Page 5 of 67 FirstFirst 1234567891555 ... LastLast
Results 81 to 100 of 3899
    Jun 2005
    thanks doc! you've been very helpful as always!
    Jun 2005
    SAE Study Shows Superior Filtration Leads to Reduced Wear and Costs
    guys, check nyo ito. very interesting read. it discusses most, if not all of our oil and filter related question. hehe
    Jun 2005
    any news on fleetguard user/handle?
    its been a while since his last post... i thought he wanted to clear some issues thats why he subscribed to this thread?
    Dec 2007
    Oil specs for AC Delco oils carried in the Philippines.
    Kwikparts - Primary supplier of automotive parts in the philippines
    AC Delco oils are pretty good stuff espcially for gas engines. The Diesel oil is CI-4. Don't know the prices.
    PRODUCT PRODUCT TYPE API RATING
    SYNTHETIC 5W30 1 LITER select mineral oil SL/CI
    SYNTHETIC 5W40 1 LITER supreme plus 100% synthetic SL/CF
    SYNTHETIC 5W40 4 LITER supreme plus 100% synthetic SL/CF
    SYNTHETIC 5W50 1 LITER supreme plus 100% synthetic SJ/CF
    SYNTHETIC 5W50 4 LITER supreme plus 100% synthetic SJ/CF
    SELECT MINERAL OIL 10W30 1 QUART select mineral oil SM
    SELECT MINERAL OIL 10W30 4 LITER select mineral oil SM
    SELECT MINERAL OIL 10W40 1 LITER(Limited stock) select mineral oil SM
    SEMI SYNTHETIC 10W40 1 QUART supreme semi-synthetic SL
    SEMI SYNTHETIC 10W40 4 LITER supreme semi-synthetic SL/CF
    DIESEL MULTIGRADE 15W40 1 QUART select mineral oil SL/CI-4
    GASOLINE MULTIGRADE 20W50 1 QUART select mineral oil SL/CF
    AC Delco formula is very close to Mobil super.
    I also happened to find a dealer for Autorx engine cleaner, This is some extreamly good stuff for getting your engine cleaned out.
    Auto-Rx (Philippines) | Contact Us
    It's pretty much one of the best engine cleaners your going to find, Very popular on the bob the oil guy forum. I have used it over the years as well.
    dvldoc, i've been reading a lot about autorx. and it seems to be a good product. a bit expensive lang at 1,500pesos for a 300++ml bottle.
    Dec 2007
    Yes it's not cheap but worth it especially on a older engine with higher miles. Especially on diesels. It's about 20USD back in the states.
    Something good to add every couple of years. I think it's worth it, not something you need to do ever oil change or anything like that. You just need to change your oil and filter after 800km after adding it.
    if it will be every few years, i think its not going to hurt the wallet hehe
    dvldoc, for your elgrand, what diesel oil are you using and how is your change interval?
    I called up volmax marketing regarding baldwin oil filter and fuel filter, and totoo nga, the first thing they asked eh kung taga-forum daw ba ako. i told them yes, so i guess siguradong real thing ang ibibigay nila because if not eh Todas sila dito sa forum. Nakakatuwa lang kasi this forum really helps
    Quote Originally Posted by zix888 View Post
    :hysterical: Ayaw nila malagay na naman sa goon squad section.
    Lahat ng mga fakers dyan beware, we are behind you ika nga! Lalo na si TS.
    Jun 2005
    nagtataka nga dati yung sa volmax, manny ata name kung bakit dumami bumibili ng baldwin bigla pati yung bt223 na dati di nauubos eh biglang dumami bumibili. sabi ko pinaguusapan kasi sa tsikot.com. hehehe. ayun binigyan ako calling card. itawag ko daw muna kung may bibilhin ako para di sayang byahe ko at baka wala sila stock...
    Jun 2007
    Malaki utang nila kay dvldoc....
    (they owe it all to dvldoc)
    4d56 oem mitsu oil filter after 5000kms
    zix, may oil filter cutter ka?
    Dec 2007
    The filter held up well, and the quality looks goot. The oil is pretty black but I guess those engines just run dirty, I would do a oil catch can and EGR blockoff to clean that up a bit.
    dvldoc, i think what zix has is the 4d56 crdi version. blocking off the EGR would light the check engine. and it would increase the EGT unless he will also install and EGT gauge.
    Crazy_boy is right, i have a vgt crdi engine. Any other option?
    Dec 2007
    Do the oil catch can for sure then.
    Wala sir, manomano lang ginawa ko, lagareng bakal lang
    Nearing 25k pms, makikita na natin yung loob ng baldwin . Nagtanong ako ng wix sa superior motors, walang pang 4d56. Next in line sana yung wix para madissect din natin after use. Anyone who knows kung saan may makuha?
    Jun 2004
    Very informative thread dvldoc. I've shifted to Bosch from Vic oil filters for my Gen2.5 Pajero Fieldmaster (4m40). Would you know of the Bosh, Baldwin, or Purolator oil filter equivalent for the 1FZ-FE engine (80 Series Landcruiser) and the 2UZ-FE engine (100 Series Landcruiser)? I currently use Toyota OEM oil filters on these rigs. Thanks.
Remote bypass oil filtration
