Results 1,511 to 1,520 of 2348
December 15th, 2011 08:25 PM #1511
~thx po sa reply...ok i'll check the air filter and replace if so...also the turbo is good...unless the injection i dont know how to check if its ok or not. Sir diesel dude my chance ba na sa nozzle din ang problem pag malakas na sa diesel? Wala pa naman po ako
napagawa sa engine and no black or any smoke po pala.:-)
- Sep 2006
- 1,335
December 16th, 2011 01:20 AM #1512
- Aug 2011
- 9
December 16th, 2011 08:56 PM #1514
~ok sir dieseldude thx alot for your reply and suggestions. I really appreciate it.;-)
December 20th, 2011 11:58 PM #1515
sir dieseldude what could be the problem of my pickup..
yung usok niya is white yung kulay ayaw na mawala kahit hugasan ko yung
muffler w/ water..
nakakahiya kasi lalo na pag umaandar makikita talaga na nag ppuff yung smoke +
pag naka idle din..
- Sep 2006
- 1,335
December 21st, 2011 11:19 PM #1516sir dieseldude what could be the problem of my pickup..
Ano ang make, model, and mileage ng car mo?
muffler w/ water..
1) White smoke when engine is hot or cold?
2) Kelan nagsimula ang problem?
3) Ok ba ang power?
4) Kamusta ang oil consumption?
pag naka idle din..
December 22nd, 2011 12:26 PM #1517
isuzu model 1994
matagal na siya pero dati medyo black pa siya pero nung nilinis ko yung muffler
medyo white na siya tapos persistent na yung white smoke...
kahit hot and cold yung engine ganun pa rin yung smoke.. ok naman yung oil consumption walang leaks..
yung power naman ok rin
- Sep 2006
- 1,335
December 23rd, 2011 10:40 AM #1519
dieseldude,
i have a problem with my local pajero with 4m40 engine. my car used to run just fine. but this morning, nag hard starting siya. 2 clicks bago mag start. then nung tinakbo ko na, parang nag misfire siya. nung naging normal operating temp na, bumalik na sa normal running condition.
what could be the problem?
walang ginawa for the past few days. except for loading up with Petron diesel last night. diesel being used before is seaoil diesel.
thanks!
- Sep 2006
- 1,335
December 23rd, 2011 07:42 PM #1520dieseldude,
i have a problem with my local pajero with 4m40 engine. my car used to run just fine. but this morning, nag hard starting siya. 2 clicks bago mag start. then nung tinakbo ko na, parang nag misfire siya. nung naging normal operating temp na, bumalik na sa normal running condition. what could be the problem?
This could be a sign of an injection pump going bad which is quite common to 4M40 engines, or a faulty glow plug system, or even both. We see a lot of these....
thanks! You're welcome..... Merry Christmas!!!
