Results 1,831 to 1,840 of 2348
- Apr 2009
- 429
September 11th, 2012 11:28 PM #1831thank you, sir dieseldude. I will have the van re-checked this week...
- Sep 2010
- 47
September 22nd, 2012 08:39 PM #1832Sir dieseldude, tanong lang po.ung trooper skyroof ko po.ng vibrate kahit idle (park or neutral) pro pag nilagay sa drive nababawasn pero bg vibrate pdin.
Pag umaandar naman ok nmn pro pag umabot ng 60 to 80 nagvibrate ulit. Pag bitaw a accelerator nawawala kahit sane speed parang kailangan pa I tyempo ung apak.ara di umalog.ano po kaya problema.salamat po
- Sep 2006
- 1,335
September 26th, 2012 12:22 AM #1833
- Sep 2010
- 47
September 29th, 2012 09:12 AM #1834
- May 2010
- 9
September 29th, 2012 12:49 PM #1835hello sir dieseldude,
The injection pump on my L300 4d56 is leaking diesel fuel. I was advised to bring it to a competent diesel calibration shop. Mahina lang naman po yung tagas and it is not continuously leaking. Is it still safe to use the van on short trips? Is there a chance that the leaking diesel will ignite?
Worst case scenario, can you provide an estimate on how much the repair will cost?
Thank you and more power!
- Sep 2006
- 1,335
September 29th, 2012 12:57 PM #1836
- May 2010
- 9
- Sep 2010
- 47
- Jul 2005
- 430
October 4th, 2012 08:47 AM #1839Sir Dieseldude,
My 2000 4m40 pajero (55,000 km mileage only) low idles when engine is cold. I have to turn on the aircon to reduce the vibration. Namamatay din paminsan minsan but pag uminit na ok na. I had the tank cleaned and filter replaced and umayos naman for a while but after a month or two bumalik ulit. Malakas din sa Fc at around 4km/l. Kailangan na kaya calibration nito? My mechanic recommends his friend na nagkakacalibrate para daw makamura. Ok lang ba ang small calibration shops compared to the bigger establishments like Central or Denso? How long is the process? Kailangan ko ba iwan ang car?
- Sep 2006
- 1,335
October 6th, 2012 11:09 PM #1840Sir Dieseldude,
My 2000 4m40 pajero (55,000 km mileage only) low idles when engine is cold. This is normal.
I have to turn on the aircon to reduce the vibration. Your idle-up compensator is working.
Namamatay din paminsan minsan but pag uminit na ok na. I had the tank cleaned and filter replaced and umayos naman for a while but after a month or two bumalik ulit. Malakas din sa Fc at around 4km/l. Kailangan na kaya calibration nito? Injection pump has to be evaluated. It may need servicing.
My mechanic recommends his friend na nagkakacalibrate para daw makamura. Ok lang ba ang small calibration shops compared to the bigger establishments like Central or Denso? Any workshop, small or big is okay as long the shop is properly equipped, trained, and tooled to do the job. More important is that the workshop should have the necessary calibration data for your particular injection pump. The pump is adjusted to conform to a specific test data. Proper pump calibration assures you of optimum power and fuel consumption, as well as clean exhaust emissions.
How long is the process? Kailangan ko ba iwan ang car? Approx 2 days.
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
