Page 467 of 775 FirstFirst ... 367417457463464465466467468469470471477517567 ... LastLast
Results 9,321 to 9,340 of 15487
    Sep 2011
    #9321
    Most of the times nawawala na yung mga all-in promo/freebies ng mga dealer kapag sa bank mo pinadaan ang loan mo. Standard freebies na lang ung makukuha + ung unit discount. You can still choose kung sang dealer ka kukuha kausapin mo lang ung bank na sila kumontact sa SA na kausap mo.
    Posted via Tsikot Mobile App
    May 2012
    #9322
    2014 Toyota Innova J DSL MT
    5k+ odo reading
    city driving FC (moderate to heavy bumper to bumper traffic) 7.3kms/liter
    Fuel: Seaoil bioexceed diesel
    route: sta. mesa, manila to mckinley hill, taguig
    travel time +/- 1 hour (7am to 8am)
    distance 10-11km (di ako sure sa exact)
    Ok ba FC ko mga sir? Thanks
    #9323
    Quote Originally Posted by crosswind View Post
    in my experience
    It cost around 10k in the casa and 6k in Shell
    konti lang naman difference saka mas maganda parin pag genuine
    toyota parts
    If that is the case, bili ka na lang ng piyesa from Toyota...
    And then, ipakabit mo sa suking talyer....
    “The measure of a man is what he does with power – LJIOHF!”
    24.3K:jump2:
    #9324
    Quote Originally Posted by jl0412 View Post
    5k+ odo reading
    my average is 10-11 km/li, but that's no bamper 2 bamper...
    7.3 seems a little high, unless traffic was really baaad..
    May 2012
    #9325
    Medyo traffic kasi sir sa umaga lalo na sa shaw going to C-5. bumper to bumper mga 15-20mins ako dun. inaalala ko nga malakas talaga Consumo ng Innova ko. naka 2 full tanks na ako same FC pa din lumalabas. pero nung inuwi namin ng Ilocos hindi naman naubos yung full tank sa one way may natitirang 1/4 full.
    Jan 2014
    #9326
    24.3K:jump2:
    Pwede ba yun bro
    never pakasi ako bumili ng genuine parts tapos sa labas papakabit
    kasi ako pag sa casa ko dinala doon kona papakabit
    1st experience ko lang sa labas magpa PMS eh
    Aug 2013
    #9327
    Pwede ba yun bro
    pwede ito bro. pwede ka din bumili ng oil or other needs pang PMS sa casa at hindi ka magpapa gawa sakanila. may parts section sila, hiwalay yun sa service section ng casa.
    o bili ka sa Toyorama, Gant, Cruiser, at RPMS, yan ang alam kong nagbebenta ng Toyota OEM parts outside Casa.
    #9328
    Pwede ba yun bro
    errr... what parts are these po?
    i like to think that there are more legitimate products outside the casa than illegitimate ones..
    besides, mahal talaga sa casa. sometimes, however, we (i) have no choice, because only the casa has the parts i need..
    Jan 2014
    #9329
    it Is the brake pads,yung sa handbrake,clutch (nakalimutan ko tawag), pressure plates and oil din
    yung mga kailangan palitan po
    Aug 2008
    #9330
    good morning bros ask ko po, do we need to change the power steering fluid of our innova over the time or can i just add power steering fluid if it is at low or minimum level? same with the clutch fluid saan nga po pala lagayan ng fluid ng clutch. tnx
    May 2005
    #9331
    Quote Originally Posted by Terrence View Post
    If you have to top up then that can only mean you have a leak.
    It is better to fully drain out old fluids and replace with all new fluid.
    Aug 2008
    #9332
    thanks sir, i will have my trusted mechanic to do it.
    #9333
    Mga ka-innova.
    Napansin ko while driving may napansin ako unusual sa steering ko. Medyo kumakabig pakanan and kailangan nakaalalay ka sa manibela compared before.
    Dinala ko sa new capitol tire (goodyear servitek) sa kapitolyo. Akala ko simpleng alignment lang kelangan.
    Then the mechanic told me need na daw palitan tie rod.
    Here are my questions:
    1. May nakapagpalit na ba senyo? Nag 8yrs na pala innova ko.
    2. Ano ba cause ng sira? Yes im sure wear and tear aside from that, Road conditions ba? Driving style?
    3. They quoted me na papalitan
    2 rack end php 2200
    2 tie rod end 1600
    Camber and align 1200
    Labor 1800
    Total is 6800
    Tama ba ito? Ilan ba components ng tie rod? Hindi pala siya isang piyesa lang?
    Mura na ba yun? O lipat ako shop? Baka may marekomenda na din kayo na trusted TIA!
    3. Mandatory ba alignment and camber after changing it?
    4. I asked also the mechanic am i endangering my life driving while sira yung tie rod. Hindi naman daw. Yung gulong daw ang mag suffer dahil maapektuhan yung upod. Tama ba yun? Or asap ipagawa na?
    Salamats!!
    #9334
    first of all, did the mechanic say the suspension was out of alignment?
    did he further say the suspension components were already worn and needed replacement?
    if the suspension parts are already worn, then they must be replaced, before alignment is attempted. it is not good practice to perform alignment with worn parts.
    at that age, i would probably replace my suspension parts in pairs.. left and right....
    and i have no idea of the price of innova suspension parts, because i have not yet had mine replaced after nine years and almost 100K km.... napaka-tibay...
    only my shocks needed replacement..
    suspension parts usually make a lot of noise or cause mis-alignment problems first, before they fall apart... that means, we are given ample warning to replace them..
    when they finally fall apart, we (our car) might become uncontrollable as regards to steer-ability..
    if your car's bottom just falls to the ground in the event of catastrophic suspension failure, you can consider yourself lucky.. there are far worse things...
    Jan 2014
    #9335
    Hello
    Mura na yan bro at ilang kilometro na takbo nyan
    kasi sa innova ko 140k kms na takbo at 7yrs na at wala pa ko na encounter na ganayan
    at daily drive sya at out of town use
    try mo nga sir bago mo ipagawa
    check mo yung tire pressure mo kung pare sa both sides
    at idrive mo
    Yung sa crosswind 35k nga sa casa
    #9336
    Nung nakapila pa lang ako nilapitan ko mechanic and i told him my observation. Dun niya nasabi na baka alignment lang.
    After inangat dun niya nakita na tie rod nga.
    BTW I already replaced shocks earlier this year front and rear.
    Hello
    at idrive mo
    151K km to be exact. Daily driven din mixed city and out of town.
    Akala ko nga dahil oblong na yun gulong kaya may kabig, dun sa isang oto kasi namin kaya pala may kabig rh oblong na gulong.
    Jan 2014
    #9337
    siguro sir paayos nyo na para safe kayo
    btw 151k kms na natakbo ng
    Innova mo, so you already change your timing belt?
    where did you acquire it and how much po
    #9338
    ^ timing is? Same as serpentine ba yan?
    Kapapalit ko lang last april 30 if thats what you mean. Sa casa ko pinapalit nung nagpalit ako alternator.
    #9339
    Ahem..
    the serpentine belt is what we see in front of the engine block. it runs the accessories. that is easier to replace, as only tension adjustments are necessary.
    timing belt is hidden inside the engine. it's different from the serpentine belt. it's more difficult to replace, because one would have to remove certain covers to access it, and one has to follow certain markings, if the engine is to run well.
    good luck.
    Jun 2009
    #9340
    Quote Originally Posted by homhomnova View Post
    san ka nakabili sir ng knn air filter cleaner at charging oil? Matagal na ako naghahanap nyan puro out of stock daw.
    Btw.. d ba sya pwede i wash using joy dishwashing liquid?
    maraming salamat sa iyong kasagutan sir..
    Sir, sa Roadstar sa fort, its that strip mall after the Mercedes, Subaro, Kia show rooms
Toyota Innova Owners & Discussions [continued 3]
