If budget permits you to upgrade to OEM spec ballast, why not right?
I'm using NHK ballast (the ones included with xenon concepts package) ok naman so far. But will upgrade soon if mag-fail ung ballast or if out of warranty na siya.
yung description mo sa pag gamit ng auto-on ng HL mo ay walang naman problema. ang ibig sabihin ng nabasa mo is yung frequent flashing nag gingamit ang HL to sgnal the on coming vehicle.
You'll be fine if for passing tunnel lang ang reason mo para palitan or up grade ang system mo ay hindi practical. Well unless gusto mo talaga mag upgrade ng HL mo.
Sent from my SM-J710GN using Tapatalk
Hi Sirs,
Question lang, can I still put vent Halos (110mm) in an Apollo 2.0 Shroud if I will be using Bi-Xenon Morimoto Mini D2S 4.0?
TIA!
sir does this mean its best to leave aftermarket retrofit hid of auto on/off headlights to auto?
For example daytime drive (off) passed by a 2 second tunnel (on) then out of the tunnel drive around 10 seconds (off) to covered parking to park for 5 seconds (on) then engine shut off.
On that above scenario, a hylux ballast would still theoretically hold its rated lifespan of 25000 hours? TIA
Available na kay xenon concepts un nhk g5 ex
Sent from my R7plusf using Tapatalk
Kung kaya i-swap out that is. Hehe. Pero liit na lang siguro ng difference pag naka-g5 ka na
