Page 643 of 775 FirstFirst ... 543593633639640641642643644645646647653693743 ... LastLast
Results 12,841 to 12,860 of 15487
    May 2012
    #12841
    Need HELP
    Innova 2012 AT odo * 45k, last change oil wala pa 5k tinakbo around 4-5months ago
    While on NLEX ako 120kph takbo ko tapos sinisubukan ko pa accelerate ayaw mag accelerate, kahit ano apak ko sa gas ayaw na, ang nangyari nag slow down pa sya, until ma reach ko 80kph dun lang uli nag accelerate..walang error dashboard ko, napansin ko nangyari may maitim na usok na lumabas sa rear exhaust/ tambucho
    walang overheat o ano wala naman binago amoy sa makina, nag amoy usok or sunog ung tambucho after pero nawala rin agad
    Quote Originally Posted by evincar View Post
    Need HELP
    diesel? gas?
    May 2012
    #12843
    diesel? gas?
    Boss diesel
    Aug 2013
    #12844
    Quote Originally Posted by Mountain_Trail View Post
    Thanks Bro.
    Yung sa akin sound lang. Di nailaw ng matagal yung airbag indicator.
    Actually checking the airbag was supposed to be my 3rd work order pero parang na solved yung problema. Di na nag occur uli.
    First na ginawa ko was nag upgrade ng tire size to 205-70/R15 using Yokohama Geolandar series.
    Second was changed my engine oil to full synthetic.
    After those changes, di na nag occur ulit yung sound. Di ko alam kung dahil sa changes na ginawa ko pero inoobserbahan ko pa rin.
    I'll have the chance to verify if the unusual sound is gone paghahataw ulit sa expressway on the way North.
    Planning to change/upgrade my tire size too to 205-70/R15 from 65. Can it be used to stock mags, Sir? May I request for an actual photo? & may I ask for a cheaper but dependable brand of tire I only have limited budget of 3k maximum per tire (+spare). Thank u!
    By the way, 2014 model innova here in case it needs to mention.
    Jan 2009
    #12845
    Quote Originally Posted by Vann-O View Post
    Use the following tool to compare 65 and 70 profile tires. Tire Size Comparison
    With a 205mm width and 15-inch rim size, switching from a 65-profile to a 70-profile tire will make the vehicle 0.4 inches taller. The overall diameter of the 70-profile tire will be 0.8 inches bigger than the 65-profile tire.
    You can reuse the original rim.
    Aug 2013
    #12846
    Wow, never had fun comparing the 2 tires! So explanatory, it's fascinating. Kudos to you, Sir!
    You might as well suggest a cheap but worthy brand of tire. Hehe nilubos na
    Jul 2017
    #12847
    the remaining four studs can pick up the slack, but only temporarily, as it is weakened by the absence of the fifth stud. it should hold, in an emergency, or just so i can bring the car home. but i'd have it repaired as soon as i can.
    most studs are replaceable, po.
    naka-turnilyo o naka-saksak sila sa hub, from behind.
    any decent shop can do it.
    i'd replace just what is broken, po. no need to replace or repair them by pairs.
    thanks dr. d for the added knowledge
    Jul 2017
    #12848
    newbie here..marami akong natututunan dito..planning to get an Innova in 2 months time..
    May 2017
    #12849
    Yes, stock rim ginamit ko.
    Sorry, I have no current photo of the set up but there is enough clearance para di tatama sa sidings. I've blitz pass the expressway and up the winding country road and back. Di naman sumayad yung gulong sa sidings.
    I cannot make any recommendation on other tire brands of 205-70/R15 because this is the first time I tried this set up.
    Got my tires on promo buy 3 take 1 free for 15K.
    The tires I've already tried on the stock set up of 205-65/R15 was the Yokohama Apec, Thunderer Mach II and GT Champiro. Of the three, The Yokohama was the most reliable and sturdy. Bumukol yung Thunderer sa NLEX. Yung Champiro nagkakabitakbitak naman kaya nag Yokohama na ako, tsaka made in the Philippines yung Yoko. Patronize your own baga.
    Eto yung observations ko sa bagong set up:
    First, mas smoother yung ride. The bigger tires are better at dampening road imperfections lalo na sa rough/unpaved roads.
    Second, dati and ingay ng gulong ko lalo na sa expressway, ngayon super tahimik.
    Kaya lang may megative impact sa speedometer and odometer since they were caliberated to sync with 205-65/.
    Halimbawa yung speedometer reading is 100kph, yung actual speed is about 105kph kaya be aware sa highway baka ma overspeeding. Ganon din sa odo.
    Other than those, I'm very happy with my tire upgrade.
    looks good...
    Jun 2017
    #12851
    hello guys! did you watch the viral video about sa car nya na dinala sa casa sa toyota fairview. napakaharsh ng mga mechanic ginawang driving school yung mga sasakyan dun. watch nyo na lang eto link Ek Ek - MY HORROR STORY WITH Toyota Motor Philippines...
    Apr 2010
    #12852
    anong size ng windshield wipers natin? parang 24" and 16" if i am correct. eh yung sa likod? this is the first gen innova ah.
    streaky na kasi and yung driver side nagju-judder. buo papalitan ko, yung stock assembly na pagpapalitan eh bibili rin ako ng wiper blade refills as a backup
    #12853
    Hello guys. na post ko na to sa toyota 2016 thread, try ko na din dito.
    Napansin ko na masmababa yung front (left side) ng innova ko, innove 2017 model. Meron na ba sa inyo naka experience nito? Sinilip ko din yung shocks at parang may tagas na.
    Dalin ko bukas sa CASA para macheck, baka sakali lang meron na naka experience nito sa group atleast meron ako idea kung ano dapat gawin at compare dun sa sasabihin ng CASA.
    Apr 2010
    #12854
    kung may tagas na, it will be replaced for free. sabihan mo lang SA
    #12855
    Quote Originally Posted by ParticleX View Post
    correct. yung sa likod, 12".
    Aug 2008
    #12856
    hi sir, ask ko lang anong brand ng tire nabili nyo with 205/70/15 na specs. ask ko din sir kung bumigat ba handling ng steering or same lang . tnx po
    May 2017
    #12857
    Quote Originally Posted by Terrence View Post
    Bro, Yokohama Geolandar G046 205/70R15. Wala naman akong napansin na change sa handling ng steering. Yung kakaiba ay yung di masyado ma "feel" yung road surface. Isa pa pala, malambot sya sa cornering *33psi. Napansin ko ito nung umakyat ako sa bundok. Siguro dahil tumaas yung sidewall. Pag akyat ko ulit, try ko *35psi kung may difference.
    May 2017
    #12858
    Tanong ko lang sa mga nakapagparenew na ngayong taon sa LTO kung magkano binayaran nyo. Php2,329.06 yung inassess sa akin. Parepareho ba tayo ng binabayaran sa renewal o depende sa year and model? 2015 G a/t diesel sa akin.
    Oct 2005
    #12859
    Same lang po sir. Yung akin me additional lang po na 100 pesos dahil sa Top Load fee. Meron kasi ako shark carrier sa bubong kaya ipinasama ko sa rehistro. Kaya instead of 2,329.06 naging 2,429.06 registration fees ko 2010 innova diesel.
    May 2017
    #12860
    Quote Originally Posted by fyke View Post
    ah ok... good to know. thanks.
    matanong ko na rin kasi may top carrier ka kung anong effect sa takbo kung loaded yung carrier mo lalo na sa expressway. Hindi pa ako nagpapalagay kasi nag alangan ako effect nya. Kadalasan sa expressway takbo ko kaya kinoconsider ko yung stability and aerodynamic ng sasakyan. Though may bike rack ako sa likod na hindi naman feel na may drag, pero iba kasi tingin ko sa top carrier kasi direct na pumapalo sa headwind tsaka nasa itaas ng sasakyan yung load.
Toyota Innova Owners & Discussions [continued 3]
