I had it installed by xenon concepts. The osram cbb came from me though. For what its worth, sulit nung first test drive.
This is WAAAYYYY better than the stock HID ng everest.
Osram CBB is 88usd plus shipping. Ordered and delivered here by amazon.
Yes. Figured it was the same if I used shippingcart or johnny air cargo. It was delivered around 8 days. Pwede na rin.
*Lin Dan,
No glare and excellent cut off. Although it cant be help na masilaw ung mga ibang sedans (especially the lowered ones) since this set up is installed in an SUV. As you can see doon sa isang picture with the silver sedan, di naman abot sa side mirrors nya.![]()
Haha laser kasi doesn't spread out eh. Pin point siya. Pang high end brands lang talaga un.
Curious ako sa mga 3rd generation na bi-led projectors. Wiling to try if the price is right.
San mo pards nabili ballast at projector? Upgraded na ng hid fog lamps ko. Hindi ko na maxado maramdaman low beam headlight ko. Planning to upgrade it too. May nakita din ako nagpalit langng clear lens. I wonder kung applicable sa stock fog.
*applicable sa stock projector ng low beam.
Useless to use the stock ballast of the everest since its for D8S bulbs only and it is only rated 25w.
Got the nhk can-bus ballast kay xenon concepts since I got the G5-EX from him also.
If you want a step upgrade lang, meron sa shopee na D3S system (bulbs, wiring and ballast) for around 2.5K. Ung difference lang ng D3S and D8S bulb is the lock ring lang. Minor modification lang pasok na un. At least ung D3S system can be had at 35W so significant improvement there too.
