Results 521 to 530 of 3899
August 6th, 2011 02:02 AM #521
Royal purple 15w-40 Specs are
Iron 2
Tin 1
Alum 3
Silicon 1
Potassium 1
Moly 117
Boron 1
Calcium 2961
MG 22
Phosphorus 1126
Zinc 1213
Vis*100C 15 (SAE 40)
I don't have any specs on the Motul diesel oil but its good oil. they are so close to Mobil delvac it would be like saying what bottle color do you like better.
Here are a few more API ratings for Motul oils http://japanesemotorsport.myshopify....ns/engine-oils
For diesel engines, Mobil 1 Turbo Diesel Truck:
* Meets CJ-4, CI-4, and CH-4
* Is recommended for diesel-powered pickup trucks built by Ford, General Motors, GMC and Dodge.
* Meets diesel engine requirements of Cummins, Powerstroke, Duramax and Navistar.
Here is a good listing of oils and there various zinc contents and API ratings.. As you know excel does not show up well on forums.
Name/Vis/P(ppm)/Zn(ppm)/B(ppm)/Detergents(ppm)/API/Date/Type/Source
Castrol Act Evo 20w50 765 1126 1724 SG 05/06 DINO Staveley
Castrol GPS 4STK MC2 20w50 767 1133 1544 SG 05/06 SYN Staveley
Castrol GTX 20w50 1157 1422 1848 SM 11/05 DINO Staveley
Castrol GTX High Mile 20w50 1248 1382 1848 SM 06/06 DINO Staveley
Castrol Syntec 5w40 786 918 1979 SL 09/06 SYN Blackstone
Castrol Syntec 5w50 921 914 58 2628 SM 11/05 SYN Staveley
Castrol Syntec Blend 20w50 937 916 1197 SM 03/07 SEMI Staveley
Castrol Tection Extra 15w40 965 1094 46 2461 CI-4 3/07 DINO Blackstone
Castrol TWS 10w60 425 1294 111 2383 SJ 06/06 SYN Staveley
Chevron Delo 400 15w40 1191 1622 3668 CI-4 06/06 DINO Staveley
Delvac 1 5w40 1390 1803 76 2583 CI-4 11/05 SYN Staveley
Delvac 1300 Super 15w40 1380 1702 78 2388 CI-4 11/05 DINO Staveley
Elf 505.01 VW 5w40 584 1092 2691 SL 05/06 SYN Staveley
Mobil 1 0w40 761 876 167 2630 SM 03/07 SYN Blackstone
Mobil 1 0w40 796 907 178 2650 SM 03/07 SYN Blackstone
Mobil 1 0w40 808 976 185 3256 SL 04/03 SYN Blackstone
Mobil 1 0w40 706 834 148 2246 SM 02/05 SYN Blackstone
Mobil 1 15w50 952 1030 41 2175 SM 03/07 SYN Staveley
Mobil 1 EP 15w50 1193 1376 228 2970 SL 04/07 SYN Blackstone
Mobil 1 EP 15w50 1062 1279 79 2485 SM 04/07 SYN Blackstone
Mobil 1 EP 15w50 906 1024 72 2071 SM 01/06 SYN Blackstone
Mobil 1 EP 15w50 1315 1428 226 2593 SL 11/05 SYN Staveley
Mobil 1 mx4t 10w40 1277 1460 188 2025 SG 03/07 SYN Blackstone
Mobil 1 mx4t 10w40 1411 1623 188 2248 SG 04/07 SYN Blackstone
Mobil 1 R 0w30 1399 1536 178 3051 SG 02/04 SYN Blackstone
Mobil 1 Super Syn 15w50 1343 1390 205 2601 SL 11/05 SYN Staveley
Mobil 1 Truck & SUV 5w40 1034 1247 51 2826 CI-4 04/07 SYN Blackstone
Mobil 1 V Twin 20w50 1329 1949 204 2130 SG 11/05 SYN Staveley
Mobil 5k Clean 10w40 660 1028 2895 SM 06/06 DINO Staveley
Mobil High Mile 10w40 527 1021 2844 SM 06/06 DINO Staveley
Motul 300V Competition 5w40 1317 1409 19 3273 SH 04/05 SYN Blackstone
Motul 300V Competition 15w50 1139 1130 20 2410 SH 05/05 SYN Blackstone
Motul 505.01 VW 5w40 973 1226 2830 SL 05/06 SYN Staveley
Motul Competition 15w50 1148 1327 11 2723 SH 05/06 SYN Staveley
Motul Tekma Mega 15w40 1220 1737 145 3469 CI-4 05/06 DINO Stavel
Rotella 15w40 843 946 26 1881 CJ-4 03/07 DINO Blackstone
Rotella 15w40 996 1130 32 2054 CJ-4 04/07 DINO Staveley
Rotella 15w40 1278 1555 2946 CI-4 11/05 DINO Staveley
Rotella 5w40 1397 1552 2921 CI-4 11/05 SYN Staveley
Royal Purple 20w50 668 763 2034 SJ 02/07 SYN Blackstone
Royal Purple 20w50 1290 1337 3295 SJ 11/05 SYN Staveley
Royal Purple Max Cycle 10w40 4085 1222 2599 SJ 07/05 SYN Blackstone
Royal Purple Max Cycle 20w50 3179 1030 2142 SJ 04/07 SYN Blackstone
Royal Purple Max Cycle 20w50 3907 1458 2478 SJ 11/05 SYN Staveley
Royal Purple Racing 51 20w50 1285 1417 2639 SJ 11/05 SYN Staveley
Royal Purple XPR 10w40 1034 1741 2709 SJ 12/06 SYN Blackstone
Valvoline All Fleet Plus 15w40 1110 1232 3559 CI-4 10/06 DINO Staveley
Valvoline Durablend 20w50 566 732 13 2606 SM 06/06 SEMI Staveley
Valvoline Max Life 20w50 691 879 17 2170 SM 11/05 DINO Staveley
Valvoline Prem. Blue 15w40 1314 1838 158 4329 CI-4 06/06 DINO Staveley
Valvoline Synpower 20w50 605 689 1786 SM 03/07 SYN Blackstone
Valvoline VR1 20w50 1085 1293 17 2242 SL 11/05 DINO Staveley
Valvoline VR-1 NSL 20w50 835 976 10 819 SL 03/07 DINO Blackstone
Valvoline VR-1 NSL 20w50 842 962 11 838 SL 03/07 SYN Blackstone
August 6th, 2011 10:26 AM #522
Read more: http://tsikot.com/forums/engine-fuel...#ixzz1UCwb0hl1
- I guess this is comparable with Delvac MX. The Zn is at 1,702 and detergents at 2388. Very high indeed, close to the synthetic delvac 1. Very good oil indeed.Fasten your seatbelt! Or else...Driven To Thrill!
August 6th, 2011 12:54 PM #523
How a turd is made
God Fram suck , the only reason people buy them is because 99% of people have no clue what's inside a oil filter.
- Nov 2009
- 3,507
August 6th, 2011 04:27 PM #524^ We belong to the 1% who knows the crap inside that can.
See that gaping slit of hole between the center tube and paper element(blue arrow marker)? Dirty oyL could take shortcut in that slit. If not for the paper end caps and poor sealing, it think quality should be OK..
The two wannabee Fleetguard, though useless bypass valves would perform better than the Fram.
August 6th, 2011 09:11 PM #525
I see Pacer is still passing off fakes, but yes the fakes still look better than the Fram but that fake LF3314 has horrible wavy media, the other on has a leaf spring lol not a coil spring and a sticker vs printed for the fleetguard. For them to say them to say they don't sell fakes is laughable.
August 6th, 2011 10:46 PM #526
Hi DevilDoc:
Nice to hear from you again.
BTW, I have been reading a lot about the FASS system - its the Fuel-Air Separation System lately.
What's your opinion on this?
Is it really worth the US$700 they're charging?
Thanks a bunch,
Dusky Lim
- Nov 2009
- 3,507
August 6th, 2011 11:04 PM #527^ +1 on this doc.
My 3rd fuel filter upgrade was put on hold because of fuelling worries and im thinking of FASS to solve it.
Most diesels here dont have lift pump in the tank.. It is the fuel pump in the engine doing the sucking from tank.
August 7th, 2011 09:15 AM #528
Unless you have a 400hp turbo diesel and you tow 1000's of kilograms you don't need it. The money wasted on this you could have bought a life time supply of quality fuel filters that still filter down to 5 microns. Stick with a high quality filter. The price is not worth it especially on a 4cly turbo diesel or N/A 4cly diesel.
If you have a mechanical fuel pump it's really not worth it on a old school diesel they are not common rail systems and even the common rail diesel there like the D4D are really not that high pressure compared to a Cummins or Ford powerstroke diesel these are pushing 29000 psi (1999 bar) A D4D engine is only (1350) bar or about 19580psi so I just can't see the point of this system on any vehicle there at that price. A inline Delphi set up will do just fine or or a DIY one with a 2 micron filter that is inline prior to the factory fuel filter. You just need to find what your factory filter flows at and try to find one that has a higher flow rate.
Almost Any Baldwin will have a higher flow rate because it's a mixed media filter vs just a cellulose media or a bypass type filter. I prefer the aftermarket filter heads they just look like they flow better than the stock ones. I rather have 1/2 NPT inlets and outlets on mine for maximum flow.
I am still working on a set up for mine. Had to scrap my previous ideal due to the flow on the filters being totally different.
I could make a FASS system for way cheaper and just use one of my companies pumps which makes up to 250psi. But I really don't think the cost of $700 USD is worth it or even $350USD.
August 9th, 2011 07:49 AM #529
A good link to API specs for a variety of oils.
http://www.repowell.net/documents/pr...guide_5-09.pdf
August 9th, 2011 10:49 AM #530
I just can't seem to post pics but I tried to weigh a Vic c-313 for 4m40-4m41 oil filter and a Bosch 036 filter for 4d56 and the result is a shocker. The Vic filter is obviously taller but the Bosch is heavier. Vic is .828kg while Bosch weighs in at .832kg!
Looks like the construction and materials of a Bosch (Korea) is indeed superior to Vic. Suwerte ni CB. ;)Fasten your seatbelt! Or else...Driven To Thrill!
Because pinoy mentality. Not surprising.
