*dagol
Let's clear up engine oil sludge, there are specific things that cause this to occur.
There are several ways for sludge to form in your engine. Water gets into the crankcase through condensation and blowby from the combustion chambers. Water mixed with oil takes on the consistency of thick, pus-colored foam. You'll know it if you see it.
Walang winter don sa pinas at di naman malamig sa texas.
ineral oil is subject to sludging thats why im recommending it.
Fortunately, small quantities of water evaporate from the crankcase as the engine warms up and the oil temperature gets above 212 degrees, which it does after a few minutes on a freeway. However, if you only drive short trips, your crankcase never gets hot enough to evaporate any accumulated water, and in such an engine, sludge formation seems certain in its future.
No winter in philippines,remember.
Sludge can also form if the oil gets too hot. At temperatures above 250 degrees, nonsynthetic oil starts to oxidize. Such oxidation thickens the oil and produces acidic byproducts. The process accelerates when the oil temperature hits 300 degrees, and the result is something more akin to tar than oil.
Kaya synthetic ang gamitin to avoid this
The final cause of sludge is simply the passage of time. Tiny particles of soot get by the piston rings and end up suspended in the oil. So do various acids formed by the products of combustion. Oil contains additives designed to neutralize these contaminants, but eventually, enough of this foul stuff builds up to compromise oil's lubricating qualities. Manufacturers conduct tests to determine this contamination and specify oil-change intervals accordingly. And therein seems to lie the cause of the sludge problems.
Again with your safeguard,este fleetguard
Most new oils are designed to help keep the soot particles suspended in the oil in larger particles so they are caught by your filter. This is why just having good oil alone without good filtration is totally useless.
The Kuliglig,remember?
Contamination of lubricating oil by diesel soot is one of the major causes of increased engine wear, especially with most engine manufacturers opting for Exhaust Gas Recirculation (EGR) technology to curb oxides of nitrogen (NO,.) emissions. The diesel soot interacts with engine oil and ultimately leads to wear of engine parts. It's know as soot loading. The soot also raises combustion temps which raises engine oil temps which wears out your oil faster.
Not that much ash content on diesels now
How clean do you think his oil is when you have intakes looking like this, and most don't know because they never check.
This is a Nissan Patrol, how many soot particles do you think sneak past the oil rings and into the oil. Remember if your filter is not efficient like a VIC then your just liquid sandpapering your internals.
unmaintained engine
Filtration matters just as much as the quality of oil you use for longer engine life you can't have one without the other to have maximum benefits.
Oil catch can is one of the best investments you can make on any vehicle, the recirculation of crankcase dirty oil laden air is one of the worst things for your car or truck. Even a cheap 100P inline fuel filter place in the tube to the PVC valve or connector on a diesel will keep almost all of that from being pushed back through your intake and increasing how much soot goes back into your combustion chambers.
