Page 651 of 775 FirstFirst ... 551601641647648649650651652653654655661701751 ... LastLast
Results 13,001 to 13,020 of 15487
    #13001
    real benefit versus placebo effect.
    it also occurs outside of medicine.
    if user is satisfied, why not?
    May 2009
    #13002
    twice or maybe thrice na siguro na naglock ang front brakes ng innova...recently lang naglock na naman
    alam nyo naman si ako mejo heavy foot lalu na at minsan lang lumalabas ng bahay yung innova.
    last time na naglock e last week lang. may kargang apat na kabang bigas plus two adults. lower than 50 kmh ang takbo. had to apply the brakes suddenly tapos ayun naglock na..had to reapply the brakes pero naglock pa rin....mejo pinawisan din ako ng malamig dahil traysikel yung sinusundan ko.
    anybody with the same experience?
    mukhang di rin reliable yung electronic abs ng innova. dunno. lets give toyota the benefit of the doubt...mukhang umaasa lang sa lspv.
    Aug 2017
    #13003
    Hi, any tips on what to do or check after not using your car (Innova particularly) for 10 straight days? I left it with a full tank.
    Sent from my EVA-L19 using Tsikot Forums mobile app
    Jan 2009
    #13004
    Quote Originally Posted by willownavarro View Post
    I'd check the fluid levels (engine oil, ATF, coolant, PSF, and brake fluid). Check the tire pressures and basically just do an ocular around the vehicle to see if there's anything out of place.
    As for the battery condition, you'll know right away if it's low on charge if the vehicle fails to start. That, or maybe the battery contacts have started to corrode.
    #13005
    just "the usual" everyday things.
    i'd also check, kung may hayop sa ilalim na natutulog.
    Nov 2017
    #13006
    Kindly suggest best/cheap repair shop for the innova accessories:
    1, Master switch of my power window (original)
    2. Alarm & door lock remote control (generic brand)
    Quezon City, Sta. Mesa or San Juan area
    Thanks
    #13007
    Quote Originally Posted by Innova583 View Post
    Thanks
    for the alarm, i've had the casa's cheap model for over 4 years now. that one with black flat egg-shaped fob. less than 5K, including installment, according to the casa guy i asked.
    Aug 2017
    #13008
    Need knowledge mga brad, Kailangan ba e.pa linis ang throttle,egr at maf sensor ng 2013 Innova Diesel Manual?
    Sent from my ASUS_Z00UD using Tapatalk
    Feb 2006
    #13009
    matibay din po yun alarm na yun palit battery ok na uli, hirap lang nun pag start ng makina mga ilang segundo naglolock na po
    Jan 2009
    #13010
    When did you have the PSF and ATF replaced?
    Do indicate if you replaced either after x Years or y Km.
    #13011
    as a possible buyer, tanong ko lang sa mga may-ari, kamusta ang sakay nito? matagtag ba like the hi-ace? how is the fuel efficiency? matipid ba yung diesel variant? sirain ba o very problem-free? thanks to all in advance.
    Jan 2009
    #13012
    Quote Originally Posted by moneyp View Post
    Are you referring to the 1st gen Innova (2006-2015) or the 2nd gen (2016- )?
    Brand new or used?
    #13013
    looking to get a brand new one. comparing which is better, diesel innova kasi vs vw caddy or even maybe peugeot expert tepee. thanks.
    #13014
    anyone experienced this? the rear aircon drain has been dripping water for around 2 days after use. hindi naman napaandar ang sasakyan. walang drip sa front aircon. only unusual i see is hindi nakaoff ang thermostat ng aircon.
    the water was quite cold. what could be the possible reason? ill try checking tomorrow if it still drips with the thermostat turned off.
    #13015
    Kamusta ang sakay ng innova? matagtag ba?
    #13016
    if the new innova is as good as the old, then it should also be problem-free.
    the new version has been in the market for a short time only. it takes some time for problems to show themselves.
    Nov 2015
    #13017
    Meron po bang OBD II port yung innova 2015 diesel manual, kung meron po san sya located?
    Jan 2009
    #13018
    Quote Originally Posted by nscostales39 View Post
    Yes and no.
    It has an OBD-II ‘style’ DLC connector located under the plastic panel below the steering wheel.
    The bad news is, it doesn’t seem to be using the standard OBD-II signaling protocol so third-party OBD-II scanners may not work. I’ve tried both ScanGaugeII and UltraGauge... nada.
    The only reliable means to get data out of it is to use Toyota’s own scanner, the Techstream. I bought an OBD-II-to-USB converter included with the Techstream software CD-ROM (for PC) from eBay and I use a laptop if I need to extract info from it.
    Nov 2015
    #13019
    Yes and no.
    Gagana po kaya yung mga Head Up Display na OBD II
    Jan 2009
    #13020
    It's unlikely. But if you can test it before buying it, it's worth a try. You can share your experiences here as I'm sure a lot, including myself, will be interested with the results.
Toyota Innova Owners & Discussions [continued 3]
