bpv will only engage if media is fully clogged. Yun bang very dirty ang oil na hindi change for a long time at driving condition is very severe, dusty, may fuel dilution, heavily sludged engine, in short, present lahat factors para clog ang filter, wala naman ganun ang engine ko.
    For three months, very normal ang gamit ng walang bpv, what more kung meron pa, kahit mataas ang setting. Confident ako sa high capacity property ng Baldwin compared sa other commonly used filters locally.
    I've used 8 psid bpv filter before, B131, maitim agad oil, think ko, easily engage ang bpv, passing unfiltered oil at high rpm.
    Just my experience...
    Posted via Tsikot Mobile App
    Sep 2013
    Ok sige interested din ako kung ano effect. Nabasa ko kasi dati kay dvldoc na around 6 lang daw allowance pag lalagpas sa bypass valve.
    Tataka ako sa b178 bakit mas mura sa b33 na pang corolla talaga. Eh ang liit ng b33 pero nung nagemail ako sa baldwin ang ganda pala micron filtration rating b33.
    Aug 2013
    And B178 is almost twice the capacity of B33, kung hindi ma-clog ang maliit sa one oci, ang mas malaki pa kaya... That's why, no worries for me.
    I also sent email to Baldwin, sabi, if you don't want to worry, use one of the same bpv setting as OEM, 14 psid, but also insinuate, you can't go wrong with the high debris carrying capacity of B143 and B178 with excellent filter media, unless you have a very dirty engine.
    Rule of thumb sa OP, 10psi every 1k rpm. Kung 14psi ang bpv ng oil filter, cruising at 2k rpm, kung maliit filter used at malapit na end of oci, sa sudden acceleration, say, umabot 3k rpm, maybe the bpv will engage, lusot unfiltered oil.
    Sep 2013
    Yung b243 ok din 8psi bypass valve.
    Meron pa isa mahaba 14psi by pass valve nalimutan ko code.
    Aug 2013
    Preferred ko Baldwin oil filters with 20 psid and above na bpv setting, 80 mm casing outside diameter, 65mm-70mm outside diameter ng gasket, kahit 130mm long, will fit my 4AFE.
    Sent from my HTC Explorer A310e using Tsikot Forums mobile app
    May 2005
    B1402 - Php 360 last year (dont know this year).
    Alternative
    Bosch OF415 - Php 150 (amazon)
    Alternative
    late last year parang 390 na bili ko sa 1402.
    Aug 2013
    Alternative
    bro, made in Korea Bosch filters mo? Thanks.
    naka bili kasi ako, B33 counter part ng Bosch, OF 110, made in korea. P200 per piece.
    Sep 2013
    Ano code yan bosch na 200 pesos?
    Yung b1402 nasa 350 pesos yan sa banawe seller.
    Aug 2013
    Bosch OT-041 (US) or OF-110 (Korea) halos same size siya sa Baldwin B33 at Vic 110, P200 isa.
    Bosch OT-042, same size siya sa Baldwin BT223, P200 din ang isa.
    May 2005
    It was 350 back in 2012. If I'm not mistaken, it was 320 before that.
    Quote Originally Posted by innova2013 View Post
    As for the OF415, I did not get to check its country of origin bec. I just asked the messenger to inquire.
    Not all Bosch are made in Korea. Some are also made in indonesia ie. OK 064
    Pls PM me contacts of your banawe supplier. Thanks!
    San ba makakabili ng bosch oil filters. Yung malapit sa Marikina
    Stock Engine Modified Driver...
    May 2012
    Quote Originally Posted by erick_214 View Post
    nag hahanap din ako sa Marikina area ng bosch filter. though nakita ko lang pero parang may maliit na auto supply na may signage ng bosch, malapit sa tapsi ni Vivian.
    Tol parang alam q yan huh. Sa may mlapit sa sta lucia. Orig kaya filter dun?
    May 2012
    well di ko din naman masabi kung may fake. usually na nakikita ko made in korea. nagamit ko na din once pero sa may kalookan ko nabili. sinubukan ko lang.
    sa shell marcos hiway pala, yung may Jollibee, bosch gamit nilang filter.
    sa may paakyat naman ng antipolo along sumulong parang may nakita akong service center ng bosch.
    May 2005
    For L300 4D56. Made in Korea.
    BF7534 is a bit pricey now so I needed an alternative to it and VIC.
    Baldwin looks to have a better quality both externally and internally. But remember Bosch is only Php 350 vs. triple that for the Baldwin.
    Baldwin has much better pleats than this one. Filtration material in the Bosch looks like it was rolled inside.
    Bosch dedicates about an inch space on the bottom part to serve as water storage. I don't recall seeing this kind of feature in Baldwin or VIC. I'm not if there is any benefit with this design.
    Question mga sir...if ever i remove or replace the oil filter with engine oil still present, tutulo ba pag tinanggal ko? TIA! :-)
    Quote Originally Posted by mateomarco View Post
    Nope as long as naka-off engine.
    Dagdag ka nga lang nang engine oil amounting to the capacity nang oil filter mo.
    Thank you sir RY Tower! :-)
Remote bypass oil filtration
