Page 468 of 775 FirstFirst ... 368418458464465466467468469470471472478518568 ... LastLast
Results 9,341 to 9,360 of 15487
    #9341
    Ahem..
    the serpentine belt is what we see in front of the engine block. it runs the accessories. that is easier to replace, as only tension adjustments are necessary.
    timing belt is hidden inside the engine. it's different from the serpentine belt. it's more difficult to replace, because one would have to remove certain covers to access it, and one has to follow certain markings, if the engine is to run well.
    good luck.
    Oh! Hindi pa ako nagpapalit.
    Ano required period or KMs para magpalit nun? And timing chain na innova diba?
    Thanks!
    #9342
    Bro... if belt, replacement would be typically between 80kkm to 100kkm... Will check if belt or chain for Innova.... But ours is gasoline variant...
    #9343
    Mine is vvti too. Ano year model sayo bro CVT?
    Jan 2014
    #9344
    Thanks!
    Bro nasa manual
    150k kms. daw
    #9345
    Quote Originally Posted by crosswind View Post
    Bro nasa manual
    150k kms. daw
    Pffffft!
    Noted on that.
    Magkano kaya damage?
    Sep 2006
    #9346
    ^ medyo malaking gastos yan sir lalo if sa kasa. hindi lang kasi yung timing belt ang pinapalitan jan. may mga bearings, oil seals, tensioners, etc. na ideally sabay papalitan ng timing belt. i've heard it would be somewhere around 30-40k.
    Sep 2014
    #9347
    I am planning to put window visors on my 2.5G Innova, so that I can’t see the overlapping of the window frame covering plastic sheets.
    Wondering why Toyota uses black plastic sheets to cover the window frames instead of painting. It simply makes the car looks cheap.
    #9348
    Year Model 2008 bro.
    32.8KKm pa lang tinatakbo....
    Good kung 150KKm ang palitan ng timing belt... Silipin ko mamayang gabi sa manual... Nakalimutan ko e... :twak:
    “The measure of a man is what he does with power – LJIOHF!”
    24.4K:sailor:
    Aug 2008
    #9349
    gud am mga bros, ask ko po what good brand of headrest monitor for innova, my in-laws gave me his original grandia HU with dvd player nag-upgrade kasi cya ng HU with GPS naman. tnx
    #9350
    24.4K:sailor:
    Sarap talaga pag may fleet ng sasakyan sa garahe, hindi gulpi mga sasakyan hehe
    San advisable magpapalit timing belt/chain?
    Casa ba talaga?
    Or may shops na kilala na sa pagpalit neto?
    Thanks!
    Jan 2014
    #9351
    Casa ba talaga?
    Thanks!
    Casa would be the best place to replace your timing belt
    and you are sure it is original brandnew and not used timing belts
    http://tsikot.com/forums/toyota-cars.../index923.html
    #9352
    Casa ba talaga?
    Thanks!
    Bro.,- Hold your guns.....
    I just checked before I left for the office....
    The manual states
    "timing belt (diesel engine) ---- replacement is 150KKm..."
    Not sure if my eyes were playing tricks on me,- but nothing was mentioned on gasoline engine...
    So,- I supposed that our gasoline-fed Innovas use timing chain,- and there is no need to replace... Just regular adjustment....
    Can anyone here confirm this, please? TIA....
    24.4K:sailor:
    #9353
    The manual states
    24.4K:sailor:
    Woah! praying for this!
    Badtrip wala na kasi manual ko
    Aug 2009
    #9354
    Timing chain po ang VVTi while timing belt naman para sa D4-D. Replaced our timing belt during 75K PMS for peace of mind. HTH!
    #9355
    So for vvti need pa ba replacement timing chain?
    Aug 2009
    #9356
    ^Hindi na po kailangan sir. Baka need lang ng adjustment (if needed) as stated by sir CVT.
    Jan 2014
    #9357
    Quote Originally Posted by Sleepcare View Post
    why during the 75k kms. PMS?
    our casa didn't advise us to changed it and
    will wait until it clocked 150k kms.
    btw How much did it cost err. the timing belt
    Aug 2014
    #9358
    In some forums, 75k is the earliest statistics where timing belt failure occurred, thou rarely.
    few only had experience this.
    for peace of mind change it between 75-90k.
    Aug 2009
    #9359
    I told the mechanic to check it kasi nabalitaan ko din yung tungkol sa pagputol ng t-belt before the 100k mark. Then upon inspection ng t-belt, manipis na siya and medyo bakat sa belt yung "ngipin" ng gears. Sinabay ko din siya sa refill ng silicon ng fan sa radiator para isang trabaho lang since kakalasin lang din tska mas malawak yung space. Nakalimutan ko na yung price since 2 years ago na yun pero most probably less than 2k+labor. (btw this was done in our suki shop)
    Aug 2009
    #9360
    Quote Originally Posted by vix View Post
    Parang pareho ata tayo ng nabasa na forum ah. Hehehe! Yan din sinabi ng mechanic kaya pinagawa nalang. Mahirap din i-inspect since covered yung t-belt.
Toyota Innova Owners & Discussions [continued 3]
