Sir hingi naman ako suggestions magpalit kase ako ng mags to R16 from R15 stock, ideal nb ang 215/65/16 na sukat? ok ba westlake or any other brands na budget meal lng? sa blumentritt pa rin ba best place bumili? TIA
Sent from my SM-G610Y using Tapatalk
Just finished replacing all the fluids except coolant at 80K, total damage is 5200 pesos sa Shell Mindanao Ave
regular oil
atf
gear oil
power steering fluid
brake fluid
then replace na din brake pad at shoe
bendix brake pad - 1100
bendix brake shoe - 1600
labor - 900
Which Toyota Dealer has the best after sales service? Will be bringing the Innova for its 185k kms pms
Sent from my SM-A700FD using Tapatalk
Ah. We just leave the car and come back for it kahit may appointment... Para hindi magmadali yung mga tech and hopefully they can spot things they may not when they're under the time pressure gun. Pag ganun they just receive the car usually immediately and you're on your merry way.
tanung ko lang po kung pag po ba off ng engine iniooff nyo din po ba un thermostat ng aircon or leave as it is na lang kung saan sya naka set bago patayin makina
[QUOTE=blacksun25;1723992]kung nagbabawas, may leak. better have it fix. kung wala pa budget para ipagawa, you can add any ATF na Dexron II or III. hth.
Good day!
May bgong innova kami na gas. Napapnsin ko na
ang lakas niya mag consume ng gas. E naka eco
mode naman. And mahina ba tlga sa arankada at
akytan ito.?
May mga nababasa din kasi akong ibng comment
sa ibng site na negative pagdting sa innova..
Need some advise... Thank you...
diesel is the more popular choice for the outgoing first generation innova, if i remember right.
more responsive engine and cheaper fuel cost, daw.
so, how strong is your gasoline consumption, sir?
