Page 603 of 775 FirstFirst ... 503553593599600601602603604605606607613653703 ... LastLast
Results 12,041 to 12,060 of 15487
    May 2009
    #12041
    Meron na sa inyo naka-try nun Toyota Air Care service on your Innova?
    Toyota Air Care Service | Toyota Abad Santos - The Dealer of Choice!
    Aircon evaporator cleaning without the need to remove the dashboard/panels, and finished in about an hour.
    Kasama po ba cleaning ng rear AC evaporator?
    Saang dealer yun pwede mo bantayan yung gumagawa, and stay in the service area (just to be sure they are taking care of your car and not doing anything unnecessary)?
    TIA.
    Nov 2014
    #12042
    It happens more often than not. Except for a few instances, all my car batteries pretty much die that way. Typical situation for me is that it would start fine in the morning, but by the time I'm about to leave the office, I get a couple of slow cranks then 'click'. One other time, it's the opposite... arrived home the night before with everything seemingly normal, but died the next morning.
    Motolite Gold.
    That's the mystery...none of these signs ever happened to me prior to leaving my Innova with Toyota Commonwealth. And yes, that too is their standard reply--"It happens." I already accepted that they will not own-up to this. They just lost one customer. But hey, I'm just one.
    May 2010
    #12043
    orig color po ng ng innova ang Flaxen Metallic?
    Sent from my SM-J700H using Tapatalk[/QUOTE]
    Jun 2009
    #12044
    i just replaced my 4years and 3month old Motolite Gold.
    i had the shop check the battery charging with the engine turned on. halos 12V lang...dapat around 13++ volts daw.
    aside from CASA, saan ba pwede ipacheck alternator ko? yung recommended shops niyo sana. around QC/Caloocan Monumento ang area ko.
    thanks.
    #12045
    Quote Originally Posted by desertfox615 View Post
    thanks.
    i go to yock's. but it's in pedro gil, paco.
    May 2010
    #12046
    Ano po ba ang possible reason bkit nagchecheck engine? Pag ka on p lang ng sasakyan ok naman but after 5 mins sa daan iilaw CEL niya at pansin ko rin when i hit 80 parang taas baba rpm kasi yung feeling na parang kumkadyot unti pero di nman daw nasyado ramdam passenger pero ikaw n driver ramdam mo e.
    Btw, nagpaservice pla ako ng aircon khapon tapos after that nung ginamit ko na umilaw na CEL.
    Jan 2012
    #12047
    Quote Originally Posted by matt chua View Post
    TIA.
    I don't think evaporators can be cleaned (cleaned correctly that is) without removing the dashboard. These are just below the panel. The recommendation outside casa is to change the evaporators rather than cleaning them. (cheaper to replace than to clean)
    tia
    #12048
    Quote Originally Posted by 1natzt View Post
    tia
    they can, sir. i had mine replaced because it sprung a leak. the dashboard wasn't even loosened.
    ..had it done in banawe... beside the vioses whose dashboards were removed. yun daw ang hindi magagawa kung hindi tatanggalin ang dashboard.
    cleaning the rear evaporator is something else.. removing the covers and the rear folding seat is not really complicated, but it is time-consuming, heavy and bulky.
    Jun 2005
    #12049
    AFAIK sa first relase ng innova nung 2005, sanden pa ang aircon. Pwede matanggal yung evaporator by dukot method. Yug sumunod na models, tanggal dashboard na
    #12050
    Quote Originally Posted by sirkosero View Post
    perhaps you're right.
    mine is a 2005 model. second shipment daw.
    May 2010
    #12051
    Quote Originally Posted by piscesboy View Post
    pa up lang, possible reasons bakit may check engine light? napalitan na fuel filter pero ganun pa rin nagchechek engine after few minutes sa daan, pag kaka on palang sasakyan at nakaidle lang hindi naman lumalabas check engine light.
    Jan 2012
    #12052
    That's interesting to know po. Is there a way to see the front evaporators without removing the dashboard? Having these replaced before, I took out the old ones and cleaned them up, but failed due to corrosion.
    tia
    #12053
    1st gen here, how to reach and remive front evaporators without removing the dash?
    Katay talaga in order to remove it eh.
    Katakot tingnan.
    Jan 2012
    #12054
    yes po, but denso na din po yung 2005 G models kaya di na din madukot yung evaporators.
    tia
    May 2009
    #12055
    Thanks to those who replied regarding evaporator cleaning.
    Mukhang madugo yung cleaning process nga based sa info na binigay niyo na need talaga tanggalin dashboard for proper cleaning, then may risk na hindi mabalik mabuti yun dashboard or may something na masira afterwards.
    We never had the evaporator/AC of our 2013 Innova cleaned since we bought the car. Palit ng AC filter lang every year. I was thinking if having it cleaned since it is already 3 yrs. old, or wait for it to lose its cooling power before having it checked/cleaned.
    May mga nabasa kasi ako sa ibang thread na same lang yun gastos and effort of having it cleaned regularly (e.g. every year), vs. having it replaced in when it fails.
    #12056
    tia
    they removed the glove compartment box. then they reach in thru the opening and under the dash, to get at the evaporator.
    it did not appear difficult. maybe the guys have a lot of practice.. they can do in ten minutes, what you and me need an hour for... having a slim, small body helps.
    #12057
    well, i never do pms on my auto aircons. i bring them to the shop, when they fail to do their stuff. almost always, the cause was freon leak. the solution, was replacement of the part. twice, 'twas compressor clutch. cheap. cheap.
    Feb 2015
    #12058
    Bawal ba talaga ang LED h4 light ssasakyan?hinuhuli ba talaga ito?plan ko kasi magpakabit bali 6000lumen 6000kelvin cxa na hi/lo beam. Need advise muna sa inyo bago ako pakabit ,lalot manila ako gabi biyahe ko. Or osram nightbreaker unlimted nalang?tnx mga kainnova
    #12059
    Quote Originally Posted by maze View Post
    hindi ko na alam. nung una, sigurado na raw silang hindi na papayag sa led.. tapos, may na-balitaan akong kinakausap ng ilang concerned groups... ewan kuna ngayon kung ano ang puede at ano ang bawal.
    btw... bat naman palit? maliwanag naman ang standard innova headlights...
    Sep 2006
    #12060
    otw to Baguio last Friday evening, i started hearing a sort of screeching/rattling sound coming from the engine bay when we reached urdaneta. quick inspection under the hood revealed what sounded like the alternator bearing starting to give out. continued on up to Baguio since it was already 9pm.
    good thing may Toyota Baguio pala, had it fixed yesterday morning before we went to la trinidad. there goes my 5k though..
Toyota Innova Owners & Discussions [continued 3]
