Page 14 of 22 FirstFirst ... 4101112131415161718 ... LastLast
Results 261 to 280 of 424
    Jan 2010
    #261
    hello guys, newbie here. just want to ask kung ano kaya problema ng lite ace ko kasi kahit na may gas ung auto ko eh bagsak pa rin ung fuel gauge ko (minsan nman eh umaakyat sya pero most of the time eh bagsak). hirap din kasi para akong nanghuhula kung may gas pa ako or wla na talaga kaya most of the time eh karga ako ng kahit 200 just to make sure na may laman sya. ang sabi ng iba eh baka may problema sya sa float, d ko pa napapatignan sya kasi bababa daw ung fuel tank nya to check. ask ko lang kung magkano kaya parepair ng ganitong problema and if you have a reputable shop na pwede ko puntahan to have my car check? TIA...
    Jan 2010
    #262
    patingnan mo floater sa tank..dudukutin yun.titingnan yun continuity kung ok pa..pero kung sira na papalitan yun.
    1,800 ang fuel floater gauge orig yun parts kaya 3 days ang order time nun. ,,bahala ka na kung san mo ipagawa.ako kasi tito ko lng naggawa nun sakin.
    Jan 2010
    #263
    sa partstar pasay ko binili yun orig floater gauge,,kuha monalng sa yellow pages yun tel #nila..pag oorder ka may deposit na dapat kasi order yun sa toyota eh.
    Jan 2010
    #264
    hello guys, thanks for your reply...another question that i would like to ask is if you have encountered na nauubos ung tubig nyo sa radiator ng ganun kabilis. meaning from QC (likod ng SM North) to Espaņa eh halos kalahati agad ung reading ng temp gauge ko? ano kaya ung dahilan nun? im planning to go to a radiator shop para mapatignan ung cause nya kasi hindi naman dati ganun ung behavior ng auto ko dati na antaas agad ng temp. any help and tips will be highly appreciated, thanks in advance...
    Jan 2010
    #265
    *joma
    check your radiator maybe its already clogged with dirt.,radiator fan ,water pump ,thermo switch baka di gumagana..
    try mo irebolusyon yun car na walang radiator cap,,pag palabas yon tubig baka may head gasket leak/blown na yan,,for top overhaul na yan.consult your trusted mechanic.
    #266
    tinatamad na ako mag ayos ng liteace ko. meron bang tipong home service para dun sa bahay ko pagawa di na kasi ma start talaga eh
    Jan 2010
    #267
    *quest uy
    baka low bat lang ,try mo itulak para start.
    question ko,
    di umiilaw headlight ko,,nakita ko may nahulog na fuse sa fuse box.di ko alam kung saan bando ko dapat maikabit yun.alam niyo ba diagram nun fuse box ng lite ace?ayaw ko tsambahan baka may masunog pag mali kabit.
    #268
    Quote Originally Posted by mcrens86 View Post
    *quest uy
    question ko,
    di sira na starter.. kahit san talyer naman kaya nila palitan no? :P di ko kasi mapadala sa talyer kasi di na naandar
    #269
    *quest uy
    question ko,
    yung takip makikita mo san dun yung fuse para sa headlight and ilang amp.
    Apr 2009
    #270
    guys need your help sa 96 gxl all power liteace....
    nabili ko lang last march, nasa 5km/l lang ba talaga fc nya? pinalitan ko na jet from 120 to 100 pero ganon pa din..bagong tune up na...
    ano pa pwedeng gawin para tumipid?
    tnx!
    #271
    Quote Originally Posted by JJGF View Post
    tnx!
    I once had a '94 LiteAce GXL, power windows but no power steering. From my experience malakas talaga sa gas ang LiteAce specially kung pipilitin sya tumakbo ng mabilis at mabigat ang karga. Underpowered kasi sya for its weight at maliit pa ang stock rims.
    Since yung LiteAce mo may power steering, mas malakas sya sa gas kasi may extra load sya na dinadala (power steering pump).
    Apr 2009
    #272
    ^ tnx! may kakasya kaya na diesel engine para dito na bolt-on lang?
    #273
    I'm not sure, maybe...ang problema lang kung yung mga ganong makina na bolt on ay available locally. Let's wait for other people's opinion.
    Apr 2009
    #274
    hhmmm mag inquire ako sa lpg.... ayaw ko sana ibenta, may project kasi ako na i-lift, lagyan ng a/t tires para ready na sa tag ulan pang hatid sundo sa anak ko sa school
    sa totoo lang mas enjoy ako idrive to kaysa sa MS
    Apr 2008
    #275
    hi sa lahat, pasingit
    hinge ako tulong,
    problem ko sa liteace namin, bigla na lng tumataas temp nya, kahit malapit lang byahe. nawawalan/natutuyuan ng tubig yung radiator, napupunta sa reserve.
    ano kaya problem don?
    takid ng radiator or sa reserve, or sa thermostat?
    Aug 2009
    #276
    baka sira na yung goma mo sa radiator cap....try to replace it with a new one....
    Aug 2009
    #277
    Quote Originally Posted by joemariperez View Post
    check mo radiator cap mo baka worn out na yung rubber.....regarding sa fuel guage mo pa check mo yung wiring baka may loose lang kaya nagkakaroon ng intermitent yung supply ng kuryente papuntang floater....
    Aug 2009
    #278
    toyota 2c turbo engine....
    Apr 2010
    #279
    mga sir,
    anong diesel engine ang pwedeng ilagay sa lite ace? thank in advance.
    #280
    Mga Bro's Try Inquiring for a toyota 3c-turbo engine only thing needed to change is the engine mount and have a bellshousing for your 5k trany to mate the 3c engine. I've done it now I can even achieve 19.2 km/l sesible driving here in cebu about 70-90 km/h speed.
Toyota LiteAce Owners & Discussions Thread [Merged]
