Mga boss san kaya nakaka bili ng cruise control na pang all new innova?
Sent from my VOG-L29 using Tapatalk
Long drives kasi ako everyday from binan laguna to bgc. Besides, off peak ang byahe ko so ma take advantage ko ang cruise control sana. Marami nga ako nakikita nagbebenta sa market place kaso sobrang mahal naman. Nakakita ako sa shopee or lazada P600 lang kaso nde naman ako marunong mag install
How do we know if the coolant needs replacement? Makalawang na kasi yung nakita ko sa radiator? I also could not remember kung napalitan ko yung coolant from the time I purchase my Innova 2008 A/T Gasoline...
Since I also have a newer vehicle Fortuner 2016 A/T Diesel, gusto ko din talaga malaman kung kelan dapat palitan yung coolant...
How often do you replaced or should replaced your aircon cabin filter? Or do you just blow the dust away? I have seen in online shop selling replacement parts for cabin filter as low as 300 pesos is it okay to use it for cabin filter? Thank you.
i hand-wash mine, until it is (subjectively) too deformed to re-use.
in my opinion, simply blowing air thru them, won't clean effectively enough.
try it, sir, and you will probably come to the same conclusion.
personally, i think these filters of questionable source, will work fine.
I do not have the manual pero I replaced all the fluids at 40K and planning to do it every 40K intervals. I mean magkano lang naman coolant. Yung mga used vehicles na binili namin dati we had to replace the radiator, hoses, and water pump due to excessive corrosion kasi hindi namaintain ng mga previous owner.
Plus I like seeing na bright pink yung color sa reservoir![]()
i also (try) replace every 40k km (less pa nga doon sa vios, dahil sa fake overheating problem), kasi i DIY coolant change every 2 years or 20k km, whichever comes first. pero ngayon siguro sundin ko na yung 40k km, malinis pa kasi when i did 20k km noon ^_^
btw 2nd hand ko na nakuha yun vios noon kaya ako medyo OC sa fluids
Actually around 130K din yung Innova ko at ngayon ko lang na pansin yung kalawang so I am now concerned. May I know how many liters of coolant needed to replace everything? Also, I heard that radiator flush harms the system and should be avoided, is that so? Kahit na me kalawang na, avoid pa din yung radiator flush?
Mine too my current coolant came with the car from the time it was released from the casa... but now me signs of kalawang, so I need to change now. But my question is if needed ba kaya yung radiator flush...
Just checked my Innova manual, it says there to change when it reaches 160,000km and 80,000km thereafter..
