Page 47 of 70 FirstFirst ... 3743444546474849505157 ... LastLast
Results 921 to 940 of 1387
    Aug 2014
    #921
    How much?
    Gaano katagal ginawa?
    From 1pm to 6:30pm.
    Mar 2018
    #922
    Quote Originally Posted by ericb View Post
    Pinapalitan ko din yung parklight to LED bulb and pinagawa kong DRL hehe.
    Possible ba if simply doing this without the need for a retrofit?? I mean is just changing the stock park light bulb to LED bulb and convert it to a DRL?
    TIA.
    Jul 2012
    #923
    I installed Mini H1 7.0 all morimoto set. Morimoto quality is good, but the price was premium. You can get the same performance with NHK counterparts for almost half the price.
    Aug 2014
    #924
    TIA.
    Madali lang po palitan yung bulb, kahit hindi retrofit. Kelangan lang alam nung gagawa kung paano ilipat yung wiring ng parklight para naka on sya palagi.
    Mar 2012
    #925
    Stage 3, Philips D2S yung bulbs (need to check the receipt for the exact type) and 4300k yung temp. Comes with a 3 year warranty (for the stage 3)
    At 4300k that would be the base model 85122.
    Quote Originally Posted by Kimchijiji View Post
    May hint ba ng pagkablue ung light output?
    Yung blue hue na makikita usually sa may cut-off banda is called color flicker normal yan sa mga properly installed hid projectors.
    Aug 2012
    #926
    TIA.
    Just change them to LED bulbs and turn them on during the day, then you already have a DRL. Rewiring is just done if you want it to be Auto on/off with engine.
    Or use an Automatic Multi-function LED DRL Controller like the one I use.
    Sent from my ASUS_X00DDA using Tapatalk
    Feb 2017
    #927
    TIA.
    I think pwde, you may approach the retrofitters for those. Hehe sayang naman kung dka pa papa retrofit. Pwde mo nga pakopya ung headlight ng 2.0v kundi ako nagkakamali
    Mar 2018
    #928
    Thanks for the reply good buddy.
    Some questions lang:
    1) Ilan watts ang LED bulb to be installed to be a DRL? Brand of LED also?
    2) Madali lang ba ang rewiring so that pag on ng engine naka engage na yun DRL? How about yun park lights sa tail lights? Pag na rewire na for DRL, naka on pa din ba yun park lights sa tail lights?
    Many thanks!
    Aug 2014
    #929
    Many thanks!
    I actually have no idea on the technicalities sir. AFAIK may wiring harness pa na ginamit si redline dun sa DRL ko.
    Yung harap lang yung naka DRL sa akin.
    Aug 2012
    #930
    Many thanks!
    1. Any watts. It won't matter because LED bulbs consume very little power versus regular bulbs anyway.
    2. Yes, madali lang specially if you use a DRL controller. Ganito ang gamit ko.
    DRL is for the front only. Hindi kasama ang park lights sa tail lights.
    Feb 2017
    #931
    By xenon concepts. Highly recommended
    Stage 2.5 hella g5r projectors. Kudos sir Pao!
    Jun 2014
    #932
    Quote Originally Posted by nixce View Post
    Sir, Hm na po inabot ng stage 2.5 ni xenon ung walang kasamang drl? Salamat!
    Feb 2017
    #933
    Quote Originally Posted by captneo View Post
    12500 sir!
    Mar 2018
    #934
    Quote Originally Posted by red_one View Post
    Follow up question lang good buddy. So I need a new unit of DRL mod for this kind of configuration? Entirely an add-on?
    I was just wondering kung say yun sa "park light bulb" upgrade lang ang gagawin to make it like a DRL sort of set-up?
    My apologies for the inconvenience on my questions since baka possible lang na ganito.
    Aug 2012
    #935
    Yes, it is possible. Just tap your park lights (LED bulbs) to Ignition/Engine Power
    fuse. I will use a piggyback Fuse Tap Holder for this purpose. Use new bulb sockets if you don't want to cut the original park lights wiring.
    The DRL will turn on when engine is on. The DRL will turn off when engine is off.
    Mar 2018
    #936
    Many thanks!
    #937
    Ito bayung kotse mo na wrap around sunbloc ultimate clear blue?
    Kahit naka clear tint kailangan padin hid retrofit?
    Malabo parin ba sa night driving yung sunbloc ultimate clear?
    Plano ko rin na ipa wrap around ng ultimate blue yung pick up ko, para di nako magpa hid
    Baka hidi iwarraty yung bcm pag nasira kung naka hid or led.
    Feb 2017
    #938
    Correct ako din yun sir and yes naka clear blue tint padin ako. For your questions, i would like to answer them and im happy to help.
    Naka h4 osram NB laser ako before retrofit, ok lang sila, they are good, but I prefer white light output. Pag tag ulan, patay na ang lahat, good thing my tint is clear to help me through the rain.
    I took the upgrade kasi i wanted to have white light output. And i want more intense lighting.
    To my surprise, it EXCEEDED my expectations, picture doesnt justify my experience.
    Bcm errors for ford sabi ni sir Pao, kayang kaya naman.
    Ang hinayang ko lang is what if i opted for the better stage 3 hella g5 EXL projector, i might see better pero so far, i am super satisfied with his works and the stage 2.5 rocks!
    Super sulit and really, day and night ang difference.
    Jan 2017
    #939
    this os what 5500 looks like
    #940
    Thanks,
    I am still undecided, Im looking for a better night driving visibility without sacrificing safety.
    Here are my current options;
    Upgrade to HID/LED, keep 3M BC20 tints
    1. Xenon Concept HID retrofit stage 2.5 with angel eyes - 14k.
    2. Vanguard 6000k led, bulb upgrade only, with bcm specific resitor/canceller module - 8k
    Change tints, keep stock lights.
    1. Sunbloc Ultimate clear-blue wrap around - 6k
    2. Better heat rejection than 3M - Sunbloc non-ultra wrap around - 17k
    3. VKool VK40 windshield only - 7k.
    Of the two major options, upgrading the headlight is the riskiest, because bcm is not cheap.
    Resistors heats up during prolonged use and may break in time.
Planning on getting an HID retrofit
