Page 663 of 775 FirstFirst ... 563613653659660661662663664665666667673713763 ... LastLast
Results 13,241 to 13,260 of 15487
    Jun 2005
    #13241
    Get branded bulbs from reputable auto supply. Yung tig 20 pesos 6 months lang tinatagal.
    Bumili ako sa banawe, sabi ko yung japan na maganda klase. Binigyan ako yung tig 200 at magandang klase daw talaga.
    Well... That was 2012 pa. Never ko pa pinalitan ever since
    Quote Originally Posted by johann123 View Post
    Okey naman housing dr. d. Wala namang contacting between the metal sa loob. Yes right bulb po. Tomorrow i will upload pics.. Pansin ko na din sa ibang innova to eh 2015 and below. Pero tumagal naman ng 8 months yung bulb na napundi.
    Sent from my Redmi Note 5 using Tapatalk
    Sent from my MI MAX 2 using Tapatalk
    Aug 2018
    #13242
    Hey guys, what's your opinion on Shell Helix oils? Planning to change oil later this month with their service centers kasi malapit at mura lang. What's the type of oil that I should get? Thanks!
    Jun 2009
    #13243
    Quote Originally Posted by Trutregire View Post
    I have a gasoline engine. Sa Shell EDSA near GMA 7 ako. Ok naman. no issues. Been doing this after my 3-year warranty lapsed (2012). Helix HX7 gamit mo.
    #13244
    Quote Originally Posted by desertfox615 View Post
    btw,
    isn't that one of the cheaper shell outlets? that, and the other one at the other side of edsa...
    Nov 2007
    #13245
    Napansin ko madali mapundi mga bulb ng toyota lately. Baka inherent problem ng bulb supplier.
    Check mo na rin tamang voltage sa housing
    Jan 2013
    #13246
    For the 4th time. Pundi nanaman yung left break light namin. Yung right going strong pa. Sinong naka remedyo na sa inyo ng ganitong problem? Park light was good dun sa mga napunding breaklight bulb sa left.
    Nag umpisa naging ganyan sakin on the forth year at laging left side break light. Sinubukan ko rin branded bulbs pero ganun pa rin kaya pinalitan ko na lang ng led light so far ok na never happened again.
    Other than that no other issue.
    Aug 2005
    #13247
    Guys...
    Sa mga naka gas at model
    Kumusta ang fc?
    Highway and city drive.
    Planning to buy innova e gas at
    Thanks po.
    Quote Originally Posted by bhybhoy View Post
    Guys...
    Kumusta ang fc?
    Thanks po.
    how many kilometers per day? fully loaded? traffic like Manila?
    Jun 2005
    #13249
    The 2.0 gas engine of the innova get around 5-6km/li city driving. 8-9km/li on the highway. Tested on a 2006 J variant and a 2015 G variant
    Aug 2005
    #13250
    Sir,
    Will use maybe once on weekdays 30-40 km
    4 passengers including driver
    Manila and edsa traffic
    On weekends, travel to south like batangas or tagaytay
    Thanks
    once a week sa manila, coding vehicle? if so then it's an ok buy. it does 6-7km/l in heavy heavy traffic. in the highway it can do up to 12kml.
    Jan 2013
    #13252
    Guys...
    Kumusta ang fc?
    Thanks po.
    6.2km/l city and I got 10.4km/l nung binyahe ko Manila to legaspi and vice versa 4 passengers+luggage. Innova 2013 G AT 2013
    Jul 2015
    #13253
    Quote Originally Posted by nscostales39 View Post
    sir san nyo po binase yung papalitan lahat ng fluids for 40K PMS, kasi nung tinignan ko ang manual ay the usual 5K PMS(oil, oil filter), plus yung differential oil at yung brake fluid ang nakalagay, 2015 2.5 MT po
    Wala ko nakita reply ni Papi Particle so ako na lang.
    Di ko pa na check ang manual kung regular PMS lang ang sked for 40k. Pero nung nag pa 35k PMS ako, ang sabi sa kin ng SA ko, ang next na 40k eh medyo madugo daw yun.
    Ask ko kung magkano ang damage sa kanila since sabi nya eh madugo, around 20k ++ daw.
    Palit fluid daw lahat yun plus the regular PMS.
    PS. wala ako balak ipagawa sa casa yun.
    Aug 2005
    #13254
    Yes sir,. Thanks
    Quote Originally Posted by homhomnova View Post
    Thank you po
    Yes sir,. Thanks
    Thank you po
    do note the 2013model is not the 6sp but rather the 4sp.
    the new model has the 6spd and is 4-8% better..
    May 2015
    #13256
    Ohh. Anong brand na led light gamit mo sir [emoji4]. Yung mga ipinalit ko din kasi dito tig 10 pesos lang. Yun yung mga tumagal lang 2 months or less. Tapos i tried malapit dito sa amin na autosupply. Ibang brand tig 15 naman. Maganda ganda at tumagal. Naka 8 months din naman. Maybe i will try leds naman.
    Jan 2013
    #13257
    Kalimutan ko na anong brand pero medyo mahal 1k+ each ata bili ko nun sa Concorde Megamall.
    #13258
    i read, that leds last a very long time.
    but they do have a weakness: for long life, they are dependent on a regulated voltage.
    sometime ago, i bought some led replacement panels for my dome lights. hauyn... isa-isang napundi over the spread of less than a year. i guess, while leds by themselves may be cheap, the voltage regulating circuit may not be. i would not even be surprised, if the cheap ones do not have any.
    Sep 2018
    #13259
    Hingi lang po ng advice master, Tanong ko lang po okay lang ba 2sm battery sa toyota innova 2017? Plano ko palitan yun brucket para magkasya. My magiging problema po ba pag 2sm lang yun battery? Medyo mahal kase yun din66 nasa 8k
    Sent from my vivo 1716 using Tapatalk
    Mar 2018
    #13260
    You should follow the minimum required specs. Otherwise, pag underspecs, madali masisira. Mapapamahal ka pa.
    Sent from my ONEPLUS A3003 using Tapatalk
Toyota Innova Owners & Discussions [continued 3]
