Results 951 to 960 of 1387
- Sep 2009
- 387
July 10th, 2018 01:40 AM #951I was of the same dilemma and considered relatively the same options. I tried the cheapest and got 2 pairs of XHP70 (12K Lumens, 5k kelvin) for HL and fogs (around 8k php).
I ended up installing the leds only as HL. It's significantly brighter than the stock osram bulb. Visibility is way better, using 3m heavy btw. I no longer find installing led on fogs necessary, will just use the extra pair as back up.
- Mar 2013
- 6,160
July 10th, 2018 07:26 AM #952I couldnt do a backread but i really want to upgrade the lighting output of my 2017 LC200.
Will a bulb change do? Both my LC's have medium tint all around.
I used to go to GaryQ of HIDRetrofit for my needs but havent been happy with the pricing and all the leaks and niggles after a few months (jazz, trailblazer).
Sent from my SM-N950F using Tapatalk ProLast edited by EQAddict; July 10th, 2018 at 08:37 AM.
July 10th, 2018 11:04 AM #953
HID projector po ba or LED projectors ang 07 lc200? If you want higher wattage ng HID bulbs kasi then you have to change the stock ballast din. If naka LED naman palit ka pa rin ng driver. You can try lens swap muna but bubuksan pa rin ang HL sa procedure na yan.
Yung strada ko naka 25w HID projectors na which IMO is better than the stock LED projectors of the totl monty pero pinalitan ko parin lahat(projectors, ballast and bulbs) dahil di ako satisfied sa output stock HL ko.
Di po ba na rectify ni garyq yung leak sa HL nyo? Most of the shops ngayun ok naman mga installs nila. Or baka pinag igihan lang ng mga reputable shops ang services nila ngayun dahil medyo iilan na rin sila ngayon unlike before na garyq lang talaga option.
- Feb 2003
- 1,038
July 10th, 2018 11:18 AM #954Saw the works of Firedrake ...oks naman, branded ballasts, bulbs. projectors gamit nya and based from his FB feedback oks naman daw. Paid a visit to his former shop malapit sa mazford and they are quite meticulous naman sa workmanship. I think they transfer now to a new location. As for pricing medyo mataas din ang pricing nya but yun nga due to branded materials their using, unlike other shop na mostly china products. If budget is not an issue this is a good choice.
- Feb 2017
- 53
July 11th, 2018 08:22 AM #955
- May 2012
- 129
July 11th, 2018 09:05 AM #956
July 11th, 2018 09:44 AM #957
Kung na tanggal kasi sa mount ang adjusting screw kahit anong pihit mo wala talagang galaw ang cut-off nyan. Minsan makikita mo medyo naka yuko na ang projector mo.
Yung philips xvc1 ko 175usd bili ko sa TRS mismo nung napunta ako ng US dun narin ako bumili ng morimoto projectors and ballasts ko sa kanila. Meron na gen2 ang philips xv ngayun I think meron sa firedrake last I checked sa FB nya.
- May 2012
- 129
July 11th, 2018 11:36 AM #958Salamat sir sa info, sana maayos na, madalas ko kasi gamit talaga pag nauwi kami province
Mahal pala talaga bulb sir, pero same lifespan lang ba?
July 11th, 2018 12:18 PM #959
If same lifespan ng NHK yung tanong mo compare sa philips personally di pa ako naka gamit ng nhk bulbs but as what i've read sa hidplanet forum at sa headlight junkies FB group mas maaga pumuputi yung color temp output ng nhk kesa mga osram or philips that means pag mag start na mag change or pumuti ang output after a couple of years, unti-unti na rin nawawala ang effectiveness nya. But dont confuse that color change sa brandnew bulbs like mga 4300k color temp dahil medyo yelowish yan on the first few hours na gamit mo and medyo puputi ng konti yan as the bulbs gets a break-in effect pero di ibig sabihin nun na pa sira na ang bulb mo.
7months pa lang sa akin yung xv so cant say anything about sa lifespan. Pero what I can tell you is yung philips 85122 ko sa previous vehicle ko na benta na lang until now di pa nag palit ata ng bulbs yung naka bili na vehicle ko after about 4-5yrs service ng bulbs and to think na mas cheaper na model ng philips yun if compare sa xv.
- May 2012
- 129
July 12th, 2018 12:51 AM #960Thanks sa info sir, antayin ko nalang mapundi to nhk hehehe, laki difference sa price
White kasi napilik ko color kaya medyo nakaka silaw talaga, kaya need talaga naka align
yeah i'm not a fan of those things :twak2: but probably just a 2-terminal epb that could be...
VinFast VF 3
