Results 1,501 to 1,510 of 2348
- Apr 2011
- 198
November 21st, 2011 06:23 PM #1501hello po
ask ko lang po kung papaano ang function ng turbo.kapag nagwhistle po ba dun lang gagana tnx
- Sep 2006
- 1,335
November 21st, 2011 11:35 PM #1502
- Apr 2011
- 198
- Apr 2011
- 198
November 30th, 2011 06:38 PM #1504hello po curious lang po ako sa mga fx na may auxilliary fan.ano po ba ang gamit nito.tinululungan po ba ang clutch fan para lumamig ang engine lalo kapag overheat?tnx
- Sep 2006
- 1,335
November 30th, 2011 09:29 PM #1505
- Apr 2011
- 198
- Aug 2011
- 9
December 14th, 2011 04:25 PM #1507Good afternoon
Ask ko lang po, everytime i'm starting my 2005 XUV manual (cold start) kailangan ko pang i adjust ung idling switch (at least 75% or full) or sasabayan ko ng sunod sunod na tapak sa accelerator, if not, mag i start sya pero mamamatay din agad? Sa cold start lang naman po. Pero kapag mainit na ang engine ok na, malakas naman ang hatak ng xwind ko. (regardless if newly changed oil, changed filters na).
Pina adjust ko ang idle so nag OK sya, pero after 2 weeks bumalik na naman ung problem. Since binili ko di pa ko pa napapacheck ang nozzles and injectors.
Thanks in advance
BTW, sir dieseldude san location ng shop mo?
December 14th, 2011 11:24 PM #1508
Good day sir dieseldude.
I just wanna ask kung bakit malakas kumain ng diesel ung 3.0 1kz-te namin na van???ano po kaya possible problem???it does 4km/ liter...konting tips naman po.
TIA!:-)
- Sep 2006
- 1,335
December 15th, 2011 09:38 AM #1509
- Sep 2006
- 1,335
December 15th, 2011 03:57 PM #1510Good afternoon
Ask ko lang po, everytime i'm starting my 2005 XUV manual (cold start) kailangan ko pang i adjust ung idling switch (at least 75% or full) or sasabayan ko ng sunod sunod na tapak sa accelerator, if not, mag i start sya pero mamamatay din agad? Sa cold start lang naman po. Pero kapag mainit na ang engine ok na, malakas naman ang hatak ng xwind ko. (regardless if newly changed oil, changed filters na). I would say this condition is normal as your car is not originally equipped with a cold-fast idle device. An idle control knob installed on your dash so that you can manually adjust low idle speed.
Thanks in advance
BTW, sir dieseldude san location ng shop mo? I will PM you....
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
