Bro.,- for my Innova VVTi, i usually fill it up at 5.25L during oil change.... Sa dipstick, nasa gitna na ito ng min and max points...
Talagang ini-ingatan ko ito with the technician dahil maliit lang kasi ang additional volume ng oil between the min and max points in the dipstick,- kaya kung 5.6L malamang nga over na sa max.
based on our experience with our various cars in the past, the difference between the lower and the upper marks in the oil dipstick, is one liter's worth.
I would recommend that bro....
Tama si doc,- dapat malaki ang (additional) volume ng oil between min and max points...
But the Innova is a bit weird in my limited personal experience... I will also check if it's in the manual as warning....
Related experience- I was actually checking my notes,- my first runs were "should be less than 5.5L" as this is max already- that was my log during year 2010,- and so I settled at 5.25L later, which is the halfway point...
Thanks. Bawasan ko siguro ng mga .2liter.
So okay lang sya kahit a little less than max level?
Also i would need to replace my front and rear shocks and I found this store in banawe called LVC selling KYB for 2100 front and 1150 rear. You think its okay?
Thanks!
Thanks!
Okay lang siya basta between min and max... Should be no worry.
Bro.,- KYB or 555 should be okay.
What's the mileage of your Innova? Dumadamba na ba?
Changed my rear shocks at 35KKm...
Front shocks - still original,- mileage is at 50KKm...
Check the alignment of the front wheels,- baka mapudpod... Sakit ng Innova iyan....
Nag drain ako ng isang cup ng oil and okay na sya, nasa max level.
33K mileage ng Innova ko, matalbog na yung front and may rebound pag bagsak ng hump. Pina check ko and may leak na daw both front shocks. Yung right rear may leak na rin daw.
Fluid type ba original shocks ng Innova? i was wondering how the ride would be if nag replace ng gas type.
