Page 655 of 775 FirstFirst ... 555605645651652653654655656657658659665705755 ... LastLast
Results 13,081 to 13,100 of 15487
    Apr 2005
    #13081
    Na experience nyo ba langitngit sa ilalim ng new innova 2018? Mga 30km/h ang takbo pag nalubak. Try ko iuga sasakyan habang naka stop pero hindi sa shocks eh.
    Sent from my ASUS_Z012D using Tapatalk
    Aug 2008
    #13082
    Good pm, pa advise naman po kung ano problem ng aircon ng innova ko diesel, nawawala ang laming kapag kainitan na ng araw especially when im stuck in trapik, pero kapag tumatakbo na ng mabilis ok lumalamig na uli. I remember before i experienced this nagpapalit ako ng bearing sa compressor dahil maingay. it was addressed naman at nawala ang ingay. I had my radiator fan checked at ok naman malakas ang hangin. ano po kaya problem ng aircon ko could it be the compressor na? appreciate your inputs. thnx po
    #13083
    Quote Originally Posted by Terrence View Post
    "you're low on freon."
    did you have your ac cleaning at toyota? they clean the freon este remove the freon [emoji28]
    Jan 2018
    #13085
    inquire ko lng po yun whistling sound sa innova ko pag preno!
    brake pads replacement? o linis lng? thanks po!
    Dec 2014
    #13086
    i paid 2229.06 pesos for my 2012 innova diesel, a couple of yours ago, after the initial 3 year LTO expired.
    cost of TPL insurance, emissions test, change venue, not included. wala na resibos, but i estimate these to be less than 2000 bucks.
    the comprehensive insurance is over 10K, po, if you still want one.
    Magkano po kaya rehistro innova dsl 2015 model? Depende po ba sa model ang amount ng rehistro? Need ko na din mag rehistro after 3yrs. Tnx
    Sent from my SM-G570Y using Tapatalk
    #13087
    Quote Originally Posted by etoma View Post
    Check mo OR divide mo sa 3 yung amount ng MVUC
    Or check this:
    Schedule of Motor Vehicle User's Charge Pursuant to R.A 8794 and Other Fees and Charges
    Jan 2009
    #13088
    Any suggestion san ok mag pa 80K PMS, bandang QC, Valenzuela? Every 5K kasi sa shell lang ako nag papachange oil, pero yung 80K gusto ko palit na lahat ng fluids atf, gear, break etc. innova 2012 diesel.
    Aug 2013
    #13089
    Quote Originally Posted by frequenzy View Post
    Sorry I can't help kasi taga Laguna ako. If you don't mind, when did you last change your fluids?
    Jan 2009
    #13090
    Quote Originally Posted by dos2 View Post
    40K nung nagpalit ako. bale sinusunod ko lang din PMS schedule pero yung ngayon hindi na sa casa
    Sep 2006
    #13091
    kaya rin sa mga gas stations mag palit lahat ng fluids sir. yung sa akin sa goodyear servitek ko dinala. pero taga bulacan ako sir hindi QC.
    Jan 2009
    #13092
    Quote Originally Posted by ptk675 View Post
    san branch sir na servitek? available na ba yung mga oils sa kanila or kailngan ko magdala?
    Nov 2015
    #13093
    May nakapansin po ba sa inyo nung wheel well cladding sa rear right ay kalahati lang pero sa rear left buong wheel well, ganun din po ba sa inyo? Bakit kaya ganun
    #13094
    Quote Originally Posted by nscostales39 View Post
    ganun din yung sa akin.
    as an aside, my 2005 innova E has no plastic liners up front in the front wheel wells. the mud goes straight to the front bumpers.
    Jan 2009
    #13095
    di ko magets sa manual, kelan ba pinapalitan or nag refill ng radiator coolant?
    initial change: after 4yrs
    succeeding change is every 2yrs.
    Jan 2009
    #13097
    tnx sir, sakto ngayon taon mag 6 yrs. since hindi na ko sa casa, pwede ba bili na lang ako coolant sa casa, then ako na lang maglagay? top up lang ba yun or kailngan pa idrain?
    #13098
    Good day Sir....
    Napansin ko may kakaibang tunog sa innova vvti ko 2005... pina check ko nasa water pump daw.. saan po ako ako makabili ng magandang pump brand maliban sa casa and how much po?
    #13099
    Quote Originally Posted by kristine123 View Post
    Good day Sir....
    you can make a few phone calls to some stores, po. the prices from various stores usually fall within a narrow range. they can't afford to sell them at significantly higher price than the competition's, dahil walang bibili sa kanila. letting your fingers do the walking thru the yellow pages, still works.
    toyorama come to mind.
    but if this item is one of those items that only the casa imports, you will probably have to buy yours at high cost.
    some time back, i also searched for an item. it appears, some slow-moving items or specialized items, the local stores buy from the casa. hence the casa prices from non-casa stores.
    Jan 2009
    #13100
    That's perfectly normal.
    Besides preventing mud and dirt from being being flung by the wheel to the under-bumper cabin vent, the rear-left splash shield is bigger because it is also protecting the fuel filler neck hose.
    The rear-right splash shield is smaller because it's just protecting the under-bumper cabin vent on that side.
Toyota Innova Owners & Discussions [continued 3]
