good evening peeps. i have a 93 gxl liteace. so far wala talagang problema. since 1993 2x lang nag raise yung temp nya. pero i cant say overheat kase pina admit ko kaagad sa shop. also yung aircon cold talaga. low gear lang talaga yung liteace pero for me sulit sya for the family. yung tanong ko lang is where kayo maka bili yung hydraulics nya sa baggage? kase whenever buksan ko yung baggage mag slowly close sya. parang weak na yung hydraulics nya. do you have any idea where i can buy one? im from cebu by the way. thanks!
problema ko rin 'yan dati, pero pinagtiyagaan ko na lang na ganoon kasi hindi naman gaanong nakakaabala. mahal kasi sa casa, ang tanda ko mga 7k+ at inoorder pa. 'ung sa evangelita makati naman, hindi na rin magaganda 'ung mga binebentang surplus. suwerte ka kung makahanap ka ng maganda-gandang surplus.
Guys may alam kayo san ok mag palinis ng gas tank and fuel pump dito sa paco manila? feeling ko yun yung kailangan ng liteace para gumana eh :P
Thanks,
Good day po, newbie here, can somebady help me what is wrong sa van ko. 80km/hr lang kayang ihatak, napa change oil ko na at palit n rin mga filters, pati spark plug using bosch platinum +. Nu rin po un JET? at sbi ng mekaniko palitan na ang clutch disc, pressure plate, release bearing. Mgkano po kea magastos jan? Kakainis po kz lalo n s 1st at 2nd gear ingay ng makina pero d makahatak. Thnx po
not an expert bro.. based on experience lang 'to.. ahmm.. kahit ba i-floor mo na yung gas mahina pa din yung hatak?
pwedeng palyado na din yung makina.. try mong pa-tune up.. for the parts that you'd mentioned.. i think he's reffering about your clutch parts.. baka manipis na yung parts mo jan..
pwede ding throttle body.. try mo palinis..
Robinhood,
Para ma-check natin kung kelangan na talagang palitan yung clutch system mo, ganito gawin mo:
1. depress clutch and brake pedals fully;
2. shift mo kambyo to 2nd gear;
3. using your right heel, depress slowly ang gas pedal, pero naka-diin ka pa rin sa brake pedal;
4. slowly release mo yung clutch pedal.
Kapag namatay ang makina mo, it means ok pa yung clutch disc mo, pero kung di namatay at nag-slip lang yung clutch, well, palitan mo na. Usually it'll cost you more or less 6K. Balitaan mo na lang ako...![]()
sir mcgyver ty s tips, try ko bukas at balitaan ko kau if ano results hehe sana mamatay para d me gastos, la pa me kz budget para rito. Un jets pala if ulitin ko tanong sa inyo wat does it mean? Feel ko my kinalaman un sa makina kea mabagal. kz savi nun may ari dati inadjust daw eh para makatipid. ewan ko kung ano un hrap wla alam s makina grrr. thnx in advance![]()
hi van lovers,
i also had a 90 model liteace, nung una naranasan kong tumirik kc nagoverheat nung naka aircon ako sa trafik sa cubao, then pina ayos ko, at ang ginawa sa condernser ko since katabi ng radiator inilipat ng gumagawa ng aircon sa left portion sa baba, at pinadagdagan ko ng malakas na auxi fan with separate switch para pag pumalo ung gauge swicth on ko lang yung auxi fan nacocool down na ung temp. so far lamig naman ng aircon ko thankful lang ako kc ung gumawa sa aircon ko ay napakagaling at hindi pa nananaga ng presyo. regarding naman sa bouncy movement ng lite ace ok naman ung sakin cguro weak na yung shock o ung suspension bushing kaya bouncy na.
sa experienced ko sa liteace basta lang may tamang mekaniko ka na nagseserbis sa mga parts like: cleaning of breakshoe and pads, cleaning or replacing your contact point and condenser, cleaning your carborador with carborator cleaner, cleaning of sparkplug, checking the fuses and ligth bulbs etc.. etc.. i think smooth sailing yung van nyo, tulad nung sakin, i recommend na kumuha kayo ng magaling na mekaniko at sya na ang mag maintain para alam nya yung in and out ng van. ofcourse supportahn ng konting budget, magastos talaga ang may second hand na sasakyan pero pag alaga mo naman kahit papano hindi ka ipapahiya ng sasakyan mo.
syempre hindi naman perpekto na yung pag aalaga ko, di lang namin makitakita ung coz ng amoy usok na naaamoy sa loob, chinek na namin lahat. pero paminsan lang kapag mabilis ako, pero pag nasa 40-60 ung takbo ko Ala namang amoy usok, at may isa pa minsan amoy gas naman, tipid naman sa gas kc pinalitan ko ng jet. malakas padin yung hatak... baka may alam kayo na cause nung amoy usok at gas tru your experience with your aprubal may i solicit a recommendation and solution to this matter. thank you.
AYZ,![]()
Kung nangangamoy gasolina, I suggest ipacheck yung carburator at fuel lines. Kung saan dumadaan ang fuel mula tank hangang engine, may maliit na tagas siguro.
Kung amoy exhaust naman, check nyo yung buong exhaust assembly mula headers hangang dulo ng tail pipe. Check nyo din yung underside ng sasakyan kung saan nakatapat yung exhaust piping, baka may butas na tumagas na sa body mismo ng sasakyan. Delikado sa pasahero yan, baka ma-carbon monoxide poisoning kayo.
hi gusy.... may idea pa ba kayo kng ano pa ba problem ng liteace ko?
nag palit na ako ng carb pati fuel filter pag start pa rin namamatay pag tumagal. tapos hirap na mag start ulit... pero after a day ma iistart mo ulit. pero namamatay ulit..![]()
mga bossing,
may problem po ba kung ang gas consumption ng liteace ko ('92 model) ay 8km/L sa city drive un and 10km/L long drive?
from Fairview po ako, bka meron kayo trusted na mekaniko near our area for our liteace...
maraming salamat sa inyo.
gud am.. up natin.... ako problem ko ngayon sa liteace ko may bumubuga na parang foam na maitim sa aircon ko. minsan lang naman hindi parati.. do i need cleaning na?
liteace peeps pwede bang palitan ng 5 lugs ang liteace natin parang sa mga 4wd na litea ace? and pwede din bang lagyan ito ng TEMS(toyota electronic modulated suspension)? magkano po kaya ang set nito front and back, pati saang surplus kaya meron? tia!
