Results 2,001 to 2,010 of 2348
April 15th, 2013 01:48 PM #2001
Hi DD, my innova will finally reach 40K km reading in odo after more than 5 years. Other than fluid changes recommended by casa, will you recommend egr cleaning? There is a very slight change in fuel consumption from the usual 10.5kpl to current 10kpl, city driving. Other than this, no performance issues whatsoever. TIA.
- Sep 2006
- 1,335
- Sep 2006
- 1,335
April 16th, 2013 11:25 PM #2003would blanking plates sa EGR ng D4D engine cause any issues?
I don't think so.
would it help in fuel consumption sir and pass the emmission tests?
Effect on fuel consumption will be very minimal. It will pass emission opacity test if smoke is reduced.
However it will fail exhaust gas analysis if NOX is measured.
thanks sir Dieseldude
You're welcome.
- Sep 2006
- 1,335
April 16th, 2013 11:30 PM #2004
April 17th, 2013 07:49 PM #2005
- Sep 2011
- 18
May 3rd, 2013 04:32 AM #2006Hi..Question lang po..ano magandang brand ng Synthetic Oil for Diesel Engine? regular naman yung change oil namin..pero i want to try other brands..baka mas gumanda yung performance..or kung may combination okay din..lagi na lang kasi sa Toyota..hehe TIA!
- Nov 2010
- 369
May 3rd, 2013 11:45 PM #2007May thread na tungkol dyan. http://tsikot.com/forums/engine-fuel.../index138.html
- Feb 2010
- 13
May 6th, 2013 03:48 PM #2008I own a 2003 Isuzu Crosswind AT. Had it's nozzle cleaned about a month ago, together with the fuel filter and sedimentor. After this, I noticed na medyo "sakal" yung power. Found out from the calibration center that I went to, that when the nozzle's were cleaned, the "pressure" was set to 180 instead of the 185 recommended by isuzu. According to the mechanic, hindi daw ito yung possible cause nung "sakal" na power. Mas ok nga daw yung lower setting kasi it means masmadali daw pumasok ang fuel dahil sa lower pressure. Is this true?
the mechanic thinks its the injector - baka kailangang linisin na daw. (air filter is about 3 months new pa lang. wala namang restricted sa air supply). When the mechanic steps on the pedal, napansin nya na hindi agad nagre-respond yung engine. Floored na yung pedal pero di pa "sumisigaw" yung engine...parang humahabol pa lang yung combustion (kaya parang sakal nga yung power).
Could the culprit be the wrong nozzle setting or the injector?
Appreciate any inputs. Also, can you PM me if you know of good calibration centers near Marikina, Sumulong HW - Cainta, Katipunan-C5-Aurora or nearby areas?
TIA
- Nov 2010
- 236
May 7th, 2013 01:09 PM #2009had the same issue with my 4jx1 trooper 6km/l city driving and 8km/l highway,black smoke on high prms and a bit white smoke in idle... decided to clean the intake manifold sobrang daming carbon deposit lalo na dun sa may bandang egr....and also done the tambutso cleaning,,, for almost a month now my city driving is 8km/l and 10km/l highway and no more black and white smoke...im planing to blocked the egr para hindi na gaanong dumumi ang intake manifold...im no expert just personal experience...
- Sep 2006
- 1,335
May 8th, 2013 10:04 PM #2010I own a 2003 Isuzu Crosswind AT. Had it's nozzle cleaned about a month ago, together with the fuel filter and sedimentor. After this, I noticed na medyo "sakal" yung power. Found out from the calibration center that I went to, that when the nozzle's were cleaned, the "pressure" was set to 180 instead of the 185 recommended by isuzu. 5 bar deviation from specs won't cause a low power problem.
According to the mechanic, hindi daw ito yung possible cause nung "sakal" na power. Mas ok nga daw yung lower setting kasi it means masmadali daw pumasok ang fuel dahil sa lower pressure. Is this true? Your mechanic is partly correct. It would still be best if pressure is set to specs.
the mechanic thinks its the injector - baka kailangang linisin na daw. Injectors don't need checking if they were properly serviced just a month ago.
TIALast edited by Dieseldude; May 8th, 2013 at 10:13 PM. Reason: correct text
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
