^yung cartridge type filter magkakaroon na din Baldwin?
may nakabili na ba dito nung glass bowl water separator kit kay berrima? or baka may iba pang store na nagbebenta neto?
tsaka hindi pa ako nagagawi kay volmax. once a month e nagagawi naman ako recto/binondo area kaso nawawala sa isip ko bumili ng filter ke volmax. san ba banda yung gandara st? ayaw lumabas sa google map e. salamat
Bosch OM 036 for L300 4D56 is now made in Vietnam (used to be Korea).
Looks and feels a bit inferior vs. korea made.
How much is the bosch OM-36?
If the price difference from BD28 is just little, better get the Baldwin na.;)
Posted via Tsikot Mobile App
Natakot ako sa bosch nung nabasa ko post ni japanabc regarding bosch na may "class a class b"
Marami daw subcon ang bosch. Yung mga cheap bosch hindi sariling planta pag-gawa ng wiper blades at oil filter.
Kahit pa madei in korea, thailand or indonesia bosch filters basta pasado naman sa standard nang parent company then wala problema. Fakes ang problem if meron.
Mas maganda performance nang bosch kesa Vic based sa experience ko eh, although mas lamang talaga baldwin. Walang kagaspang-gaspang yung oil eh.
Bosch OM 036 - Php 350.
BD28 - Php 9xx ? ( I think).
Price is quite far. ry is correct in stating baldwin is 2.5X of the price of OM 036
Not all Bosch filters are made in the same area. Some are made in Korea, Vietnam, Indonesia and other areas.
Question po about filter size for my Hyundai Santa Fe
Currently using Mobil 1 Extended Performance Oil Filter for my Hyundai Santa Fe 09 CRDI. Rated siya for 15,000 miles according sa website ng Mobil 1.
Specs
Compared sa OEM Hyundai, mas shorter yung outer diameter niya ng half and inch and about 3/4th inch shorther siya vs OEM pero sa gasket at thyread size same sila ng OEM. Currently been using it for about 5000 kms and so far not seeing any leaks.Provides long-life performance for today's longer drain intervals
Effectively removes contaminants, with a 99.6 percentage Multi-Pass Efficiency Rating and an advanced synthetic fiber blend media
Holds double the contaminants compared to other filters, with 28.0 grams of total capacity
Withstands nine times normal system operating pressure, for exceptional protection up to 615 pascals per square inch
Prevents dry starts by eliminating internal leakage during shutdown through the use of a silicone anti-drain back valve (where required by OEM)
Question ko is since mas maliit yung Mobil 1 kesa OEM oil filter, mas superior pa din ba ang filtering efficiency ng Mobil 1 at mas malaki pa din dirt holding capacity niya vs oem kahit mas maliit body niya?
Any alternatives for VIC C-226 (oil) and FC-226 (fuel) filters? Medyo hindi widespread yung sa oil filter ko kasi 1-12 UNF ang thread size nya.
Guys,
I live in the province and I want to get a Baldwin (or even Fleetguard or any good oil filter) for my Innova.
Do you know any seller/supplier who can ship the item even at my expense?
Someone contacted me (also a seller in olx) but of course, like everyone else, I want to make sure his stuff are genuine.
Thanks!
(Any suggested physical store is also appreciated especially near Alabang or Calamba Area)
ang laki nga nung b2 compared sa dating filter. bigger filtering medium, better filtration. malapit nga lang sa exhaust pipe, dapat may heat shield![]()
