Results 451 to 460 of 1387
- Jul 2017
- 50
September 28th, 2017 02:42 PM #451yun din po sir iniisip ko. pero who knows? baka name po nagpapamahal, same as android and ios. mejo mas fluid lang ios pero ang mahal
pero sa ngayon po na wala pa po akong masyadong choices. stick muna ako kay HIDRetrofit. mukhang bang for buck talaga e. pero kung may iba pa pong options. kindly let me know. thank you po sainyo!
September 28th, 2017 02:46 PM #452
I had my HID done at Redline and have been very happy both with their installation and aftersales service. Stage 2 for my Mazda 3 for 19.5k with Q5 projectors, NHK bulbs, and ballasts.
No leaks inside the headlight, excellent aftersales service when they cleaned my lens after it showed poor cutoff, no fuss on the warranty claim when one of the connectors gave out prematurely.
While I'm very happy with their service, I'm curious to know why Xenon Concepts can offer the same package at half the price.
OT: The Note8 costs as much as the iPhone X ($999) so the Android vs Apple argument doesn't really hold water anymore.
- Jul 2017
- 50
September 28th, 2017 03:05 PM #453sir do you have a pic for your setup? I'm a bit curious.
also why do they clean your lenses sir? does it moist? because THAT is my primary problem in my HL. can those shop remove "that" moist before installing their retrofits?
I searched for Redline, but can't find any site or what the shop look like. are they trustworthy sir?I've somewhat learned my lessons in a shop in banawe, but it's a long story.
September 28th, 2017 03:19 PM #454
Exterior shot of the headlamps:
Output on the road:
They cleaned my headlamps because the car is 13 years old and the headlamp housing has degraded over time, making the lighting output hazy.
The moisture on headlamps is caused by imperfect sealing of the headlamps. When they retrofit your headlamps, they will apply new sealant. I have not experienced moist headlamps with Redline's work.
You can search Redline Auto Works on Facebook. Their shop is located in White Plains and is certainly a far cry from the shady shops in Banawe.
September 28th, 2017 03:33 PM #455
kanya kanyang marketing mga shops sir yung iba finish product na pina pakita yung iba pinapakita during opening of HL. Check mo page ng Firedrake or Chroma lights. IMO hidretrofit and redline are usually at the top of the conversation medyo pricey nga lang. Xenon concepts is known for its budget friendly price.
yes sa provinve ako nakatira pero nung una akong nagpa retrofit pina lbc ko HL ko to manila.
DIY mo yan sir?edi stock HL housing pa rin po gamit niyo?
Wala pong site ang redline. Sa mga retrofitter sa pinas hidretrofit lang ang meron website dahil sila yung pioneer shop sa pinas in retrofitting. Na feature na rin sila sa top gear philippines.
Redline is also a good option and hindi na sila bagohan sa retrofitting. They have handled a few hundred cars including luxury cars. And yung unang stage 3 retrofit ko is redline ang gumawa.
- Jul 2017
- 50
September 28th, 2017 03:36 PM #456sir do they have options where the shrouds is like devil/angel eye?I really do like good light quality together with "porma" since I will only change or replace my HL setup once, I want it to be all in one.
Output on the road:
thank you sir for showing me your setup and giving me ideas. much appreciated!
September 28th, 2017 03:40 PM #457
Yes, gagawin naman ni Redline yang mga angel/devil for you for an additional charge. Personally though I prefer a cleaner OEM look.
Low beam yan. High beam is even brighter. I actually intentionally underexposed the photo to show the width of the lighting but in person it was brighter than that. My car has good light output even during rains. Kaya mahina lighting mo before because it wasn't a real retrofit - talagang mahina ang plug and play HID/LED especially if reflector headlamps lang.
Hindi liblib ang White Plains. Sobrang mahal na subdivision nun and private subdivision yun which is probably why there isn't any Google Streetview.
Sent from my SM-N9208 using TapatalkLast edited by jut703; September 28th, 2017 at 03:50 PM.
September 28th, 2017 03:43 PM #458
I'm also curious. Ang pagkaka alam ko mga NHK bulbs, ballast and projectors ang ginagamit sa mga entry level ng mga shops.
If same lang ang parts na ginagamit sa 10k-12k ng xenon concept or firedrake then it would be intersting to know kung anong parts ang gamit sa medyo pricey na mga shops.
- Jul 2017
- 50
September 28th, 2017 03:43 PM #459siguro sir stick na lang muna ako kina hidretrofit and redline, kahit pricey, mukhang safe and high quality naman works nila. mahirap na at baka ma banawe na naman ako. haha
yup DIY lang sir and I'll still be using my stock HL. medyo modify lang cguro ang mounts since magka iba ang stock HID projector ko kaysa mini d2s 4.0.sana marunong din ako mag DIY, kaso pag about sa wiring mukhang malabo para sakin. kahit sa motor minsan nagogoyo ako kasi wala akong gganong alam. hahaha.
so bali ikaw magaassemble sir? devil eye yung sainyo sir diba? may mga ganung style kaya sila hidretrofit or redline? meron mga samples sa hidretrofit site kaso yung HL lang ang pinapakita, di pinakita yung output niya once turned on.
- Jul 2017
- 50
September 28th, 2017 03:53 PM #460sir yung projectors ba satin may feature na "daylight"? yung parang sa mga bagong model nang cars ngayon na may led light na naka open day or night. like dun sa ecosport namin. always open yun. yun kasi madalas kong nakikita sa mga nakakasalubong ko na naka projectors e.
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
