Page 457 of 775 FirstFirst ... 357407447453454455456457458459460461467507557 ... LastLast
Results 9,121 to 9,140 of 15487
    #9121
    Quote Originally Posted by gygie View Post
    mga sir, every morning pag start ko ng innova gas engine ko may squaking sound na madidinig pero after a while, nawawala naman. pero sa umaga lang naman yun. loose belt kaya? 52k palang odo ng sasakyan ko eh. TIA.
    pag nababasa po yung belt ay nag kakaroon ng squeaking sound pero around mga 2 to 5 seconds maximum lang...
    nag squeak po sya tuwing nababasa ang grill sa ulan or sa washing tapos naiipon sa radiator kaya pag start mo ay nababasa ang belt.
    Mar 2012
    #9122
    Quote Originally Posted by kristine123 View Post
    Thanks ma'm kristine123. actually more than 5 seconds yumatagal yung ingay. kahit hindi naman po nabasa yung car ay meron pa din ingay sa umaga. ang sabi lang ng mekaniko, lagyan na lang ng belt dressing. safe kaya ang WD40 sa belt?
    Jul 2014
    #9123
    Good suggestion ng mekaniko sir.. Baka imbes na tumagal ang belt dumali sa paglalagay ng oil o WD40.. Baka palitin na ang belt o mga idler pully sira bearing o marumi lang.
    Tsikot Mobile App
    #9124
    ^^^ Huwag WD40 bro... May nabibili namang belt conditioner/grip sprays, iyon na lang gamitin mo....
    “Familiarity breeds awe”
    23.9K:thud:
    Jan 2012
    #9125
    sir, this happened to me before, was advised to check the power steering motor, fluids and joints.
    Jan 2012
    #9126
    Quote Originally Posted by boogie18 View Post
    Hi guys need help... where is the best shop to have the aircon cleaned na hindi sa casa? Thanks a lot!
    sir, I just had my aircon cleaned, 2 evaporators replaced, all fluids flushed at Cruven Shaw Pasig.... with warranty pa.
    Aug 2012
    #9127
    Thanks sir! Would you know how much yung cleaning lang? Evaporators need to be replaced ba pag cleaning? Thanks!
    Aug 2012
    #9128
    Sir cvt, im from paranaque... any good abd trusted places around? Thanks!
    Jun 2014
    #9129
    Mga pips, Question lang poh. saan mo maganda mag pa-fabricate ng front chin ng innova 2014?
    Maraming salamat poh
    Mar 2012
    #9130
    [QUOTE=CVT;2384776][COLOR="#008080"]
    thanks sir CVT, may nabili kasi akong elevo silicon spray. naka sulat a label, safe for rubber and vinyl. puede kaya ito?
    Aug 2014
    #9131
    need help mga sir, kaka-install lng ng turbo timer ko (AMATA Brand), so far ok naman sya, pero after na tanggalin ko na ang key sa sasakyan, automatic mag-activate na ang turbo timer, pero merong ABS na indicator na lumalabas sa dashboard. Tanong ko lng if normal lng ba ito mga sir? if running naman yung engine with key na naka-attached, di naman lumalabas yung ABS na indicator. Toyota innova E 2014 yung unit ko.
    #9132
    kung aircon cleaning and repair since nasa paranaque ka highly recommended and ceejays sa laspinas. maraming tsikoters ang nagpapagawa dito. may special discount pa ang mg tsikot
    #9133
    Quote Originally Posted by josaix View Post
    parang may nagalaw sa wiring ng innova nyo. G-gas itong sa akin normally pag switch ON ng ignition, iilaw ang mga indicator including ABS then mawawala din after 2-3 secs. pag patay at hugot naman ang susi dapat walang naka ilaw. bago ba pa install ng turbo timer ganun na?
    Jan 2012
    #9134
    Na putol po ung antenna ng innova. saan may nabibili at magkakabit aside from casa? may nabalian na po ba ng antenna dito?
    Thanks
    Jan 2014
    #9135
    try figidzone po
    Jan 2014
    #9136
    mga innova owners
    ano po magandang wiper sa innova
    palitin na kasi size nya 24 saka 16
    #9137
    Quote Originally Posted by crosswind View Post
    mga innova owners
    i get the cheap wiper rubber refills. 130 kesos a pair.. replacing/installing them does take some getting used to...
    Jan 2014
    #9138
    dr.d it will be challenging though that's why; I'm
    opting for the whole one
    #9139
    yes, i understand. i was cursing myself the first time.. it wasn't as easy as what the instructions made me believe..
    i have only one experience with banana-type blades. it was more expensive, but i thought it lasted longer than the traditional. i just got the cheaper (mid-priced) one, from the mall (sm automotive store).
    Jan 2014
    #9140
    dr.d what brand did you get??
    i just got a hybrid nwb wiper for the crosswind
    ngayon sa innova naman
    daily driver yung innova ko malabo na wipe kawawa naman yung driver
Toyota Innova Owners & Discussions [continued 3]
